Old 09-30-2004, 06:56 PM   #1
dreaminsubys
Member#: 71579
1998 Legacy Outback
Question rear main seal 1998 2.5L
Does anyone know where I can find a seal driver big enough to put in the rear main seal on my 1998 Outback. The diameter of the seal is 3 3/4 inches. I've been able to track down the right tools for almost ever other part of my current head gasket replacement project excet this. Any help will be greatly appreciated.
Pete
dreaminsubys is offline   Reply With Quote
Old 09-30-2004, 09:01 PM   #2
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Try starting the seal in there and then putting the flywheel on and snug up the bolts. Pull the flywheel back off and you should be able to "install" it in a little further with a 3/8 extention and light taps with a mallet. I had a bear of a time on an sti and decided to try this. It worked very well.
Tim Sanderson is offline   Reply With Quote
Old 10-08-2004, 11:22 AM   #3
Member#: 47261
he's exactly right... any decent clutch change guide will tell you to change the rear main seal while you are in there. I did exactly what Tim says to do... works like a charm.
soccer_freak_m@hotma is offline   Reply With Quote
Old 03-25-2006, 03:56 AM   #4
skunkfifty
Member#: 73102
1998 legacy outback
white
hate to dig up and old thread , but im also doing this on a 98 2.5L and wanted to know how far in should the seal be installed? just past flush with the back of the engine? as far as it will go?
what subarus spec on that? .734niner mm past flush? my fancy caliper will measure that depth, don't tempt me to use it. what happens if it's installed too deep? a leak would be my guess, or nothing at all?
skunkfifty is offline   Reply With Quote
Old 03-25-2006, 10:00 AM   #5
skunkfifty
Member#: 73102
1998 legacy outback
white
im doing this today, a fast answer would be helpful please.
Old 03-27-2006, 02:14 AM   #6
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Outside flush. Too far and you cover an oil drain hole and it may leak. Check the snout of the flywheel for wear and/or oil residue. If you have oil residue then clean it out. If the old oil seal wore a grove then you could install in a little deeper. A thin film of sealant around the outside of the seal is good peace of mind.
Good luck.
rear main seal help Imprezanize Normally Aspirated Powertrain 11 02-24-2005 02:36 AM
Installing a clutch? Why not throw in a new rear main seal. Tim Sanderson Transmission (AT/MT) & Driveline 0 07-08-2004 10:02 AM
rear main seal mybluesubi Service & Maintenance 11 02-09-2004 06:28 PM
rear main seal replacement?+ flywheel and pressure plate bolt torque? Haase14 Transmission (AT/MT) & Driveline 7 01-17-2003 10:42 AM
('93-'01) Rear main seal gone - 650kms? Help! JNaubur Impreza Forum 6 05-25-2001 12:29 AM
