Old 01-08-2005, 09:18 PM   #1
BMWWRX
Member#: 79079
2004 WRX
WR Blue
Default ECU Reset
What exactly does an ECU reset do? I had my ECU reflashed by ECUTEK, if I do the reset will my ECU revert to its stock settings, causing me to lose my 600 dollars worth of tuning?
BMWWRX is offline   Reply With Quote
Old 01-08-2005, 09:23 PM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
A ECU reset will just cause the ECU to revert back to the base maps that were flashed onto it via Ecutek. You will just lose all the learning that the ECU had done. After driving around for a bit, the ECU will relearn and you'll be fine.
Calvin
cnk is offline   Reply With Quote
Old 01-08-2005, 09:35 PM   #3
BMWWRX
Member#: 79079
2004 WRX
WR Blue
Default RE: ECU Reset
Thanks, how long does it usually take to relearn stuff. For example I just got a B&B catless uppipe installed, would it be worth reseting my ECU?
Old 01-08-2005, 09:37 PM   #4
cnk
Member#: 10757
It usually takes a few hundred miles. . .just drive around and you'll be fine. As for the uppipe, it really doesn't matter since it will adapt to the UP either way. Most people reset their ECU's anyways, which sucks if you don't have a way to do it without disconnecting the battery as you have to reprogram your clock and radio.
Calvin
Keyless entry- reset after ECU reset? sir_aspen_white Electrical & Lighting 1 04-22-2003 08:24 PM
('93-'01) Does an ECU reset change the way an auto tranny shifts? subymamma Impreza Forum 14 05-18-2001 11:44 AM
('93-'01) ECU reset? littleblue Impreza Forum 3 05-04-2001 01:00 AM
('93-'01) ECU reset causing me to run RICH ? bigbird Impreza Forum 5 04-10-2001 10:53 PM
ECU reset for '99 Liberty Andy_T Legacy Forum 0 01-23-2000 06:29 PM
