Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 01-08-2005, 05:51 AM   #1
litebrite2001
Member#: 41656
2002 WRX Wagon
Default JDM STi Automatic Transmission
Does anyone have specs for a JDM STi Auto Tranny? I'm looking mostly for a wiring diagram. Power handling capabilities and quirks would be nice too. I'm hoping my uniqueness will pay off and I can use an aftermarket tranny controller like the one MSD offers to control it. I promise I'm not crazy. I'm sure someone saw this thing on ebay, and I was the only one dumb enough to buy it. Anything will help. Thanks.
litebrite2001 is offline   Reply With Quote
Old 01-09-2005, 02:01 PM   #2
GTScoob
Member#: 68602
02 STi Wagon
is it the sportshift model?
I know a lot of guys talk about wanting to swap in the sport-shift 4EAT but nobody really has bothered trying. I think it's probably the same as ours over here; possibly a beefier torque converter and clutchpacks.
GTScoob is offline   Reply With Quote
Old 01-09-2005, 09:48 PM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
umm ...
no...
no there is no sti auto
the sport shift for the 2.5T is the same as the american one
Old 01-09-2005, 09:51 PM   #4
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
There was never an automatic WRX STi. There may be a Legacy STi auto tranny, but you may have gotten scammed. I doubt there is much of a difference between that and a regular US auto. What did you pay?
garface is offline   Reply With Quote
Old 01-09-2005, 11:28 PM   #5
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
This is more than likely the auction:
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
I have heard of an STI automatic transmission before from somewhere, I believe Ralyrcr on the board had one. I have no idea what kind of automatic it is though, this is very similar to the one he had, very old. Probably circa 96-97? I wouldn't be surprised if it's just a standard old 4EAT with the 90/10 split.
Whatever it is, it's a step down from a WRX transmission. So unless you are using this in some old Subaru, it's probably not worth much.
Old 01-10-2005, 09:14 AM   #6
litebrite2001
Member#: 41656
2002 WRX Wagon
My gf is wanting to drive the rex and she can't drive standard. I probably did get scammed, but at least I have an auto tranny for her to use. I am 99% sure that this came off a 280hp EJ20 motor. That being said, is it truly weaker than the tranny's coupled to our 227hp motor? I've heard of the 5MT failing under stock conditions if you drive them too hard. I paid 350 shipped, which is probably way too much, but what can I do now? Does anyone have some electrical drawings so that the least I can do is try to make the best out of it?
Just so no one thinks I'm a wuss, I have an Automatic B18 CRX that I'm building as a track only drag car and the WRX is my daily driver with a TXS Stage 4 and a 75 shot.
Old 01-10-2005, 10:26 AM   #7
GTScoob
Member#: 68602
02 STi Wagon
An auto swap is going to be a lot harder than a manual swap into an automatic car.
You might as well go with a new wiring harness for that transmission because I doubt you will be able to splice any of the old wires together. You would probably be better off returning you car to stock and trading it in on a 4EAT rex.
Old 01-10-2005, 10:42 AM   #8
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
don't do this ...
put the tranny back on ebay
and sell your car and buy an auto
this is just a bad idea
don't make it worse by destroying the car
it more than likely came off an early 90s legacy RS ~ 220 hp
Old 01-10-2005, 11:04 AM   #9
garface
Member#: 1581
MY00 RS/STi7
That's actually not a bad price at all, though the mileage is a bit high. If you do decide to do this, I have a TCU and TCU harness that you might want. PM me if you're interested. Thanks.
Old 01-10-2005, 11:31 AM   #10
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
As painful as this may be, teaching her to drive stick may be less painful than swapping an automatic into a manual WRX.
Old 01-10-2005, 02:27 PM   #11
litebrite2001
Member#: 41656
2002 WRX Wagon
I don't really want to trade in the one I got. What are the chances of the tranny bolting in place, and what kind of engine management differences will need to be made. A rev limiter for WOT shifts should take care of a lot. Its easy enough to wire in a Neutral/Park limit switch to disable starting. An EJ20 should be set up to easily transfer between a auto and manual. I will need to find the taps for the hydraulic lines, but the shop manuals can give me that. I've done this in a few older cars, Mustang GT to GTA conversion, but none used electronics. They use a detent off of the carb to move shift points to higher RPM's at WOT. My biggest concern is how to control the shift solenoid as I don't know much about Subaru. I know I'm not an expert mechanic. 99% of my car experience was out of necessity not for pleasure. Thanks everyone for looking out for me, but I'd really like to tackle this one if it is possible without a lot of cutting and welding.
Old 01-10-2005, 02:37 PM   #12
garface
Member#: 1581
MY00 RS/STi7
It will bolt on, but you will need an AT driveshaft and rear differential. What you need to control the tranny is the TCU or transmission control unit. I have one for sale along with the harness that connects to it. I also have the automatic shifter and linkage as well as the brake pedal assembly. Just let me know if you want any of these items. [email protected] or pm me.
Old 01-11-2005, 05:29 AM   #13
litebrite2001
Member#: 41656
2002 WRX Wagon
Now comes the stupid question... Why would I only change one differential? Where would the difference come from between the front and rear? In the center diff? Or is there actually some internal gearing in the tranny that puts out two different speeds between the front and rear? I am not being sarcastic, I am truly having trouble picturing this. On a 4WD, I would have a transfer case, and the front and rear driveshafts spin at the same speed, so if you change one diff, and don't change the other, the first time you engage 4WD, BOOM.
I could have a driveshaft fabbed locally, and would probably go strong enough to do a future RWD conversion, but that's a whole 'nother project.
Old 01-11-2005, 08:08 AM   #14
garface
Member#: 1581
MY00 RS/STi7
The front and center diff are in the tranny. So the only diff you haven't changed yet is the rear, and you have to do it otherwise, then comes the boom.
FS : JDM STi wagon rear lip painted CGM Shagon Wagon Exterior/Styling 4 06-03-2010 11:50 PM
FS/FT : 96 jdm sti ver.2 seats F&R k3lh3 NWIC Private Classifieds 5 06-03-2010 09:23 AM
JDM STi Complete Transmission z-rex Drivetrain 44 03-13-2010 04:26 PM
jdm sti v4 transmission question mannyOlicious Transmission (AT/MT) & Driveline 6 10-20-2008 05:36 PM
JDM STi AUTOMATIC Transmission Roo Private 'For Sale' Classifieds 0 03-15-2005 10:45 PM
