Old 01-09-2005, 07:51 PM   #1
RockRaceScooby
Member#: 57120
1999 Forester
Red
Default How to Change Timing Belt
I was searching around and I haven't found a specific answer. I'm trying to change the timing belt on my NA 2.5, SOHC. This picture apears to be the tensioner:
tensioner picture link
How does that thing work? Do I just remove the bolt on the bolt on the opposite side from the blue pulley?
Picture of everything else
RockRaceScooby is offline   Reply With Quote
Old 01-09-2005, 08:29 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
I'd highly suggest that before you proceed further with this job, you should get a copy of the factory manual. That way you will have all the info you need to do this service.
You can get the manual from Subaru's tech site, here-
http://techinfo.subaru.com/html/index.jsp
Sign up for the $20/72-hour subscription and get whatever parts of the manual you need, or the whole thing.
Old 01-09-2005, 11:56 PM   #3
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
First off, I second Mulder's suggestion.
Yes that is the T-Belt tensioner. It is a hydraulic type and needs to be compressed upon putting the new belt in.
There are two ways that I do this.
1. As the factory recommends (I think, I haven't looked at the service manuals for a long time.):
First remove the belts and what ever pulley you need to remove to ge the belt off
Remove the tensioner like you said off the engine and put it in a press, I used an upright 20 ton.
Slowly compress with the tensioner piston pointing up in small increments, don't go too fast or you'll blow it. And you'll see pin holes in the lip housing in relation to the piston.
Once you have compressed the tensioner to a point where the holes line up, put in a grenade pin thru it (or a paper clip of yielding size). Make sure you don't stick the pin too far in as it will interfere with putting it back on from the engine side.
Bolt it back in and when you are done with putting the new belt, linign up the marks, etc, and the pulleys back it, pull the grenade pin and check that the tensioner is working adequately.
Double check all timing marks, and all bolts tight.
2. And the other way that I fancy It might be confusing, so bear with me:
With everything still together, grab a large prybar and use the leverage from the water pump "pulley" to pry against it and the tensioner pulley gentily. You will see the tensioner compress and then stick the pin in it.
The belt will be loose. Remove the belt and proceed with what you are doing, etc. You won't have to take off the pulleys. After getting all the belts lined up, just lift the belt above the orange pulley, the farthest one down. Double check the marks and pull the pin.
Voila, you just saved a few minutes of work without removing the tensioner or pulleys and all that out-of-car compression.
SOHC's are pretty easy to work with.
-paK +4
Pakin is offline   Reply With Quote
Old 01-10-2005, 12:16 PM   #4
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
I hope your water pump does'nt fail prematurely pak. That's probably not real good advise.
Tim Sanderson is offline   Reply With Quote
Old 01-10-2005, 12:50 PM   #5
RockRaceScooby
Member#: 57120
1999 Forester
Red
It doesn't sound good, but it does kind of sound like something I'd try anyway.
Old 01-10-2005, 02:00 PM   #6
agterlik
Member#: 41626
SPB We make people
quit teh internet
This is a really easy job. I did mine on my 01rs not to long ago and I am more or less a novice of things. I followed the service manual instructions more or less. Remove the crank pulley, remove the plastic cover over the timing belt. Remove the tensioner pulley and remove the bottom left idle pulley. I recommend just compressing the tensioner in a vice and then sticking a paperclip or a small allen wrench through the whole to keep it compressed. Also something to note is that the service manual says that the notch count on the belt should be approx 40.5 and 44 if I recall correctly.....well this is wrong. If you get a new belt and count the notches it is more like 47.5 and 44. Just a heads up if for some reason you are using an old belt that has the alignment marks on it rubbed off.
To reassemble it first put on the tensioner pulley still compressed by your pin of choice. Then line up the two outside pulleys and the crank with the appropriate marks on the engine. Place the new timing belt on making sure everything is lined up. Once everything is lined up I recommend bolting on the cover over the crank to hold the belt in place on the crank for you. Now is the fun part of getting the belt on the two outside pulleys. Once that is done put the idle pulley back on and then pull the pin out of the tensioner. Place the plastic cover back on over the belt. Then the crankpulley goes back on. Put the car in 5th and have someone step on the brake pedal when you go to torque it. Put all your belts beck on and you are done. Hope this somehow helps. And yes you remove the top right bolt on the tensioner pulley bracket thing to remove it
agterlik is offline   Reply With Quote
Old 01-10-2005, 05:57 PM   #7
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
It hasn't yet. Nor has it on another car I worked on.
I figured the amount of axial stress caused by the belt itself far exeeds my press strength. I don't need to emphazise any excessive force when doing this.
-paK +1
Old 01-10-2005, 11:11 PM   #8
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Get the Haynes manual for the 1998 Legacy. It covers 98% of what is on your vehicle. It even explains the timing belt swap.
Western Suburbs: Need shop to change timing belt in 2000 Honda Civic john_matrix Mid West Subaru Owners Club Forum -- MWSOC 5 03-25-2010 04:16 PM
NJ shops to change timing belt tdats Tri-State Area Forum 10 11-25-2009 12:54 PM
need to change timing belt. WHERE is good in queens? scutts Tri-State Area Forum 35 06-24-2009 02:04 PM
how much for timing belt change? rebel1988us Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-16-2009 11:25 PM
Cost to change timing belt - parts & labor? blessed0903 Service & Maintenance 13 05-06-2007 11:05 PM
