Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 01-08-2005, 07:52 PM   #1
Supaboom
Member#: 38755
2004 WRX
Default cobb stage 2 owners, is a EGT gauge a must?
I was curious to know those of you who are running a cobb stage 2 93 flash, can you run it without a egt gauge? i know its smart to have, but can it be put off till later down the road?
TIA!
Supaboom is offline   Reply With Quote
Old 01-08-2005, 07:59 PM   #2
Chigliakus
Member#: 77525
'02 GDA, '09 GR
'93 FD
I don't run an egt, and I probably won't get one. I'm just going to go straight to a wideband, probably with some kind of datalogging capability. There's already a bung in my Cobb dp just waiting for it.
Chigliakus is offline   Reply With Quote
Old 01-08-2005, 09:15 PM   #3
Supaboom
Member#: 38755
2004 WRX
yeah i got the same downpipe and was thinking of alternative setups (i.e. getting a wideband 02) thanks for the help
Old 01-08-2005, 11:11 PM   #4
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
07 STI 6-Speed Goodness!
Yeah, but ya might end up like this:
That my friends is why you use an EGT gauge when upgrading your car's performance...especially if you are using a TBE.
ScoobyNubieToo! is offline   Reply With Quote
Old 01-08-2005, 11:34 PM   #5
wrx05
Member#: 69032
2005 Legacy GT
Obsidian Black
Nice photochop..
wrx05 is offline   Reply With Quote
Old 01-09-2005, 01:02 AM   #6
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
Originally Posted by wrx05
Nice photochop..
It's not...I took it from another thread (unless they photochopped it)
Old 01-09-2005, 01:03 AM   #7
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
Old 01-09-2005, 10:02 AM   #8
crazymikie
Member#: 56321
2006 Honda El Camino
Green
Even though it is 'off-the-shelf' engine management, I'd highly recommend running a basic set of gauges (EGT, Boost and Oil Pressure or Temp).
I've seen several threads where people have talked about high EGTs with Cobb reflashes. Even if the root cause isn't the reflash, it's a cheap insurance policy.
Mike
crazymikie is offline   Reply With Quote
Old 01-09-2005, 01:32 PM   #9
Supaboom
Member#: 38755
2004 WRX
yeah i'm looking to get a borla header and have a egt bung welded in that rather than my stocker.
my question then is this, say you are running high egts and lets say you are crusing at 70mph on the highway, what can be done at that moment to help things out? I guess what I"m wondering is yeah the gauge will tell you whats going on, but how should someone react to help remedy the situation and bring those temps down? Would downshifting help to maybe get out of boost, and what if its not even in boost, just vacuum, what shoudl someone do next?
thanks for your help everyone, i appreciate it
Old 01-09-2005, 02:03 PM   #10
84SubaruDL
Member#: 42179
SON! F 22's i roll
on 33" 12 fity SON!!!
in my opinion, for the street, i think you should get an egt guage, its a good idea when you adjust boost levels above factory settings.
84SubaruDL is offline   Reply With Quote
Old 01-09-2005, 11:15 PM   #11
Gonz
Member#: 18642
2005 Impreza WRX STi
You shouldn't see high EGT's just cruising, but if you did let off the gas/slow down.
I see High EGT's with the accessport in certain situations. Full throttle for a long time (on the track), and especially pulling up a long uphill grade in 5th gear.
New versions of the Stage II map really helped with this, but I'd say it is still critical to have an EGT gauge or avoid certain situations like those above.
Gonz is offline   Reply With Quote
Cobb Stage 2 Owners..EGT changes after flashing? super laubo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-23-2007 04:24 PM
Attention all Cobb stage 2.5 owners, must read! scooby1220 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-29-2007 11:58 PM
going cobb stage 2 but dont want egt gauge? RobSub Engine Management & Tuning 15 11-08-2005 03:54 PM
Any cobb stage 2 owners...yet? kinger Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 06-09-2004 09:58 PM
cobb stage 2 owners, how many have lost boost with headers? wrxracer55 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 03-08-2004 03:29 AM
