Old 01-08-2005, 05:45 PM   #1
Ireneusz
Member#: 34464
1994 GC8STI /FXTSTI
426whp aspen / 340whp psm
Question OBodII Code P1491 Help
Hey guys
Im in final stage of my swap car runs is just the engine light is on
i check it and it it showed Error P1491 and P1446 after reset the P1446 went away and the first one is on and dont want to go away I checked all vacum hoses I already have up and down pipe on with 3inch Exshaust and front mount could any of these mods cause that i also have home made cell fix that seem to work. I dont get cell for cat.
The question is did anyone have P1491 code pop on their car if so what could be the solution ?
Please help
Ireneusz is offline   Reply With Quote
Old 01-08-2005, 07:46 PM   #2
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
There is a list of CEL codes on here. The 1446 I believe is for the probe that is in the up-pipe so if it's not there you'll need to put in a resistor.
Z
Zephyr is offline   Reply With Quote
Old 01-08-2005, 10:41 PM   #3
Ireneusz
Member#: 34464
1994 GC8STI /FXTSTI
Default OBDII Error
Hello
Thanks for reply but that code (P1446) already cleared and don't seem to be problem anymore,it jus the other one the P1491 is still the problem and I can't figure it out what cause it.
Thanks
Old 01-09-2005, 06:23 PM   #4
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
p1491: crank case blow by. check the sensor, if its there, if its disconected, or if your getting blowby
edit: oh, yeah, we need more info on the conditions, like what swap and such, you needed that from the beggining
Hurley 2.5 WRS is offline   Reply With Quote
Old 01-11-2005, 02:22 AM   #5
Ireneusz
Member#: 34464
1994 GC8STI /FXTSTI
Default OBDII P1491 and P1446
Chcked the valve and it's attached and seem to be fine I also looked around for the loose vacuum ,but nothing soom to be disconected.
As for the mods and my swap
2004 WRX engine and tranny
invida header,up pipe,down pipe,and exshaust 3"
Utec,stg2
Right now stock turbo
stock injectors,stk fuell raill
walbro fuell pump
Turboxs fmic,turboxs bow RFL,turboxs short ram intake
GFB light crank Pulley
Home made cell fix
1meg Ohm resistor and 1micro farad capacitor (as for the cell fix)
I think thats all
Everything seem to be fine except the two codes.
Has anyone have any sugestions or ideas how to get rid of these codes
maybe the resistors would work but where to install them.
Thank you guys
Old 01-11-2005, 04:03 AM   #6
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
on 04 Rex's, there is a sensor that detects if you have blow by (gasses passing the piston rings). this is what your code means. i believe you either have blow by or a bad/missing/disconnected sensor
Old 01-11-2005, 06:48 PM   #7
Ireneusz
Member#: 34464
1994 GC8STI /FXTSTI
Default Obdii Error P1491,p1446
Hello
Thanks for info
Sorry to ask but what exactly mean blow by?
Is it that some vacuum leak or something?
Thanks a lot
Old 01-12-2005, 08:42 PM   #8
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
SEARCH, you will find your problem.
http://forums.nasioc.com/forums/show...ighlight=p1491
Code P1491 Javwrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 05-28-2008 10:08 PM
****need Help With Cel Codes-please Help************** stito Subaru Conversions 4 07-29-2007 04:55 AM
244 code please help FuZZyLoGiC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 12-17-2006 10:32 PM
code pullers help please. christoph1371 Bay Area Impreza Club Forum -- BAIC 5 02-05-2002 03:02 PM
The dealer pulled this code today.......help Aaron'z 2.5RS Normally Aspirated Powertrain 23 11-22-2001 08:39 PM
