Old 01-08-2005, 07:39 PM   #1
MF-DIF
Member#: 62197
Default Cobb STG 2 + downpipe only...results?
What type of performance gains will I see with running AP Stg. 2 w/ DP only? I can't image it being the same as Stg. 2 w/ full TBE (approx 225whp). What kind of numbers would I typically be seeing...210whp would be my best guestimate.
Also, can I expect the same safty as the Stg 2 w/ TBE running just a DP or is the map too aggressive, causing some potential problem down the road?
MF-DIF is offline   Reply With Quote
Old 01-08-2005, 07:57 PM   #2
Chigliakus
Member#: 77525
'02 GDA, PSM
'93 FD, Red
There's plenty of info on this if you search, I know I've commented on running Cobb stage2 with Cobb dp and stock cat-back in a number of threads...
The general consensus seems to be about 10 hp lost if you use the stock cat-back with a full dp (no cats, or a high-flow cat). Maybe a greater loss with a stock 3rd cat. I doubt it's going to cause problems for you, you'll just be a little slower and lack the wonderful deep boxer rumble that a full tbe will give you.
Chigliakus is offline   Reply With Quote
Old 01-08-2005, 10:57 PM   #3
MF-DIF
Member#: 62197
^I did a search for this but it turned a lot of threads that didn't really pertain to the question I had. I think the terms downpipe & cobb are used way to much to narrow down an effective search.
Thanks for answering my questions though. Just trying to make an educated decision on meh mods.
Old 01-08-2005, 11:56 PM   #4
BigJ04STi
Member#: 77239
2004 Impreza WRX
None
Why just a DP?
The reason I ask, is cause ypu can easily make a more optimal Turbo back with little sound if you'd like...
Check out daddysscp.com
Look at the 3" divorced DP w/ cat, and 3rd cat eliminator...this gives you 3" piping back to the cat, then ti tapers to 2.5" for a stock style cat back...
Also they have an option for a 3" mid section, that again will taper to 2.5" to connect to a 2.5" axle back. This would give you better exhaust flow, without a loud set up, and allow for bigger hp gains.
Of course if sound is not an issue, and it's money or some other issue...This won't help...
Just an idea though...
BigJ04STi is offline   Reply With Quote
Old 01-09-2005, 12:10 PM   #5
MF-DIF
Member#: 62197
^You hit it on the head with the money thing. I can always go full tbe later, but for now....$600 AP + $210 ERZ DP+UP...pretty good start & bang for the buck.
Cobb Stg 2 with DP only... Safe or Not??? stusha AccessPort 17 08-17-2008 05:55 PM
Need some clarification on downpipes and Cobbs Stg 2 Jsun Newbies & FAQs 8 06-24-2008 09:59 PM
Cobb Stg 2 w/DP only mommawagon AccessPort 14 07-01-2006 09:49 AM
Cobb stg 2 STi Protuned by HM Results SubyFi Proven Power Bragging 37 04-08-2006 01:12 AM
Cobb Stg 2 STI = WOW! (no bad results here) StealthWagon Engine Management & Tuning 5 06-12-2004 11:56 AM
Message Board Statistics All times are GMT -4. The time now is 09:50 AM.
