Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 01-09-2005, 04:46 AM   #1
pico
Member#: 5254
01 WRX
Default Battery died after 2 weeks...
hi, I left my WRX in garage for 2 weeks during the holiday and the battery dies when i came back. i jump start it and drive for half an hour, i was able to restart it but it died again the other day. It looks like the fluid level inside the battery is low, should add water to it? how? or should i just get a new battery?
thanks
pico is offline   Reply With Quote
Old 01-09-2005, 08:40 AM   #2
file_id
Member#: 28197
2003 WRX w/ VF34
You want to put in distilled water.
file_id is offline   Reply With Quote
Old 01-09-2005, 10:06 AM   #3
Karl
Member#: 13110
If you don't have access to conc sulphuric acid, put distilled water in it.
Then you want to charge the battery back up and then get it tested.
Karl is offline   Reply With Quote
Old 01-09-2005, 12:04 PM   #4
wrx05
Member#: 69032
2005 Legacy GT
Obsidian Black
Its time for a new battery..go for a red top optima. You got almost 4 years out of that battery. Id be happy with that. I just replaced my 4 month old oem battery for a Optima. I was having cold start issues.
wrx05 is offline   Reply With Quote
Old 01-09-2005, 12:22 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Get a new battery.
Old 01-09-2005, 12:30 PM   #6
wrxinsc
Member#: 21343
2002 WRX Wagon
Decepticon #2
Aren't the factory batteries maintenance free anyhoo? Mine died after a two week vacation also and I replaced it with an Optima as well.
wrxinsc is offline   Reply With Quote
Old 01-09-2005, 12:35 PM   #7
OneOBS
Member#: 63076
2004 Outback Sport
Red!
No, they are not. Maybe that's why so many die. People aren't used to taking care of them.
OneOBS is offline   Reply With Quote
Old 01-09-2005, 03:41 PM   #8
pico
Member#: 5254
01 WRX
thanks, i guess i will try distilled water first and if it doesnt work i will get a optima.
thanks guys, at least i know i'm not the only one having trouble with the battery. my wife's camry's battery lasted 5years with no problem....
Old 01-09-2005, 04:41 PM   #9
tooocool49723
Member#: 67127
3.3 I <3/h8 my GF3
1.8-2.5-2.2-2.5-2.2-3.3
Mine did the same thing (died) except it was overnight. (too cold for it). I have since re-filled it w/ distilled, and it starts like a champ.
But I will get an optima when funding presents itself.
tooocool49723 is offline   Reply With Quote
Old 01-09-2005, 04:42 PM   #10
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
you should charge it fully with a battery charger too, not only will your alternator struggle to charge a dead battery, but if the battery's no good it could damage the alternator. Subaru batteries are maintence batterys, so adding water is fine, as was said earlier.
check out the new optima 51r, only 26 lbs. I will be getting one of these soon.
http://lib1.store.vip.sc5.yahoo.com/...opcopo51r.html
00Maddog is offline   Reply With Quote
Old 01-09-2005, 04:44 PM   #11
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If you're planning to keep (or at least try to rejuvenate) the OEM battery, go to the parts store and buy a battery tester (hydrometer), they are cheap. You can then use it to check the state of charge in the individual cells at any time, and especially while charging to see if the battery is taking a charge. You can also tell if any individual cells are weak or NG.
Old 01-09-2005, 11:51 PM   #12
pico
Member#: 5254
01 WRX
so, can anybody recommend a good battery charger for me please?
thanks
Old 01-10-2005, 12:12 AM   #13
Uncle Scotty
Member#: 16200
OK buy Nates beans
...no....a new battery would be about the same price and you really do need a new battey....if a battery won't hold a charge, like yours didn't....it's toast.....buy a new battery.
Old 01-10-2005, 12:43 AM   #14
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
Get a new battery. Possibly even a braille lightweight battery since here in california we don't get snow (except for the mountains).
Maintenance free is a misnomer. It should be "reduced maintenance" instead. Just add distilled water every month or so and you'll be fine.
Old 01-10-2005, 01:17 AM   #15
pico
Member#: 5254
01 WRX
those batteries are nice, but they are quite expansive.... is there a good one cost ~70? how much does a regular battery for WRX cost?
thanks
Old 01-10-2005, 01:44 AM   #16
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
if you're on a bodget, you have to decide whether you want to spend 20 to 50$ on an entry level charger, or just buy a battery. the cheaper (less amps) charger you buy the longer it takes to charge a battery. If you buy the 1.5 amp trickle (usually the cheapie) it will take overnight at least. 5 to 10 amps is good for a home charger. btw that is sustained charge, not jump start which is usually about 50 amps on a 5 to 10 amp charger. In the end you may just find out your battery is no good.
If there is a junkyard in your area they usually have nice low-mile batteries for $20 or less.
Old 01-10-2005, 03:11 AM   #17
tooocool49723
Member#: 67127
3.3 I <3/h8 my GF3
(manual says 10 amps or less for charging, just some FYI)
Subaru battery is dead after 2 weeks!!! BBBsti LTD Electrical & Lighting 17 08-03-2008 12:48 PM
Valvoline manual transmission fluid very dark after 2 weeks, plus grinding into first ImportVenom Transmission (AT/MT) & Driveline 41 07-27-2007 04:24 PM
STI Accessport, 2nd Dyno run after 2 weeks of ECU learning finger123 Engine Management & Tuning 17 06-27-2004 05:29 PM
I'm selling dog after 2 weeks ownership LotusDriftx Mid Atlantic Impreza Club -- MAIC 6 04-03-2004 04:37 AM
Just got my car back after 2 weeks! ryball Bay Area Impreza Club Forum -- BAIC 6 03-19-2002 03:25 PM
