Old 01-08-2005, 10:19 AM   #1
fosgate769
Member#: 55841
2007 STi
WR Blue
Default how to clean engine bay
I currently have my intake manifold and tgv housing off for work. Noticed that my engine bay is really dirty, whats the best way of getting all that dirt ect. off.
fosgate769 is offline   Reply With Quote
Old 01-08-2005, 10:23 AM   #2
Perdue
Member#: 57431
98 Legacy GT
04 Dakota QC 4x4
Cold engine, put a bag or something around your air filter, simple green, let it sit for a few minutes, then come back with a hose (some use a pressure washer) and spray it off. If it's the first time you're doing it, you might have to repeat this a couple times and maybe use a brush of some sort to get rid of the stubborn stuff.
Perdue is offline   Reply With Quote
Old 01-08-2005, 02:12 PM   #3
Tim-E
Member#: 19990
03 Wrx
WR blue
When I had my jeep I used to use two cans of Gunk engine cleaner, followed by two cans of brake cleaner and it always worked,,, still use it to this day on my wrx and it always comes out great
Later on
-Me-
Tim-E is offline   Reply With Quote
Old 01-08-2005, 02:19 PM   #4
STi-MAN
Member#: 70252
05 STI
blue
i hear simple green works really well. yea coming from cleaning a honda engine bay the subaru one looks pretty intimidating.
STi-MAN is offline   Reply With Quote
Old 01-08-2005, 02:50 PM   #5
pleue
Member#: 35469
2002 wrx wagon
mbp
probably not the best to clean with the intake manifold off hehe. I warm up the engine for about 10 minutes, tinfoil the alternator just in case, spray with water, simple green, close hood, let sit 5 minutes, go over some stuff with a soft brush, spray clean, then dress the rubber. Some people spray anarmoral tire foam on all the rubber/plastic whch makes it look real nice, but not sure how good it is on rubber (drying etc.). good luck.
pleue is offline   Reply With Quote
Old 01-09-2005, 03:01 PM   #6
Honkey3k
Member#: 53992
SOLD CGM 2005 2.5RS
35 PSI -- in my tires
AWESOME CLEAN... iz teh baest
Honkey3k is offline   Reply With Quote
Old 01-09-2005, 04:17 PM   #7
Uncle Ben
Member#: 28628
2003 WRX Sedan
World Rally Blue Pearl
Is the air filter and alternator the only things you should cover up?
Uncle Ben is offline   Reply With Quote
Old 01-09-2005, 04:37 PM   #8
holland_patrick
Member#: 72014
05 Baja gone
Winner best wax job 06WBM
I'm not an expert but I normally use a hd cleaner (simple green,greased lighting or engine bright) warm or cold I normally don't cover anything. Spray and let it sit then brush or wipe or anything like that just scrub it up.. I then use a water based dressing after everything is dry. I used armor all or wd-40(it forces water out of tight spaces) but that's it and if you don't belive me this isn't a subie but mine is new so it's not dirty(my step daugters car) also put a spray and wax on the paint..I almost forgot that.
holland_patrick is offline   Reply With Quote
Old 01-09-2005, 04:37 PM   #9
Golfa
Member#: 21394
Sold 2004 STi
08 WW Evo X
if teh alternator gets teh wat0r in it, you will lose, pm davenow for more info
Golfa is offline   Reply With Quote
Old 01-09-2005, 04:39 PM   #10
holland_patrick
Member#: 72014
05 Baja gone
I have washed my engine bay for 10 years in my jeep and NEVER replaced the alternator.
Old 01-09-2005, 04:41 PM   #11
JnJassociates
Member#: 69539
2004 wrx wagon
red
I would cover up the fuse boxes as well, just to be extra carefull.
We use 303 Cleaner. It is concentrated and will not harm painted surfaces or plastics and rubber hoses. There are no fumes and it is non-toxic. Not to mention it is water soluble. Follow up with 303 protectant on your rubber and plastic.
Bryan
www.JnJAssociates.biz
JnJassociates is offline   Reply With Quote
Old 01-09-2005, 05:02 PM   #12
Seeing StaRS
Member#: 5294
simple green works great
Seeing StaRS is offline   Reply With Quote
Old 01-10-2005, 12:34 AM   #13
2k2
Member#: 12368
2008 Infiniti G35X
2011 BMW X5 Diesel
Honestly, do a search.
This has been discussed hundreds of times and the same things have been said.
I have detailed hundeds of cars using a high concentrate cleaner and pressure washer and not once have I had a single problem. You don't need to cover anything up.
Its best to clean then engine while its warm because thats when the grease will still be loose.
Just do a search and you will come up with plenty of threads, there needs to be a sticky on this.
Here is mine after one of my cleanings and dressings:
2k2 is offline   Reply With Quote
Old 01-10-2005, 06:00 AM   #14
wrxited
Member#: 58289
I've washed plenty of engines, and let me tell you that Castrol makes a great engine degreaser, that's if your engine is very extremely dirty, if not use Gunk. Gunk comes in a can which you can spray on,and by the way there are 2 kinds. One is a white can, which it is the normal cleaner, and the other, is blue and orange can which it leaves your engine with a armor all shine to plastic stuff in your engine bay, and doesn't leave your rubber hoses dry looking. Another thing is to cover the alternator with a plastic bag. Let me tell you that your alternator bearing doesn't like water, I've learned from experience, besides the alternator, nothing else needs to be covered. With that said, you will decide what you need. Since you have an 03 I don't think you will really need a concentrate cleaner.
wrxited is offline   Reply With Quote
Old 01-10-2005, 10:07 AM   #15
TreyS
Member#: 42478
2004 WRX STi
White/Gold
Another Simple Green fan here. +4
I washed mine yesterday.
Sprayed Simple Green on the engine, let it sit for a minute.
I covered the Apex'i air filter with a plastic bag.
Then I scrubbed the underside of the hood, then hosed the engine and hood off.
I then sprayed armor-all all over the engine and then closed the hood.
I washed the car at that point and dried the car off.
I then popped the hood and wiped down the engine to evenly distribute the armor all and remove the excess water.
Looks brand new every time...
TreyS is offline   Reply With Quote
How to clean your engine bay engine parts???? turbobird14 Car Care & Detailing 39 12-25-2008 01:43 PM
Best way to clean engine bay? sabubarub Interior & Exterior Modification 18 11-29-2005 09:12 AM
Products to clean engine bay? g0tb00st Interior & Exterior Modification 40 08-07-2005 12:34 PM
how to clean engine bay fookiethedookie Car Care & Detailing 24 09-16-2002 03:04 PM
How to Clean Engine Bay and Underbody? Josico Interior & Exterior Modification 1 04-20-2002 07:49 PM
