Old 01-08-2005, 01:33 AM   #1
gsteclipse33
Member#: 72859
Default Access Port Stuck In Stage 2
well i was trying to flash the stock map so i could bring it to the dealer and i set it up to flash and then when i check whats map its on it says stage 2 93 oct again do i need to put those connectors on to flash stock map thats the only thing i havent tried
gsteclipse33 is offline   Reply With Quote
Old 01-08-2005, 02:34 AM   #2
jdubman
Member#: 57900
1981 Toyota FJ60
yup.....exactamundo!
jdubman is offline   Reply With Quote
Old 01-08-2005, 03:28 AM   #3
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
Yes, sounds like you only switched the real-time map. Should be good enough, but you may want to reflash the base map by hooking up the connectors under the dash and reflashing the base map.
drees is offline   Reply With Quote
Old 01-08-2005, 01:12 PM   #4
darkstarmoto
Member#: 44681
2011 WRX SWP Hatch
www.48hrs.info group lead
Your only going to see your base map...the AP won't show you your reltime map....so if you flashed the reltime "stock" map, you'll still see "stage 2 93 octane" when you go to check your map.
darkstarmoto is offline   Reply With Quote
Old 01-08-2005, 01:27 PM   #5
fasterthanrayswrx
Member#: 48672
2005 Subaru
WRX
exactly
fasterthanrayswrx is offline   Reply With Quote
Old 01-09-2005, 02:41 AM   #6
gsteclipse33
Member#: 72859
o ok cool thanks alot
Old 01-09-2005, 02:54 PM   #7
Brahmzy
Member#: 3293
'14 FXT-T
'15 XTERRA PRO-4X
Do you have a big hammer?
Old 01-09-2005, 11:48 PM   #8
Killian Maynard
Member#: 73734
2005 WRX I caught
you a delicious bass
Shouldnt you switch the base map to stock as well (uninstall AP)? If the dealer decided to do some work they will invariably disconnect the battery. Once the battery is disconnected the ECU will revert back to the base map. In your case if you left the base map at stage 2 the dealer could effectively notice the stage 2 programming.
Also arent you worried about having a DP while taking your car to a dealer?
Killian Maynard is offline   Reply With Quote
Old 01-10-2005, 02:19 AM   #9
gsteclipse33
Member#: 72859
thats easy to change out i didnt say i dont take it out
Old 01-10-2005, 02:37 AM   #10
Killian Maynard
Member#: 73734
2005 WRX I caught
So do you run the stock map (base map, AP uninstall) when you take it in as well?
Old 01-11-2005, 03:14 AM   #11
gsteclipse33
Member#: 72859
nah just stock real time thye dont see m to kno
Brand New CobbTuning Access Port 04-07 Subaru 2.5L Turbo Models STI.VI.TYPE-R Engine/Power/Exhaust 41 08-27-2008 10:55 PM
Access Port for 06 WRX 2.5 L iDrivaWRX AccessPort 12 11-16-2006 11:15 PM
For Sale: 04 STI Access Port and 05 STI Access Port NEW in Box $569 Shpped 4 Each!!! mrtrex Engine/Power/Exhaust 10 09-18-2006 08:43 AM
