Old 01-08-2005, 06:29 PM   #1
Ireneusz
Member#: 34464
1994 GC8STI /FXTSTI
426whp aspen / 340whp psm
Default Turboxs FMIC Question
Hello
I just installed Turboxs FMIC and after starting up the car hesitates at idle
has anyone had that problem?
I was thinking if UTEC can solve that problem or its somthing that is caused by stock turbo right now.
Has anyone had something like that ohh i have 2004 wrx motor on my 2000 rs
Thanks alot
Ireneusz is offline   Reply With Quote
Old 01-09-2005, 09:57 PM   #2
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Check for leaks first off. Is it holding boost like before? Was the installation bolt on, or did you have to bend, cut, modify, shave, etc. anything? Thanks.
garface is offline   Reply With Quote
Old 01-10-2005, 11:50 AM   #3
Ireneusz
Member#: 34464
1994 GC8STI /FXTSTI
Hey thanks for response
The installation was pretty much bolt on except the front intercooler piping was 2.25 inch to long so i had tu cut and then clamp it with silicone hose besides that everything bolt right on.
Do you think that if total lenght of the piping is 5inch shorter would create hesitation?
I already checked for leaks and seem to be ok.
Thanks for response
Old 01-10-2005, 12:32 PM   #4
garface
Member#: 1581
MY00 RS/STi7
Do you have a BOV now and before you installed the FMIC? Where did you cut it?
Old 01-10-2005, 12:36 PM   #5
2superblus
Member#: 33526
2013 WRB W/Gold BRZ
08 STI WRB w/Gold, 02 WRX
put washers in the bov, at least 3
2superblus is offline   Reply With Quote
Old 01-10-2005, 03:54 PM   #6
Ireneusz
Member#: 34464
1994 GC8STI /FXTSTI
Hey
I had to cut the pipes both sides,you know the inlet to intercooler and outlet
both sides 2.25 inch before the 90deg angle to fmic and on the 90deg angle from fmic and conect it with silicone hose from both sides.
Do you think the pipes that i cut made them shorter could cause that.
Thats preety weird if it did.
The wrx's front is little longer thats why i needed to shorten them to fit on to fmic.
As for the bow right now i have 5 washers.Maybe there are to many washers in bow?
I will check tonight and see what happen.
Thanks for help i will try that
Old 01-10-2005, 04:29 PM   #7
garface
Member#: 1581
MY00 RS/STi7
Oh no, I was just askin about the cutting because I'm going to be installing a WRX front mount on my GC soon. The bov or a leak are the only things I can think of. But if you do a search I'm pretty sure a lot of people have issues with front mounts and idling. You have a turbo'd RS engine or WRX swap?
Old 01-10-2005, 06:24 PM   #8
wrx plus
Member#: 42253
2003 RWD WRX
Alcohol injected, WRB
I started with 6 washers and ended with 12 gold dollars in the BOV at 18Lbs of boost. The spring is very weak, keep on putting washers until the whistle at full boost stops.
wrx plus is offline   Reply With Quote
Old 01-11-2005, 02:12 AM   #9
Ireneusz
Member#: 34464
1994 GC8STI /FXTSTI
Hey problem solved no hesitation car runs smoooooth.
I added 6 washers and the tiny leak stoped also 1 fmic clamp wasn't tight so with higher boost leaked little .
all that made car hesitate.
Now the OBDII problem cell is on it comes up as P1446 and P1491
The scanner shows both as (auxuary emission input fault)
Any idea what that could be.
Thanks
Old 01-26-2005, 01:47 PM   #10
el~sharko
Member#: 29735
2011 JSW TDI - DSG
2008 EVO X MR
Thanks
so you have 11 washers in the bov now, and the idle issues went away? I was having this same problem. I had about 10 quarters in the bov, which didn't completely solve the idle problem, but it wouldn't open on throttle lift causing surge. I still have the idle proble, but I've pretty much ruled out the bov as the problem.
el~sharko is offline   Reply With Quote
quick question on turboxs fmic! chrisc75 Water/Methanol Injection, Nitrous & Intercooler Cooling 8 05-01-2009 12:45 AM
turboxs fmic install on 06/07 question BrooklynSTi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 10-20-2007 03:55 PM
TurboXS FMIC Question (Bumper Beam) Andrew Water/Methanol Injection, Nitrous & Intercooler Cooling 1 03-15-2007 11:19 PM
So i got my TurboXS Fmic kit today...here is some pics w/questions. BoostedAWD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-08-2004 10:33 PM
New TurboXS FMIC question thatdmgud Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 09-29-2004 08:04 PM
