Old 01-08-2005, 02:59 PM   #1
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
Default wandering idle with valet mode [utec]
I had to valet my car a few times last week so I had the utec on valet mode, which seemed to work, except for the idle was wandering, and I could see my vaccuum fluctuating and the AFRs going way more rich and then lean than it normally does.
When I got in my car to go home, the guy had turned it off, so I switched the remote switch to one of my maps and tried to start the car, but it wouldnt start, it only cranked. Cycling the key didnt help,and the check engine light wasnt flashing when I turned the key on, I had to disconnect the battery and reconnect it to get the car started again.
Anybody had this problem before?
santofontana is offline   Reply With Quote
Old 01-09-2005, 05:06 PM   #2
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
bump
Old 01-10-2005, 06:54 AM   #3
Abe Froman
Member#: 22309
04 STI
05 LGT Wagon
Perhaps he selected the security mode? Once you select security mode the next time you shut the car down it won't start until you select another map...just a suggestion...
Abe Froman is offline   Reply With Quote
Old 01-15-2005, 12:41 AM   #4
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
No it was still on valet mode when he brought it up and turned it off, I switched it to a map and it wouldnt start no matter what I put the switch on. Too bad no one else has had this problem, its still happening.
Old 01-15-2005, 02:33 AM   #5
leon
Member#: 17123
Silva
Santofontana: I have the same problem. Does your valet mode limit you to 7 psi? mine sure as hell doesnt.
-Leon
leon is offline   Reply With Quote
Old 01-15-2005, 08:09 AM   #6
Abe Froman
Member#: 22309
04 STI
05 LGT Wagon
I would call TXS, sounds like a hardware issue, you may want to load the latest software but remember to save your maps to the computer first.
Old 01-15-2005, 10:39 AM   #7
hippy
Member#: 36528
2002 Impreza Wrx
Do you have one of your normal maps in slot 1?
Old 01-15-2005, 12:17 PM   #8
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
Im pretty sure I have a stage 2 base map in slot 1, but I cant check right now because my laptop is being repaired. I know that there is a working map loaded in slots 1-5.
Old 01-15-2005, 12:19 PM   #9
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
-Leon
Yeah the valet mode seems to work besides the rough idle and no start issue. I can hear the difference in the exhaust with the wastegate open. It wont get up to 10psi and is pretty slow.
Old 01-15-2005, 12:20 PM   #10
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
I emailed them and no response yet, maybe Ill have to call.
Old 01-15-2005, 07:36 PM   #11
leon
Member#: 17123
Silva
Mine doesnt do that.. I can definately boost OVER 7psi.. into like 14'ish.
I'm using the stage 2 map off of the TXS site.
Stage 2: TXS TBE
-Leon
Old 01-17-2005, 01:12 AM   #12
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
I got my laptop back and I have the base stage 2 new map in slot one.
I made a log of the idle.
Code:
730  -9.6 1.2   0  00    00   W/B  +12.6    1.7 ECU.   +0.0 ECU.   1.2  14.78
  721  -9.6 1.2   0  00    00   W/B  +12.6    1.7 ECU.   +0.0 ECU.   1.2  14.78
  733  -9.6 1.2   0  00    00   W/B  +12.4    1.2 ECU.   +0.0 ECU.   1.3  14.74
  728  -9.6 1.3   0  00    00   W/B  +12.7    1.5 ECU.   +0.0 ECU.   1.2  14.74
  708  -9.6 1.3   0  00    00   W/B  +12.4    1.6 ECU.   +0.0 ECU.   1.2  14.74
  727  -9.6 1.3   0  00    00   W/B  +12.7    1.7 ECU.   +0.0 ECU.   1.2  14.78
  734  -9.6 1.2   0  00    00   W/B  +12.8    1.6 ECU.   +0.0 ECU.   1.2  14.83
  736  -9.6 1.2   0  00    00   W/B  +13.9    1.7 ECU.   +0.0 ECU.   1.3  14.83
  724  -9.6 1.2   0  00    00   W/B  +13.4    1.5 ECU.   +0.0 ECU.   1.3  14.83
  711  -9.6 1.3   0  00    00   W/B  +14.4    1.5 ECU.   +0.0 ECU.   1.2  14.83
  711  -9.6 1.3   0  00    00   W/B  +13.7    1.6 ECU.   +0.0 ECU.   1.2  14.83
  736  -9.6 1.2   0  00    00   W/B  +13.1    1.5 ECU.   +0.0 ECU.   1.2  14.83
