Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 01-08-2005, 03:44 AM   #1
dgp2003wrx
Member#: 60955
2003 wrx
blue
Default ecutek boost problem
i also posted this in engine management section but...ok im not sure what is causing this, but i have a stock turbo and i just got my car reflashed on wednesday. when i get on the gas the boost spikes to about 20 then drops down to about 16, my mods are catless TBE+Up-pipe, and intercooler hoses. i had the 3/16 mod from being stock, but then i was told after i got the reflash that, that could be causing the high boost, so i took that out yesterday and today its still spiking, it was about 15-25 degrees out today when i tested it out, so is there anything anyone can recommend or have any thoughts on how to reduce the boost, or what is causing, im going to calll the shop that tuned it on monday to see whats up. i have a 2003 wrx
dgp2003wrx is offline   Reply With Quote
Old 01-08-2005, 03:54 AM   #2
Russ77
Member#: 69369
did you get a generic flash or a custom tune? if it was a generic flash, the 3/16's mod would definitely cause the boost you have. try taking it out and putting a stock coupler in.
Russ77 is offline   Reply With Quote
EcuTEK reflash problems Jim Payne Commercial ECU Reflashes 1 09-16-2006 02:24 PM
Weird ECUTek Boost Solenoid problems Virusx86 Engine Management & Tuning 1 10-23-2005 01:19 AM
ecutek boost problem dgp2003wrx Engine Management & Tuning 6 01-10-2005 03:24 PM
vf34/Vishnu Ecutek Reflash Problem Tuned Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-19-2004 03:48 AM
ecutek possible problem? onesillyracer2k2 Engine Management & Tuning 6 05-31-2003 05:57 AM
