Old 01-08-2005, 08:34 PM   #1
JakeInKY
Member#: 77180
Default ECUs for STI Engine swaps
I was wondering what ECUs you all are using on 2.0L STi and Spec-C engines? I am hoping to get a V7 or V8 RA Spec-C engine to swap into my 02 WRX sometime this year. I want to retain the AVCS system, but am looking for an aftermarket ECU so that I can have better tuning options. Right now, I am thinking about using the Stock ECU for AVCS and using a TEC-III for the rest of the engine management and ignition. That setup is kinda pricey though, and I am not quite sure if the TEC is really as good as the advertising makes it seem.
JakeInKY is offline   Reply With Quote
Old 01-08-2005, 11:04 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
use the stock ecu and add the avcs "kit"
Old 01-08-2005, 11:29 PM   #3
Scoobie Steve
Member#: 2289
1998 [email protected]
Subaru L Ver 6 STi Type R
There are NO ecu's better then factory. Dont get a Tec 3, just flash the factory ecu. Doing that will save you many sleepless nights
Scoobie Steve is offline   Reply With Quote
Old 01-09-2005, 12:52 PM   #4
2pt5RS
Member#: 10853
2013 BRZ LTD
Satin White Pearl
Or, use a Hydra.
2pt5RS is offline   Reply With Quote
Old 01-10-2005, 12:14 AM   #5
joubtt
Member#: 33901
04 04 STI
No AWD, Not interested
Impreza GC8
Factory.
joubtt is offline   Reply With Quote
2 More Element ECUs for STi including 05 model in STOCK! WorldOne Engine/Power/Exhaust 1 03-07-2005 06:06 PM
2 different ECUs for STIs? hatchy STi Forum Archive 7 08-16-2003 12:17 AM
US STi engine swap question? garface Normally Aspirated with bolt-on Forced Induction Powertrain 6 09-17-2001 03:49 PM
STI engine swap... MINDGAME Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-20-2001 03:29 PM
('93-'01) Help: Sti Engine Swap gotawd11 Impreza Forum 23 07-02-2001 02:06 AM