  736  -9.6 1.2   0  00    00   W/B  +12.2    1.7 ECU.   +0.0 ECU.   1.2  14.83
  733  -9.6 1.2   0  00    00   W/B  +11.6    1.2 ECU.   +0.0 ECU.   1.2  14.78
  721  -9.6 1.2   0  00    00   W/B  +13.0    1.2 ECU.   +0.0 ECU.   1.2  14.74
  699  -9.6 1.3   0  00    00   W/B  +15.1    1.7 ECU.   +0.0 ECU.   1.2  14.78
  725  -9.6 1.2   0  00    00   W/B  +14.1    1.7 ECU.   +0.0 ECU.   1.2  14.74
  734  -9.6 1.2   0  00    00   W/B  +13.5    1.7 ECU.   +0.0 ECU.   1.2  14.74
  731  -9.6 1.2   0  00    00   W/B  +12.7    1.6 ECU.   +0.0 ECU.   1.3  14.74
  707  -9.6 1.3   0  00    00   W/B  +13.0    1.6 ECU.   +0.0 ECU.   1.2  14.74
  715  -9.6 1.3   0  00    00   W/B  +13.0    1.7 ECU.   +0.0 ECU.   1.2  14.74
  746  -9.6 1.2   0  00    00   W/B  +12.0    1.6 ECU.   +0.0 ECU.   1.2  14.74
  728  -9.4 1.2   0  00    00   W/B  +12.5    1.7 ECU.   +0.0 ECU.   1.2  14.74
  739  -9.4 1.2   0  00    00   W/B  +13.3    1.5 ECU.   +0.0 ECU.   1.3  14.74
  735  -9.6 1.2   0  00    00   W/B  +12.3    1.7 ECU.   +0.0 ECU.   1.3  14.74
  716  -9.6 1.3   0  00    00   W/B  +13.1    1.6 ECU.   +0.0 ECU.   1.2  14.74
  731  -9.6 1.3   0  00    00   W/B  +14.0    1.6 ECU.   +0.0 ECU.   1.2  14.74
  729  -9.6 1.2   0  00    00   W/B  +13.2    1.7 ECU.   +0.0 ECU.   1.2  14.74
  739  -9.4 1.2   0  00    00   W/B  +13.5    1.6 ECU.   +0.0 ECU.   1.3  14.74
  732  -9.6 1.2   0  00    00   W/B  +13.7    1.6 ECU.   +0.0 ECU.   1.3  14.74
  707  -9.6 1.3   0  00    00   W/B  +14.4    1.6 ECU.   +0.0 ECU.   1.2  14.74
  726  -9.6 1.3   0  00    00   W/B  +13.5    1.6 ECU.   +0.0 ECU.   1.2  14.65
  720  -9.6 1.2   0  00    00   W/B  +13.5    1.6 ECU.   +0.0 ECU.   1.2  14.61
  724  -9.6 1.2   0  00    00   W/B  +13.7    1.5 ECU.   +0.0 ECU.   1.3  14.70
  737  -9.6 1.3   0  00    00   W/B  +13.6    1.5 ECU.   +0.0 ECU.   1.3  14.70
  725  -9.4 1.3   0  00    00   W/B  +12.4    1.5 ECU.   +0.0 ECU.   1.2  14.74
  717  -9.4 1.3   0  00    00   W/B  +12.4    1.7 ECU.   +0.0 ECU.   1.2  14.74
  717  -9.4 1.2   0  00    00   W/B  +12.3    1.5 ECU.   +0.0 ECU.   1.2  14.74
  732  -9.4 1.2   0  00    00   W/B  +12.8    1.5 ECU.   +0.0 ECU.   1.2  14.74
  733  -9.4 1.2   0  00    00   W/B  +13.2    1.5 ECU.   +0.0 ECU.   1.3  14.74
  745  -9.6 1.2   0  00    00   W/B  +13.3    1.5 ECU.   +0.0 ECU.   1.3  14.74
  730  -9.6 1.2   0  00    00   W/B  +12.3    1.7 ECU.   +0.0 ECU.   1.2  14.78
  711  -9.6 1.3   0  00    00   W/B  +13.3    1.7 ECU.   +0.0 ECU.   1.2  14.83
  714  -9.6 1.3   0  00    00   W/B  +13.2    1.5 ECU.   +0.0 ECU.   1.2  14.78
  718  -9.6 1.2   0  00    00   W/B  +13.8    1.6 ECU.   +0.0 ECU.   1.3  14.78
  735  -9.6 1.2   0  00    00   W/B  +13.4    1.4 ECU.   +0.0 ECU.   1.3  14.83
  726  -9.6 1.2   0  00    00   W/B  +11.8    1.6 ECU.   +0.0 ECU.   1.2  14.83
  709  -9.6 1.2   0  00    00   W/B  +13.4    1.5 ECU.   +0.0 ECU.   1.2  14.78
  712  -9.6 1.2   0  00    00   W/B  +13.5    1.7 ECU.   +0.0 ECU.   1.2  14.78
  713  -9.6 1.2   0  00    00   W/B  +14.9    1.6 ECU.   +0.0 ECU.   1.3  14.78
  732  -9.6 1.3   0  00    00   W/B  +13.3    1.5 ECU.   +0.0 ECU.   1.3  14.78
  717  -9.6 1.3   0  00    00   W/B  +12.0    1.6 ECU.   +0.0 ECU.   1.2  14.74
  704  -9.4 1.3   0  00    00   W/B  +12.8    1.7 ECU.   +0.0 ECU.   1.2  14.74
valet on
  728  -9.4 1.2   0  00    00   W/B  +13.1    1.6 +10.0  +0.0 ECU.   1.2  14.74
  708  -9.4 1.2   0  00    00   W/B  +14.1    1.5 +10.0  +0.0 ECU.   1.3  14.61
  698  -9.4 1.3   0  00    00   W/B  +15.2    2.0 +10.0  +0.0 ECU.   1.3  14.61
  712  -9.4 1.3   0  00    00   W/B  +14.8    1.4 +10.0  +0.0 ECU.   1.3  14.74
  736  -9.2 1.2   0  00    00   W/B  +12.8    1.6 +10.0  +0.0 ECU.   1.3  14.74
  750  -9.2 1.2   0  00    00   W/B  +10.9    1.5 +10.0  +0.0 ECU.   1.3  14.74
  757  -9.2 1.2   0  00    00   W/B  +10.4    1.7 +10.0  +0.0 ECU.   1.3  14.83
  739  -9.4 1.2   0  00    00   W/B  +11.3    1.6 +10.0  +0.0 ECU.   1.3  14.83
  698  -9.4 1.3   0  00    00   W/B  +13.8    1.6 +10.0  +0.0 ECU.   1.3  14.83
  698  -9.4 1.3   0  00    00   W/B  +15.7    1.6 +10.0  +0.0 ECU.   1.2  14.83
