Old 01-09-2005, 04:37 PM   #1
leon
Member#: 17123
Silva
Default UTEC VALET, Still reaching 15psi
All,
When driving in valet mode, I can tell that it's noticibly slower especially during initial takeoff, but it still reaches full boost(~15lbs). I can see this through the logs as well. Whats not right?
-Leon
leon is offline   Reply With Quote
Old 01-09-2005, 05:08 PM   #2
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
Is your abc way open?
santofontana is offline   Reply With Quote
Old 01-09-2005, 05:19 PM   #3
leon
Member#: 17123
Silva
I acutually opened not to use the ABC. I'm using another MBC, which is turned up to the MAXIUM i want to allow the boost to go. I thought that was the correct configuration?
Old 01-09-2005, 05:25 PM   #4
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
Theres your problem. The mbc doesnt know your utec is in valet mode.
Old 01-09-2005, 06:56 PM   #5
leon
Member#: 17123
Silva
The ABC woudn't know either. I guess I'm still confused as to how it works.
-Leon
Old 01-09-2005, 09:05 PM   #6
serendipity
Member#: 54597
08 'Busa, 08 ML63
10 Multistrada, 996 Targa
-Leon
How is the UTEC supposed to control the boost when you've disconnected the boost control solenoid and put a manual boost controller in?
With the ABC, the UTEC still uses the BCS to regulate boost, the ABC just bleeds off extra air.
serendipity is offline   Reply With Quote
Old 01-09-2005, 09:18 PM   #7
leon
Member#: 17123
Silva
Hmm ok I think I'm starting to get the picture. Can someone with a 2002 or simiar engine bay take pictures of EXACTLY how things are supposed to be hooked up? I've read, and re-read the instructions and still cant figure it out.
-Leon
Old 01-10-2005, 02:24 PM   #8
leon
Member#: 17123
Silva
bump!
Need REAL pictures(photo) of each component that explains what I need to do, to put the fbc back into operation (STOCK) then I can add the ABC and be ok.
-Leon
Old 01-13-2005, 09:59 AM   #9
leon
Member#: 17123
Silva
Ok I've fixed this! Finally the ABC is wired correctly. I believe It's all the way closed. This would explain why I'm only hitting about 14.5 PSI max. The valet thing is still an issue. While having the laptop hooked up I can see that it goes into valet mode and adjusts the ignition etc, but boost levels still go well above 7.
Any tips would be great.
-Leon
Old 01-13-2005, 10:09 AM   #10
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
The car will make at least 7 psi since that is the weight of the wastegate spring. The car can't make less boost than that.
mbiker97 is offline   Reply With Quote
Old 01-13-2005, 10:28 AM   #11
leon
Member#: 17123
Silva
It makes 14.5 as it does when using a stage 2 map. Thats the prob.
Old 01-13-2005, 10:38 AM   #12
ti 3vom
Member#: 65262
The UTEC uses some parameters from Map 1 for Map 0. Of course, you'd know this if you read your manual. I believe the boost map is one of them.
ti 3vom is offline   Reply With Quote
Old 01-13-2005, 10:44 AM   #13
leon
Member#: 17123
Silva
No.. it uses it's fuel maps. Perhaps someone else should be reading the manual?
Old 06-02-2005, 09:30 AM   #14
boomn29
Member#: 82968
2005 05 WRB STi gone
06 EB Evo IX
Got a question on the valet map:
Is it safe to run that map for an extended period of time? Like say on a long roadtrip? Would this help increase gas mileage or anything by chance?
boomn29 is offline   Reply With Quote
Old 06-02-2005, 09:42 AM   #15
TurboXS (Pete)
Member#: 16704
No, as the timing is not optimal.
regards
Pete
(TurboXS)
TurboXS (Pete) is offline   Reply With Quote
Old 06-02-2005, 10:18 AM   #16
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
On long road trips you aren't in boost anyway so the ECU is changing fuel to 14.7:1. Changing the map won't do a thing for you.
Old 06-02-2005, 10:44 AM   #17
boomn29
Member#: 82968
06 EB Evo IX
True for most. But some of us like to pass a lot...
Old 06-04-2005, 10:39 PM   #18
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
You can always just make a map with low boost and a good amount of timing.
I wonder what a good afr would be if you were running just 10psi?
UTEC valet mode bluebaru wrx Engine Management & Tuning 26 09-21-2004 02:05 AM
Question on UTEC Valet map....a/f, timing, saftey. Kwyjibo Engine Management & Tuning 8 01-20-2004 10:05 AM
car jerks when reach 15psi cml899 Newbies & FAQs 1 10-25-2003 10:38 PM
UTEC valet mode: safe to drive in? edkwon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 06-23-2003 12:10 PM
UTEC Valet Map and MPG mtb_dude Engine Management & Tuning 1 12-17-2002 08:35 PM
