Old 01-08-2005, 09:00 PM   #1
snowjob
Member#: 59357
2009 Forester XT
Default My fans wont' shut off after swap
I'm hoping somebody can help me, I just did an ej20g swap into a 91 Legacy Turbo. After wiring it and getting it started the radiator fans won't stop, Here's the problem: when I turn the key on, the fans(both of them) turn on and stay on, even if the engine is running or not. Have I wired something wrong here?? EJ20 is from a 89-91 Liberty with a silver airwater intercooler.
Any help to get things back to normal would be appreciated.
Thanks
Frazer
snowjob is offline   Reply With Quote
Old 01-08-2005, 11:21 PM   #2
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
I believe there is a test connector that when connected will keep the fans on all the time...
Old 01-09-2005, 12:51 PM   #3
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Yeah if the test connectors are connected the radiator fans will stay on all the time.
However if the connector is not connected, it could be the wiring from the coolant temp sensor, or possibly the coolant temp sensor itself.
Honestly, it could be a number of things. How did you wire everything up for the swap?
Legacy777 is offline   Reply With Quote
Old 01-09-2005, 05:44 PM   #4
Mumbles
Member#: 248
Check the wiring at the relay. I know the RS's use a ground to turn the relay on. The ecu should be telling the fans when to turn on. If your fans are on after the car is off, then yes the check connectors or you put that ground static.
Mumbles is offline   Reply With Quote
Old 01-09-2005, 08:24 PM   #5
snowjob
Member#: 59357
2009 Forester XT
When you guys talk about the test connector, are you talking about the check ecu conectors? These are not connected, are their another set?
Old 01-09-2005, 09:19 PM   #6
Diz
Member#: 874
2015 WRX STI
2004 Mazdaspeed MX-5
Also check the speed sensor. I think the car will engage the fans if it thinks it's moving above a certain speed.
Diz is offline   Reply With Quote
Old 01-09-2005, 10:37 PM   #7
Legacy777
Member#: 4800
Yes, the check connectors, green & black ones
http://www.main.experiencetherave.co...es/ecuhide.jpg
Diz, the ECU won't engage the fans if it's going above a certain speed. It will however turn the fans on if it doesn't get a signal from the speed sensor.
Old 01-16-2005, 08:07 PM   #8
snowjob
Member#: 59357
2009 Forester XT
Thanks for the responces, but the connectors are not the answer, I've just spend the better part of a very frustrating day trying to figure things out.
Here is what I know for sure
1.I turn the key to the On position and the fans come on and don't shut off. I've pulled the pin for the fans on the ecu and they stop, so I know the ecu is telling the fans to turn on. So lets go back from thier, What would tell the ecu to turn the fans on? coolant sensor?
Old 01-16-2005, 08:11 PM   #9
snowjob
Member#: 59357
2009 Forester XT
1. I turn the key to the On position and the fans come on and don't shut off. I've pulled the pin for the fans on the ecu and they stop, so I know the ecu is telling the fans to turn on. So lets go back from thier, What would tell the ecu to turn the fans on? coolant sensor?
2. The ecu is throwing an Atmospheric pressure sensor and MAF sensor malfunction.
The maf, I think is faulty, i'll swap it with my spare, but I don't know what or where the Atmospheric pressure sensor is, any help with any of these three would be great.
Thanks Everyone.
Old 01-16-2005, 08:54 PM   #10
Mumbles
Member#: 248
Do a search under my name in the conversion forums only, lots of info in those threads.
Old 01-16-2005, 10:21 PM   #11
snowjob
Member#: 59357
2009 Forester XT
Good Posts Mumbles, but I've got the oposite problem, and my comp is an ob1 setup. Good info though.
Old 01-16-2005, 11:00 PM   #12
Mumbles
Member#: 248
Yeah but i outlined the 3 things that tell the ecu what's up. Air Intake Temps, speed sensor and coolant temp sensor. Sounds also to me like you grounded the test wires... that's exactly what happens when you ground those wires.
Old 01-17-2005, 09:13 AM   #13
snowjob
Member#: 59357
2009 Forester XT
Ok, this might make sence, I'm getting a Mass air flow sensor error, I'll try and replace it and see where I get.