  712  -9.4 1.3   0  00    00   W/B  +16.1    1.5 +10.0  +0.0 ECU.   1.3  14.83
  736  -9.2 1.3   0  00    00   W/B  +14.2    2.0 +10.0  +0.0 ECU.   1.3  14.83
  746  -9.2 1.3   0  00    00   W/B   +9.9    1.5 +10.0  +0.0 ECU.   1.2  14.83
  740  -9.2 1.2   0  00    00   W/B   +9.9    1.6 +10.0  +0.0 ECU.   1.2  14.78
  709  -9.4 1.3   0  00    00   W/B  +11.4    1.7 +10.0  +0.0 ECU.   1.2  14.74
  691  -9.6 1.2   0  00    00   W/B  +14.5    1.5 +10.0  +0.0 ECU.   1.3  14.74
  651  -9.6 1.3   0  00    00   W/B  +17.7    1.5 +10.0  +0.0 ECU.   1.3  14.70
  684  -9.4 1.3   0  00    00   W/B  +18.4    1.7 +10.0  +0.0 ECU.   1.3  14.74
  692  -9.2 1.3   0  00    00   W/B  +14.8    1.4 +10.0  +0.0 ECU.   1.3  14.74
  755  -8.9 1.3   0  00    00   W/B   +9.9    2.0 +10.0  +0.0 ECU.   1.2  14.78
  808  -8.9 1.2   0  00    00   W/B   +4.2    1.8 +10.0  +0.0 ECU.   1.2  14.78
  766  -8.9 1.2   0  00    00   W/B   +7.3    1.4 +10.0  +0.0 ECU.   1.3  14.74
  711  -9.4 1.2   0  00    00   W/B  +14.1    1.2 +10.0  +0.0 ECU.   1.3  14.65
  670  -9.6 1.3   0  00    00   W/B  +18.0    1.5 +10.0  +0.0 ECU.   1.2  14.70
  686  -9.6 1.3   0  00    00   W/B  +17.7    1.5 +10.0  +0.0 ECU.   1.3  14.70
  686  -9.4 1.3   0  00    00   W/B  +17.2    1.5 +10.0  +0.0 ECU.   1.3  14.74
  737  -9.2 1.3   0  00    00   W/B  +14.6    1.6 +10.0  +0.0 ECU.   1.2  14.78
  761  -8.9 1.2   0  00    00   W/B   +8.3    1.5 +10.0  +0.0 ECU.   1.2  14.83
  766  -9.2 1.2   0  00    00   W/B   +6.9    1.8 +10.0  +0.0 ECU.   1.2  14.87
  731  -9.2 1.2   0  00    00   W/B  +11.2    1.7 +10.0  +0.0 ECU.   1.2  14.83
  707  -9.4 1.2   0  00    00   W/B  +14.3    1.7 +10.0  +0.0 ECU.   1.3  14.78
  686  -9.6 1.3   0  00    00   W/B  +16.2    1.5 +10.0  +0.0 ECU.   1.3  14.83
  704  -9.4 1.3   0  00    00   W/B  +15.9    1.6 +10.0  +0.0 ECU.   1.3  14.83
  738  -9.4 1.3   0  00    00   W/B  +14.0    1.5 +10.0  +0.0 ECU.   1.3  14.92
  762  -9.2 1.3   0  00    00   W/B  +10.7    1.7 +10.0  +0.0 ECU.   1.3  14.92
  781  -9.2 1.2   0  00    00   W/B   +7.9    1.6 +10.0  +0.0 ECU.   1.2  14.92
  757  -9.4 1.2   0  00    00   W/B   +8.6    1.7 +10.0  +0.0 ECU.   1.2  14.87
  722  -9.6 1.2   0  00    00   W/B  +13.0    1.7 +10.0  +0.0 ECU.   1.3  14.83
  694  -9.6 1.3   0  00    00   W/B  +15.9    1.6 +10.0  +0.0 ECU.   1.3  14.74
  684  -9.6 1.3   0  00    00   W/B  +17.3    1.6 +10.0  +0.0 ECU.   1.3  14.58
  687  -9.4 1.3   0  00    00   W/B  +17.7    1.4 +10.0  +0.0 ECU.   1.3  14.58
  712  -9.2 1.3   0  00    00   W/B  +16.8    1.7 +10.0  +0.0 ECU.   1.3  14.74
  755  -8.9 1.3   0  00    00   W/B  +10.4    1.5 +10.0  +0.0 ECU.   1.2  14.74
  774  -8.9 1.2   0  00    00   W/B   +7.5    1.5 +10.0  +0.0 ECU.   1.2  14.74
  758  -8.9 1.2   0  00    00   W/B   +6.8    1.5 +10.0  +0.0 ECU.   1.2  14.65
  716  -9.4 1.3   0  00    00   W/B   +8.0    1.8 +10.0  +0.0 ECU.   1.2  14.58
  695  -9.4 1.2   0  00    00   W/B  +17.3    1.2 +10.0  +0.0 ECU.   1.3  14.53
  691  -9.6 1.3   0  00    00   W/B  +17.3    1.5 +10.0  +0.0 ECU.   1.3  14.53
  696  -9.4 1.3   0  00    00   W/B  +17.3    1.6 +10.0  +0.0 ECU.   1.3  14.65
  722  -9.2 1.3   0  00    00   W/B  +14.9    2.0 +10.0  +0.0 ECU.   1.3  14.78
  752  -9.2 1.3   0  00    00   W/B  +12.5    1.6 +10.0  +0.0 ECU.   1.3  14.83
  775  -9.2 1.2   0  00    00   W/B   +7.9    1.6 +10.0  +0.0 ECU.   1.2  14.83
  749  -9.2 1.2   0  00    00   W/B   +9.9    1.7 +10.0  +0.0 ECU.   1.2  14.83
  701  -9.4 1.2   0  00    00   W/B  +13.6    1.5 +10.0  +0.0 ECU.   1.2  14.78
  684  -9.4 1.3   0  00    00   W/B  +16.4    1.5 +10.0  +0.0 ECU.   1.2  14.74
  666  -9.4 1.3   0  00    00   W/B  +18.7    1.4 +10.0  +0.0 ECU.   1.3  14.74
  676  -9.4 1.3   0  00    00   W/B  +19.1    1.4 +10.0  +0.0 ECU.   1.3  14.83
  750  -8.9 1.3   0  00    00   W/B  +17.9    1.6 +10.0  +0.0 ECU.   1.3  14.83
  803  -8.9 1.2   0  00    00   W/B   +5.0    1.6 +10.0  +0.0 ECU.   1.3  14.83
  791  -8.9 1.2   0  00    00   W/B   +4.5    1.7 +10.0  +0.0 ECU.   1.2  14.78
valet off
