Old 01-07-2005, 10:23 PM   #1
Almost_there_1
Member#: 74837
2003 WRX
SRP whore
Default Fog lights
I was wondering if i could change the bulgs in my fog's and if so what kind of bulb is it.
WARNING: i didnt search because dial-up=t3h suck!
Almost_there_1 is offline   Reply With Quote
Old 01-07-2005, 11:38 PM   #2
brunetmj
Member#: 8023
2004 2.5 RS
Fog lights are H3's and yes you can change them. First remove the fog light cover/panel or whatever it's called. It just snaps off. You have to undue a couple of plastic push pins which are under the car along the front and side edge. You have to pull back the plastic that is covering the fog light area from under the car. No need to remove the whole thing it can just folded out of the way. There are two 10 mm bolts holding the light on from undernath. Remove the bolts and position the light so you can undo the clip on the back
brunetmj is offline   Reply With Quote
Old 01-08-2005, 03:49 AM   #3
Almost_there_1
Member#: 74837
2003 WRX
SRP whore
Thanks
FT: 04 WRX fog lights and fog bezels for STI fog light covers WRXSuShi Private 'Wanted' Classifieds 9 11-01-2011 02:59 AM
FS : '04/'05 WRX/STi CGM Fog Light Bezels (Surrounds) in VA TrailRated Exterior/Styling 4 10-27-2010 02:34 PM
FS : '04/'05 WRX/STi Fog lights, Brackets, Switch in VA TrailRated Exterior/Styling 2 07-08-2010 12:49 AM
Which hella fog lights fit the the stock fog light area? advance Interior & Exterior Modification 2 06-26-2001 02:32 PM
Fog light VS Fog light Cover gerardchau General Forum Archive 6 05-19-2000 08:58 AM