Thanks, i'll keep you posted.
Frazer
Old 01-17-2005, 01:31 PM   #14
Legacy777
Member#: 4800
OBD1 does not have intake air temp sensor.
I'd try replacing the maf and see what happens.
As for the atmospheric sensor, it's in the ECU, and cannot be replaced separately.
Old 01-22-2005, 04:58 PM   #15
snowjob
Member#: 59357
2009 Forester XT
Ok, here's the update, I replaced the MAF sensor and am still throwing a code for it, not quite sure why, but I think I may have wired the coolant sensor incorrectly, On the coolant rail where the sensor sits, their are two sensors, one has two wires entering it and the other has just one that is cliped on to it. Which one is the coolant sensor that goes to the ECU?? and second question, how can I tell if they are working correctly?
Thanks for any responces.
Frazer
Old 01-23-2005, 05:47 PM   #16
Legacy777
Member#: 4800
The two wire sensor goes to the ECU. The one wire sensor goes to the dash temp gauge.
How did you wire the coolant temp sensor? Is the ECU coolant temp sensor new or used?
You can measure the resistance across the two pins on the sensor. It will change depending on the temperature it reads. If you're in doubt about the condition, I'd just get a new one. They're like 20 bucks at www.subaruparts.com
Old 01-24-2005, 08:37 AM   #17
snowjob
Member#: 59357
2009 Forester XT
When I did the swap I just repined the engine to ECU so that I could use the plugs from the engine to the chassis. The sensor is used, I didn't change it with the engine.
their are two wires coming from the sensor, does one go to the ecu and the other one is grounded? or do they both go to the ecu? I'm an electrical NOOBY and proud of it!!
Thanks
Frazer
Old 01-24-2005, 10:07 AM   #18
Legacy777
Member#: 4800
Both pins go to the ECU. Since the sensor is a resistive type element, a voltage signal is sent to one pin of the sensor, and changes voltage across the sensor. That changed voltage is read by the ECU, and determines the engine's temp.
Old 01-24-2005, 10:22 AM   #19
snowjob
Member#: 59357
2009 Forester XT
I don't supose you know the pins ## do you?
Old 01-24-2005, 11:29 AM   #20
Sperm
Member#: 25038
2002 PSM WRX sedan
One time I burned the wires to my Coolant sensor to the point where it was completely screwed and my fans would not stop either. It's the sensor right above the belt cover\alternator area. It kinda sticks out from in between the intake manifolds. I'd check that if you haven't already. Maybe its a bad sensor. I know for a fact that this sensor failing WILL cause the fans to run non-stop.
Hope it helps!
Sperm is offline   Reply With Quote
Old 01-24-2005, 01:42 PM   #21
snowjob
Member#: 59357
2009 Forester XT
Default check out the photo
check out http://photos.yahoo.com/educateabroad
I've put an arrow to the three sensors, I think your talking about number 3, if so, then this might make sence, the wire going to this sensor spit and I had to resolder it. Hmmm.
Old 01-24-2005, 09:22 PM   #22
Legacy777
Member#: 4800
Check out these pics.
http://www.main.experiencetherave.co...ges/injectors/
The sensor JSpych is sounding like he's talking about is the oil pressure sensor.
Coolant temp sensor is here
http://www.main.experiencetherave.co...s/DCP_2477.JPG
As for the ECU pinouts, this should help
http://www.main.experiencetherave.co..._I-O_page1.jpg
http://www.main.experiencetherave.co..._I-O_page2.jpg
http://www.main.experiencetherave.co..._I-O_page3.jpg
FAQ of the century: Why won't my parking lights shut off? munkis Electrical & Lighting 115 05-26-2015 12:06 AM
hid's shut off after 5 minutes pmartell12 Electrical & Lighting 5 09-16-2006 09:44 PM
Engine shut off after startup freds88 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 02-02-2005 05:06 PM
Strange problem: my tailights won't shut off. imprezive Electrical & Lighting 7 03-06-2004 11:21 PM