  773  -9.2 1.3   0  00    00   W/B   +6.6    1.9 ECU.   +0.0 ECU.   1.2  14.74
  729  -9.4 1.3   0  00    00   W/B  +13.1    1.2 ECU.   +0.0 ECU.   1.3  14.70
  750  -9.4 1.2   0  00    00   W/B  +14.0    1.6 ECU.   +0.0 ECU.   1.2  14.65
  759  -9.4 1.2   0  00    00   W/B  +12.3    1.2 ECU.   +0.0 ECU.   1.2  14.65
  753  -9.4 1.2   0  00    00   W/B  +11.4    1.8 ECU.   +0.0 ECU.   1.2  14.74
  753  -9.6 1.2   0  00    00   W/B  +13.4    1.6 ECU.   +0.0 ECU.   1.2  14.78
  735  -9.6 1.2   0  00    00   W/B  +13.5    1.6 ECU.   +0.0 ECU.   1.3  14.78
  733  -9.6 1.2   0  00    00   W/B  +13.9    1.6 ECU.   +0.0 ECU.   1.2  14.78
  722  -9.6 1.2   0  00    00   W/B  +14.3    1.2 ECU.   +0.0 ECU.   1.2  14.78
  711  -9.6 1.3   0  00    00   W/B  +14.4    1.6 ECU.   +0.0 ECU.   1.2  14.78
  708  -9.6 1.2   0  00    00   W/B  +13.7    1.6 ECU.   +0.0 ECU.   1.2  14.78
  733  -9.6 1.2   0  00    00   W/B  +14.8    1.7 ECU.   +0.0 ECU.   1.3  14.83
  730  -9.6 1.2   0  00    00   W/B  +13.6    1.6 ECU.   +0.0 ECU.   1.2  15.02
  723  -9.6 1.2   0  00    00   W/B  +12.8    1.6 ECU.   +0.0 ECU.   1.2  14.96
  709  -9.6 1.2   0  00    00   W/B  +14.1    1.5 ECU.   +0.0 ECU.   1.2  14.83
  701  -9.6 1.3   0  00    00   W/B  +14.1   20.5 ECU.   +0.0 ECU.   1.2  14.74
  728  -9.6 1.2   0  00    00   W/B  +14.2    1.5 ECU.   +0.0 ECU.   1.3  14.74
  739  -9.6 1.2   0  00    00   W/B  +13.8    1.7 ECU.   +0.0 ECU.   1.3  14.70
  722  -9.6 1.2   0  00    00   W/B  +12.0    1.2 ECU.   +0.0 ECU.   1.2  14.70
  712  -9.6 1.3   0  00    00   W/B  +13.7    1.7 ECU.   +0.0 ECU.   1.2  14.74
  719  -9.6 1.2   0  00    00   W/B  +14.1    1.5 ECU.   +0.0 ECU.   1.2  14.74
  731  -9.4 1.2   0  00    00   W/B  +13.2    1.7 ECU.   +0.0 ECU.   1.2  14.70
  726  -9.4 1.2   0  00    00   W/B  +13.5    1.5 ECU.   +0.0 ECU.   1.3  14.70
  728  -9.6 1.3   0  00    00   W/B  +13.0    1.2 ECU.   +0.0 ECU.   1.3  14.65
  716  -9.4 1.3   0  00    00   W/B  +12.6    1.7 ECU.   +0.0 ECU.   1.2  14.65
  731  -9.6 1.3   0  00    00   W/B  +11.6    1.7 ECU.   +0.0 ECU.   1.2  14.70
  735  -9.6 1.2   0  00    00   W/B  +11.7    1.5 ECU.   +0.0 ECU.   1.2  14.74
  717  -9.6 1.2   0  00    00   W/B  +13.6    1.7 ECU.   +0.0 ECU.   1.2  14.74
  730  -9.6 1.2   0  00    00   W/B  +14.4    1.7 ECU.   +0.0 ECU.   1.3  14.78
  729  -9.6 1.3   0  00    00   W/B  +13.3    1.5 ECU.   +0.0 ECU.   1.2  14.78
  717  -9.6 1.3   0  00    00   W/B  +13.0    1.5 ECU.   +0.0 ECU.   1.2  14.78
  728  -9.6 1.2   0  00    00   W/B  +12.4    1.7 ECU.   +0.0 ECU.   1.2  14.78
  719  -9.6 1.2   0  00    00   W/B  +13.2    1.5 ECU.   +0.0 ECU.   1.2  14.74
  728  -9.6 1.2   0  00    00   W/B  +13.7    1.6 ECU.   +0.0 ECU.   1.3  14.74
  729  -9.6 1.3   0  00    00   W/B  +12.9    1.2 ECU.   +0.0 ECU.   1.3  14.74
  716  -9.6 1.3   0  00    00   W/B  +12.7    1.6 ECU.   +0.0 ECU.   1.2  14.74
  741  -9.6 1.3   0  00    00   W/B  +13.3    1.5 ECU.   +0.0 ECU.   1.2  14.74
  720  -9.4 1.2   0  00    00   W/B  +12.3    1.7 ECU.   +0.0 ECU.   1.2  14.74
  728  -9.6 1.2   0  00    00   W/B  +14.0    1.6 ECU.   +0.0 ECU.   1.3  14.74
  743  -9.4 1.2   0  00    00   W/B  +13.2    1.6 ECU.   +0.0 ECU.   1.3  14.74
  708  -9.4 1.3   0  00    00   W/B  +13.1    1.7 ECU.   +0.0 ECU.   1.2  14.74
  715  -9.6 1.3   0  00    00   W/B  +13.1    1.5 ECU.   +0.0 ECU.   1.2  14.74
  726  -9.4 1.2   0  00    00   W/B  +13.4    1.5 ECU.   +0.0 ECU.   1.2  14.74
  725  -9.6 1.2   0  00    00   W/B  +13.6    1.5 ECU.   +0.0 ECU.   1.3  14.74
  734  -9.6 1.2   0  00    00   W/B  +13.0    1.5 ECU.   +0.0 ECU.   1.3  14.74
  719  -9.6 1.3   0  00    00   W/B  +12.7    1.7 ECU.   +0.0 ECU.   1.2  14.78
  713  -9.6 1.3   0  00    00   W/B  +12.7    1.6 ECU.   +0.0 ECU.   1.2  14.78
  734  -9.6 1.2   0  00    00   W/B  +13.1    1.6 ECU.   +0.0 ECU.   1.2  14.83
  727  -9.6 1.2   0  00    00   W/B  +12.8    1.6 ECU.   +0.0 ECU.   1.3  14.83
  731  -9.6 1.2   0  00    00   W/B  +13.9    1.6 ECU.   +0.0 ECU.   1.3  14.78
  730  -9.6 1.2   0  00    00   W/B  +12.4    1.7 ECU.   +0.0 ECU.   1.2  14.92
