Notices
Old 01-09-2005, 12:28 PM   #1
EcksJay
Member#: 77677
1997 OBS
'07 KLR 650
Default Info on JDM swaps?
I have been searching for info, and I am having a hard time. What are some search words I should use? I am mainly looking at my options for an engine swap, and I have enough info on a EJ20, an EJ25, and I need to learn about JDM.
The swap will be done to my 1993 Impreza with a 1.8.
EcksJay is offline   Reply With Quote
Old 01-09-2005, 10:21 PM   #2
EcksJay
Member#: 77677
1997 OBS
'07 KLR 650
anybody?.....
I'm on the computer for another eight hours, and I was hoping to get some research done....
(I have to get back into 2nd shift schedule)
Old 01-09-2005, 10:31 PM   #3
Ghost Rider
Member#: 70346
2013 Focus ST
Performance Blue
Not exactly sure, but i think it is easiest to swap with the corresponding jdm sti engine for the model, i.e. Ver. 7 in an 02. I dont know what version a 93 would be but you could search for that. I believe there is a FAQ in this forum about that. I would search for the words "JDM" "Swap" "1.8" "Wire Harness" and so forth
Ghost Rider is offline   Reply With Quote
Old 01-09-2005, 11:27 PM   #4
Capt Crunch
Member#: 10852
Then : JDM Ver 7 STi
Now : E46 M3 / MKVI GTI
if you can do a WRX swap, you can do a version 7, 8, or 9 swap. There are just a couple more wires for AVCS involved. I think no matter what motor you put in, if it's turbocharged the wiring will be a bitch, so you might as well get the best engine you can afford.
Capt Crunch is offline   Reply With Quote
Old 01-09-2005, 11:27 PM   #5
mykrrrr
Member#: 733
'16 Fiesta ST
Platinum white metallic
Options:
USDM EJ20
USDM EJ257
JDM WRX
JDM WRX STi V1 thru V8
Is your car a FWD or AWD???
Who is going to do the swap???
What kind of power are you looking to get???
5 spd or 6 spd driveline???
Budget???
These are all things you need to look into before you jump into getting a swap or even considering one.
Good luck...
-mykr.
mykrrrr is offline   Reply With Quote
Old 01-09-2005, 11:40 PM   #6
EcksJay
Member#: 77677
1997 OBS
'07 KLR 650
My car is a AWD, 5spd.
I am looking at getting whatever power I can. (more than the 1.8, less than an STI)
I will be doing the swap. (it's okay if my car is out of commision for a month)
I will probably be sticking with a 5 speed. I really don't need a 6spd for Autocross.
Budget less than $6000. Preferably under 4k
I am also looking to stay away from full-blown wiring jobs. A handful of connectors and wires that need to be extended, sure. Tearing out the dash, ECU, and putting it all back together, probably not,..
Old 01-09-2005, 11:57 PM   #7
mykrrrr
Member#: 733
'16 Fiesta ST
1) Good start. You won't need to source a rear AWD subframe.
2) I'd say go USDM EJ20 swap. Not as cool in the bragging rights department as a JDM STi or USDM STI but easy to source parts and it's typically cheaper
3) 5 spd good. Might want to look into sourcing an RS tranny/rear diff if you want lower gearing for autoX. My STi driveline is 4.44 final drive like the RS and it's nice on autoX courses but not so great @ speed on the e-way. It's a trade off though...
4) You'll probably look around 3-4k for the parts and then the labour is all yours since you're going to do the swap yourself.
5) It's not like you're going to rip the entire wiring loom out of your car and replace it w/the WRX one but you should label every wire on both looms so you can match it up. This is the time intensive part of a Subaru swap. The physical swap is a matter of a few hours or a weekend BS'ing w/yer buddies eating pizza and working.
Again...good luck.
-mykr.
No one seems to have The right Info on this swap 04.STI General Community 1 10-10-2006 11:21 PM
been searching- need info on manual swap... beppomarx Transmission (AT/MT) & Driveline 4 09-02-2006 12:32 AM
Need info on ej20H swap in 95 bg5 legacy hotshot2109 Subaru Conversions 0 04-22-2006 03:22 PM
Please help with info on JDM swap srsaccount Subaru Conversions 1 09-13-2005 11:05 AM
Info on Engine Swap EJ20T Itsgoood Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-13-2001 04:23 PM