  708  -9.6 1.3   0  00    00   W/B  +13.8    1.5 ECU.   +0.0 ECU.   1.2  14.87
  725  -9.6 1.2   0  00    00   W/B  +14.7    1.5 ECU.   +0.0 ECU.   1.2  14.87
  728  -9.6 1.2   0  00    00   W/B  +13.2    1.7 ECU.   +0.0 ECU.   1.3  14.83
  747  -9.6 1.2   0  00    00   W/B  +11.8    1.6 ECU.   +0.0 ECU.   1.3  14.70
  724  -9.6 1.2   0  00    00   W/B  +13.1    1.6 ECU.   +0.0 ECU.   1.3  14.70
  700  -9.6 1.3   0  00    00   W/B  +13.7    1.1 ECU.   +0.0 ECU.   1.2  14.74
  728  -9.6 1.3   0  00    00   W/B  +14.0    1.7 ECU.   +0.0 ECU.   1.2  14.83
  743  -9.6 1.2   0  00    00   W/B  +12.4    1.8 ECU.   +0.0 ECU.   1.2  14.83
  736  -9.6 1.2   0  00    00   W/B  +13.2    1.7 ECU.   +0.0 ECU.   1.3  14.83
  722  -9.6 1.2   0  00    00   W/B  +12.7    1.5 ECU.   +0.0 ECU.   1.3  14.83
  717  -9.6 1.3   0  00    00   W/B  +13.3    1.6 ECU.   +0.0 ECU.   1.2  14.83
  737  -9.6 1.2   0  00    00   W/B  +13.4    1.6 ECU.   +0.0 ECU.   1.2  14.83
  734  -9.6 1.2   0  00    00   W/B  +12.1    1.6 ECU.   +0.0 ECU.   1.2  14.83
  739  -9.6 1.2   0  00    00   W/B  +12.7    1.7 ECU.   +0.0 ECU.   1.3  14.83
  712  -9.6 1.2   0  00    00   W/B  +13.1    1.5 ECU.   +0.0 ECU.   1.2  14.83
  708  -9.6 1.3   0  00    00   W/B  +14.3    1.5 ECU.   +0.0 ECU.   1.2  14.83
The idle starts wandering right when I switch the remote switch to #6 and stops when I go to 5.
My tuner shows the afr wandering alot more than the logs do, from the 13s up to the 15s.
Old 01-17-2005, 01:15 AM   #13
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
valet idle:
Code:
  776  -8.7 1.3   0  00    00   W/B  +11.6    1.9 +10.0  +0.0 ECU.   1.2  14.87
  850  -8.5 1.2   0  00    00   W/B   +4.3    1.8 +10.0  +0.0 ECU.   1.2  14.87
  807  -8.9 1.2   0  00    00   W/B   +4.5    1.9 +10.0  +0.0 ECU.   1.2  14.83
  743  -9.4 1.3   0  00    00   W/B   +5.6    1.8 +10.0  +0.0 ECU.   1.3  14.78
  683  -9.6 1.3   0  00    00   W/B  +17.6    1.5 +10.0  +0.0 ECU.   1.3  14.74
  719  -9.6 1.3   0  00    00   W/B  +16.9    1.7 +10.0  +0.0 ECU.   1.3  14.74
  709  -9.4 1.3   0  00    00   W/B  +16.5    1.6 +10.0  +0.0 ECU.   1.3  14.78
  708  -9.2 1.3   0  00    00   W/B  +16.1    1.5 +10.0  +0.0 ECU.   1.3  14.74
  730  -9.2 1.3   0  00    00   W/B  +14.3    1.5 +10.0  +0.0 ECU.   1.3  14.65
  739  -9.2 1.3   0  00    00   W/B  +12.3    1.6 +10.0  +0.0 ECU.   1.3  14.58
  736  -8.9 1.2   0  00    00   W/B  +12.2    1.7 +10.0  +0.0 ECU.   1.3  14.49
  734  -9.2 1.2   0  00    00   W/B  +13.5    2.0 +10.0  +0.0 ECU.   1.3  14.37
  749  -9.2 1.3   0  00    00   W/B  +13.0    1.6 +10.0  +0.0 ECU.   1.3  14.49
  712  -9.2 1.3   0  00    00   W/B  +12.4    1.6 +10.0  +0.0 ECU.   1.3  14.74
  700  -9.2 1.3   0  00    00   W/B  +14.8    2.0 +10.0  +0.0 ECU.   1.3  14.87
  722  -9.2 1.3   0  00    00   W/B  +14.6    1.6 +10.0  +0.0 ECU.   1.3  14.92
  735  -9.2 1.3   0  00    00   W/B  +13.5    1.5 +10.0  +0.0 ECU.   1.3  14.92
  762  -9.2 1.3   0  00    00   W/B  +11.5    2.0 +10.0  +0.0 ECU.   1.3  14.92
  749  -9.2 1.2   0  00    00   W/B  +10.9    1.7 +10.0  +0.0 ECU.   1.3  15.02
  719  -9.4 1.3   0  00    00   W/B  +13.7    1.6 +10.0  +0.0 ECU.   1.3  15.02
  682  -9.4 1.3   0  00    00   W/B  +15.5    1.7 +10.0  +0.0 ECU.   1.3  14.78
  694  -9.4 1.3   0  00    00   W/B  +16.1    1.4 +10.0  +0.0 ECU.   1.3  14.78
  694  -9.2 1.3   0  00    00   W/B  +16.5    1.9 +10.0  +0.0 ECU.   1.3  14.78
  723  -9.2 1.3   0  00    00   W/B  +15.1    2.0 +10.0  +0.0 ECU.   1.3  14.83
  743  -8.9 1.3   0  00    00   W/B  +12.1    1.5 +10.0  +0.0 ECU.   1.3  14.83
  761  -8.9 1.2   0  00    00   W/B  +10.5    2.0 +10.0  +0.0 ECU.   1.3  14.83
  757  -8.9 1.2   0  00    00   W/B   +8.0    1.6 +10.0  +0.0 ECU.   1.2  14.78
  743  -9.2 1.2   0  00    00   W/B  +10.6    1.5 +10.0  +0.0 ECU.   1.3  14.58
  693  -9.4 1.3   0  00    00   W/B  +12.3    1.5 +10.0  +0.0 ECU.   1.3  14.53
  677  -9.4 1.3   0  00    00   W/B  +19.1    1.9 +10.0  +0.0 ECU.   1.3  14.74
  676  -9.2 1.3   0  00    00   W/B  +17.7    1.4 +10.0  +0.0 ECU.   1.3  14.78
  715  -8.9 1.3   0  00    00   W/B  +16.2    1.4 +10.0  +0.0 ECU.   1.3  14.83
  762  -8.7 1.3   0  00    00   W/B  +11.8    1.9 +10.0  +0.0 ECU.   1.3  14.87
  807  -8.7 1.2   0  00    00   W/B   +6.3    2.2 +10.0  +0.0 ECU.   1.2  14.83
  792  -8.9 1.2   0  00    00   W/B   +4.3    1.7 +10.0  +0.0 ECU.   1.2  14.74
  743  -9.2 1.2   0  00    00   W/B   +8.0    1.6 +10.0  +0.0 ECU.   1.3  14.74
  648  -9.4 1.3   0  00    00   W/B  +15.1    1.5 +10.0  +0.0 ECU.   1.2  14.74
  642  -9.6 1.3   0  00    00   W/B  +21.0    1.3 +10.0  +0.0 ECU.   1.3  14.74
  686  -9.4 1.3   0  00    00   W/B  +21.3    1.6 +10.0  +0.0 ECU.   1.3  14.78
  752  -8.9 1.3   0  00    00   W/B  +17.8    1.9 +10.0  +0.0 ECU.   1.3  14.83
  789  -8.7 1.3   0  00    00   W/B   +6.1    1.5 +10.0  +0.0 ECU.   1.3  14.87
  793  -8.9 1.2   0  00    00   W/B   +5.5    1.7 +10.0  +0.0 ECU.   1.2  14.87
  747  -9.2 1.2   0  00    00   W/B   +6.7    1.6 +10.0  +0.0 ECU.   1.2  14.78
  673  -9.4 1.2   0  00    00   W/B  +19.1    1.4 +10.0  +0.0 ECU.   1.3  14.78
  633  -9.4 1.3   0  00    00   W/B  +21.7    1.3 +10.0  +0.0 ECU.   1.3  14.74
  628  -9.2 1.3   0  00    00   W/B  +21.3    1.5 +10.0  +0.0 ECU.   1.3  14.70
  737  -8.9 1.3   0  00    00   W/B  +14.7    1.7 +10.0  +0.0 ECU.   1.3  14.65
  812  -8.5 1.2   0  00    00   W/B   +6.4    1.6 +10.0  +0.0 ECU.   1.2  14.65
  824  -8.7 1.2   0  00    00   W/B   +4.4    1.8 +10.0  +0.0 ECU.   1.2  14.53
  748  -8.9 1.3   0  00    00   W/B   +7.6    1.3 +10.0  +0.0 ECU.   1.3  14.49
  675  -9.4 1.3   0  00    00   W/B  +14.0    1.7 +10.0  +0.0 ECU.   1.2  14.49
  651  -9.6 1.3   0  00    00   W/B  +20.5    1.8 +10.0  +0.0 ECU.   1.3  14.58
  655  -9.4 1.3   0  00    00   W/B  +21.3    1.6 +10.0  +0.0 ECU.   1.3  14.65
  718  -9.2 1.3   0  00    00   W/B  +19.7    1.8 +10.0  +0.0 ECU.   1.3  14.74
  769  -8.9 1.3   0  00    00   W/B  +11.6    1.9 +10.0  +0.0 ECU.   1.3  14.74
  805  -8.7 1.2   0  00    00   W/B   +4.3    1.7 +10.0  +0.0 ECU.   1.2  14.70
  775  -8.9 1.2   0  00    00   W/B   +5.9    1.3 +10.0  +0.0 ECU.   1.2  14.58
  717  -9.2 1.2   0  00    00   W/B  +11.2    1.7 +10.0  +0.0 ECU.   1.3  14.58
  667  -9.4 1.3   0  00    00   W/B  +16.0    1.4 +10.0  +0.0 ECU.   1.3  14.65
  663  -9.4 1.3   0  00    00   W/B  +20.7    1.5 +10.0  +0.0 ECU.   1.3  14.74
  656  -8.9 1.3   0  00    00   W/B  +19.9    1.6 +10.0  +0.0 ECU.   1.3  14.87
  756  -8.7 1.3   0  00    00   W/B  +13.0    1.7 +10.0  +0.0 ECU.   1.3  14.92
  814  -8.5 1.2   0  00    00   W/B   +6.0    1.7 +10.0  +0.0 ECU.   1.2  14.92
  810  -8.7 1.2   0  00    00   W/B   +4.3    1.7 +10.0  +0.0 ECU.   1.2  14.83
  769  -8.9 1.2   0  00    00   W/B   +6.8    1.9 +10.0  +0.0 ECU.   1.3  14.78
  709  -9.4 1.3   0  00    00   W/B  +12.5    1.7 +10.0  +0.0 ECU.   1.3  14.78
  643  -9.4 1.3   0  00    00   W/B  +18.4    1.4 +10.0  +0.0 ECU.   1.3  14.83
  706  -9.4 1.3   0  00    00   W/B  +20.2    1.8 +10.0  +0.0 ECU.   1.3  14.92
  704  -9.2 1.3   0  00    00   W/B  +16.8    2.0 +10.0  +0.0 ECU.   1.3  15.02
  726  -8.9 1.3   0  00    00   W/B  +12.2    1.5 +10.0  +0.0 ECU.   1.2  15.02
  765  -8.9 1.3   0  00    00   W/B  +10.1    2.0 +10.0  +0.0 ECU.   1.2  14.92
  735  -8.9 1.3   0  00    00   W/B   +9.9    1.7 +10.0  +0.0 ECU.   1.2  14.83
  728  -9.2 1.3   0  00    00   W/B  +11.9    1.6 +10.0  +0.0 ECU.   1.2  14.78
  690  -9.4 1.2   0  00    00   W/B  +17.3    1.5 +10.0  +0.0 ECU.   1.3  14.78
  660  -9.4 1.3   0  00    00   W/B  +18.7    1.4 +10.0  +0.0 ECU.   1.3  14.83
  687  -9.2 1.3   0  00    00   W/B  +18.7    1.8 +10.0  +0.0 ECU.   1.3  14.83
  709  -8.9 1.3   0  00    00   W/B  +16.1    1.6 +10.0  +0.0 ECU.   1.3  14.87
  783  -8.5 1.3   0  00    00   W/B  +10.8    2.0 +10.0  +0.0 ECU.   1.2  14.92
  817  -8.7 1.3   0  00    00   W/B   +4.6    1.8 +10.0  +0.0 ECU.   1.2  14.87
  809  -8.7 1.2   0  00    00   W/B   +4.4    1.7 +10.0  +0.0 ECU.   1.2  14.78
  757  -9.2 1.2   0  00    00   W/B   +7.6    1.6 +10.0  +0.0 ECU.   1.3  14.74
  715  -9.4 1.3   0  00    00   W/B  +13.1    1.7 +10.0  +0.0 ECU.   1.3  14.74
  698  -9.4 1.3   0  00    00   W/B  +16.9    1.7 +10.0  +0.0 ECU.   1.3  14.83
  696  -9.4 1.3   0  00    00   W/B  +15.8    1.5 +10.0  +0.0 ECU.   1.3  14.92
  736  -9.2 1.3   0  00    00   W/B  +14.1    1.5 +10.0  +0.0 ECU.   1.3  14.96
  741  -9.2 1.2   0  00    00   W/B  +12.5    1.6 +10.0  +0.0 ECU.   1.2  14.96
  737  -9.2 1.2   0  00    00   W/B  +12.7    2.0 +10.0  +0.0 ECU.   1.3  14.92
  720  -9.4 1.3   0  00    00   W/B  +13.1    1.6 +10.0  +0.0 ECU.   1.3  14.92
  698  -9.4 1.3   0  00    00   W/B  +15.5    1.6 +10.0  +0.0 ECU.   1.3  14.87
  703  -9.4 1.3   0  00    00   W/B  +16.0    1.6 +10.0  +0.0 ECU.   1.3  14.83
  721  -9.2 1.3   0  00    00   W/B  +15.4    1.4 +10.0  +0.0 ECU.   1.3  14.65
  728  -9.2 1.3   0  00    00   W/B  +13.2    2.0 +10.0  +0.0 ECU.   1.3  14.65
  748  -8.9 1.3   0  00    00   W/B  +11.1    1.8 +10.0  +0.0 ECU.   1.2  14.83
  757  -9.2 1.3   0  00    00   W/B   +8.6    1.6 +10.0  +0.0 ECU.   1.2  14.78
  726  -9.2 1.3   0  00    00   W/B  +11.0    1.6 +10.0  +0.0 ECU.   1.2  14.70
  688  -9.4 1.3   0  00    00   W/B  +13.8    1.6 +10.0  +0.0 ECU.   1.2  14.65
  689  -9.4 1.3   0  00    00   W/B  +15.9    1.5 +10.0  +0.0 ECU.   1.3  14.61
  652  -9.2 1.3   0  00    00   W/B  +18.0    1.5 +10.0  +0.0 ECU.   1.3  14.61
  698  -9.2 1.3   0  00    00   W/B  +17.0    1.9 +10.0  +0.0 ECU.   1.3  14.65
  731  -8.9 1.3   0  00    00   W/B  +12.6    1.9 +10.0  +0.0 ECU.   1.3  14.83
  768  -8.7 1.3   0  00    00   W/B   +7.5    1.6 +10.0  +0.0 ECU.   1.2  14.87
  784  -8.9 1.2   0  00    00   W/B   +5.4    1.6 +10.0  +0.0 ECU.   1.2  14.74
  745  -9.2 1.2   0  00    00   W/B  +10.4    1.8 +10.0  +0.0 ECU.   1.3  14.74
  690  -9.4 1.2   0  00    00   W/B  +15.3    1.6 +10.0  +0.0 ECU.   1.3  14.74
  674  -9.4 1.3   0  00    00   W/B  +18.7    1.6 +10.0  +0.0 ECU.   1.3  14.74
  636  -9.4 1.3   0  00    00   W/B  +20.4    1.4 +10.0  +0.0 ECU.   1.3  14.78
  700  -9.2 1.3   0  00    00   W/B  +19.4    1.7 +10.0  +0.0 ECU.   1.3  14.83
  790  -8.7 1.3   0  00    00   W/B  +12.9    2.0 +10.0  +0.0 ECU.   1.3  14.83
  824  -8.7 1.2   0  00    00   W/B   +4.3    1.7 +10.0  +0.0 ECU.   1.2  14.87
  797  -8.9 1.3   0  00    00   W/B   +4.3    1.7 +10.0  +0.0 ECU.   1.3  14.83
  752  -9.2 1.3   0  00    00   W/B   +6.9    1.8 +10.0  +0.0 ECU.   1.3  14.78
  701  -9.4 1.3   0  00    00   W/B  +12.7    1.8 +10.0  +0.0 ECU.   1.3  14.78
  695  -9.4 1.3   0  00    00   W/B  +19.4    1.9 +10.0  +0.0 ECU.   1.3  14.78
  722  -9.4 1.3   0  00    00   W/B  +16.8    1.9 +10.0  +0.0 ECU.   1.3  14.78
  726  -9.2 1.3   0  00    00   W/B  +14.4    1.9 +10.0  +0.0 ECU.   1.3  14.83
  727  -9.2 1.3   0  00    00   W/B  +11.9    1.6 +10.0  +0.0 ECU.   1.2  14.78
  727  -9.2 1.3   0  00    00   W/B  +11.8    1.7 +10.0  +0.0 ECU.   1.2  14.65
  728  -9.2 1.3   0  00    00   W/B  +13.5    1.6 +10.0  +0.0 ECU.   1.2  14.58
  706  -9.4 1.2   0  00    00   W/B  +15.3    1.6 +10.0  +0.0 ECU.   1.3  14.58
  669  -9.2 1.3   0  00    00   W/B  +17.3    1.4 +10.0  +0.0 ECU.   1.3  14.58
  690  -9.2 1.3   0  00    00   W/B  +18.1    1.9 +10.0  +0.0 ECU.   1.3  14.65
  717  -8.9 1.3   0  00    00   W/B  +16.1    1.9 +10.0  +0.0 ECU.   1.3  14.74
  748  -8.7 1.3   0  00    00   W/B  +12.7    1.9 +10.0  +0.0 ECU.   1.3  14.87
  785  -8.7 1.2   0  00    00   W/B   +5.3    1.7 +10.0  +0.0 ECU.   1.2  14.92
  764  -8.9 1.2   0  00    00   W/B   +6.2    1.7 +10.0  +0.0 ECU.   1.2  14.83
  727  -9.2 1.2   0  00    00   W/B  +11.2    1.7 +10.0  +0.0 ECU.   1.3  14.83
  663  -9.4 1.3   0  00    00   W/B  +15.0    1.6 +10.0  +0.0 ECU.   1.2  14.78
  663  -9.6 1.3   0  00    00   W/B  +20.2    1.8 +10.0  +0.0 ECU.   1.3  14.78
  672  -9.4 1.3   0  00    00   W/B  +19.5    1.8 +10.0  +0.0 ECU.   1.3  14.83
  741  -8.9 1.3   0  00    00   W/B  +14.3    1.7 +10.0  +0.0 ECU.   1.3  14.92
  789  -8.9 1.3   0  00    00   W/B   +7.9    1.7 +10.0  +0.0 ECU.   1.3  14.92
  818  -8.7 1.2   0  00    00   W/B   +4.3    1.7 +10.0  +0.0 ECU.   1.2  14.92
  778  -9.2 1.2   0  00    00   W/B   +5.8    1.3 +10.0  +0.0 ECU.   1.2  14.92
  716  -9.4 1.3   0  00    00   W/B  +12.1    1.7 +10.0  +0.0 ECU.   1.3  14.83
  674  -9.6 1.3   0  00    00   W/B  +16.4    1.4 +10.0  +0.0 ECU.   1.3  14.83
  647  -9.4 1.3   0  00    00   W/B  +20.7    1.4 +10.0  +0.0 ECU.   1.3  14.78
  680  -9.2 1.3   0  00    00   W/B  +20.0    1.7 +10.0  +0.0 ECU.   1.3  14.74
  728  -8.9 1.3   0  00    00   W/B  +19.0    1.4 +10.0  +0.0 ECU.   1.3  14.74
  794  -8.7 1.3   0  00    00   W/B   +5.7    1.5 +10.0  +0.0 ECU.   1.2  14.74
  811  -8.7 1.2   0  00    00   W/B   +4.3    1.9 +10.0  +0.0 ECU.   1.2  14.65
  777  -8.9 1.2   0  00    00   W/B   +4.9    1.9 +10.0  +0.0 ECU.   1.3  14.65
  727  -9.2 1.3   0  00    00   W/B  +13.8    1.8 +10.0  +0.0 ECU.   1.3  14.65
  703  -9.4 1.3   0  00    00   W/B  +17.4    1.6 +10.0  +0.0 ECU.   1.3  14.74
  699  -9.4 1.3   0  00    00   W/B  +16.9    1.5 +10.0  +0.0 ECU.   1.3  14.74
  704  -9.2 1.3   0  00    00   W/B  +15.4    1.6 +10.0  +0.0 ECU.   1.2  14.74
  749  -9.2 1.3   0  00    00   W/B  +13.6    2.0 +10.0  +0.0 ECU.   1.2  14.74
  759  -9.2 1.2   0  00    00   W/B  +10.9    1.6 +10.0  +0.0 ECU.   1.2  14.78
  750  -9.2 1.2   0  00    00   W/B  +11.0    2.1 +10.0  +0.0 ECU.   1.2  14.74
  724  -9.4 1.2   0  00    00   W/B  +13.6    1.7 +10.0  +0.0 ECU.   1.2  14.65
  697  -9.4 1.2   0  00    00   W/B  +15.2    1.4 +10.0  +0.0 ECU.   1.3  14.65
  691  -9.4 1.3   0  00    00   W/B  +17.3    1.9 +10.0  +0.0 ECU.   1.3  14.74
  690  -9.2 1.3   0  00    00   W/B  +18.7    1.5 +10.0  +0.0 ECU.   1.3  14.78
  687  -8.9 1.3   0  00    00   W/B  +15.5    1.8 +10.0  +0.0 ECU.   1.3  14.83
  738  -8.9 1.3   0  00    00   W/B  +13.3    2.0 +10.0  +0.0 ECU.   1.3  14.83
  776  -8.7 1.2   0  00    00   W/B   +8.2    2.1 +10.0  +0.0 ECU.   1.2  14.83
  769  -8.9 1.2   0  00    00   W/B   +6.2    1.8 +10.0  +0.0 ECU.   1.2  14.74
  719  -9.2 1.3   0  00    00   W/B  +13.1    1.7 +10.0  +0.0 ECU.   1.2  14.70
Old 02-25-2005, 10:29 PM   #14
el~sharko
Member#: 29735
2011 JSW TDI - DSG
2008 EVO X MR
did you figure this out? my utec logs look almost identical to yours only it does this on my tuned maps. I can't stablize the timing or vacuum at idle.
el~sharko is offline   Reply With Quote
Old 02-25-2005, 10:50 PM   #15
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
No, I emailed two people at TXS, no response at all. I have been too busy with work and stuff to play with my toys so I havent persued it any further, but I will.
Old 02-26-2005, 05:10 AM   #16
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Hmm thats weird.. i cant see whats making it go wrong. The ignition timing even though it might not be the cause of the bad idling once it gets going it probably adds to whatever it is. Its going low then high then low then high like its overcorrecting..
PaulRex is offline   Reply With Quote
Old 02-27-2005, 08:39 AM   #17
el~sharko
Member#: 29735
2011 JSW TDI - DSG
2008 EVO X MR
Like I said, I am having a very similar problem, but I have modded injectors. This is also after a custom turboxs tune, which they could not solve. I have one last variable that I have troubleshot which is swapping to different injectors. If santo is on the stock injectors, then I am completely clueless. I feel like I keep hijacking threads on thsi subject, but I have been unsuccessful finding any closure on these problems. Most of these threads end without someone posting what actually solved their problem. So, santo please keep us up to date.
Old 02-27-2005, 11:47 AM   #18
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
Will do....and i am still on stock injectors.
Utec Delta valet mode ???? awd-box-turbo UTEC 9 07-22-2008 12:49 PM
getting out of valet mode with no key fob???? dstnbmxvr6 Car Audio, Video & Security 1 04-18-2008 02:48 PM
UTEC valet mode bluebaru wrx Engine Management & Tuning 26 09-21-2004 02:05 AM
make sure its not in valet mode bahboy20 Car Audio, Video & Security 3 08-16-2001 01:46 PM
Security System stuck in Valet Mode??? cincyRS Technical Forum Archive 2 07-21-2000 09:24 AM
