Old 01-09-2005, 10:00 PM   #1
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Default Correct jack up points on WRX?
I tried jacking up my car several times using spots recommended by Subaru. However, it ended up bending and damaging the jack up points. Is anyone else having the same problem?
Old 01-09-2005, 10:51 PM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Don't use the stock jack points unless you really, really need to.
Though for a Forester, this link applies to the WRX:
http://www.scoobymods.com/forums/showthread.php?t=2673
Old 01-09-2005, 11:17 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Ramps are your friend, as is the rear diff and the jack pad behind the oil pan.
Old 01-09-2005, 11:29 PM   #4
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Tried using ramps, but with lowered springs it never worked.
Old 01-09-2005, 11:31 PM   #5
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Will jack fit under rear diff. with lowered springs?
Old 01-09-2005, 11:39 PM   #6
MPREZD
Member#: 50596
04 wrx breakin
necks in JBP sucka!
can someone post pix of the jack pad behind the oil pan please?
MPREZD is offline   Reply With Quote
Old 01-09-2005, 11:42 PM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
use some 3/4" or 1" X 6" boards or plywood stacked up in front of the ramps to get clerance....I have a bunch of scrap wood I picked up at Home Depot for this purpose...works great.
Old 01-10-2005, 02:19 AM   #8
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Rhino ramps, the plastic ones available for about $25/pair at Walmart, have a gentle-enough angle that they work with many lowered cars.
Old 01-10-2005, 11:15 PM   #9
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Were you using a regular floor jack on the "Flange jack points"? If so, this will bend them. The flange jack points are ONLY for the OEM jack.
Old 01-10-2005, 11:41 PM   #10
DJ_STI
Member#: 56826
2006 Subaru Evo IX
Cute & FABULOUS Miata
A trick to solve this is get a small piece of wood. Place the piece of wood against the ramps and then just drive up on the little wood pieces, then right onto the ramp? I think this would work wouldn't it? I had tein-s techs on my wrx and the rhino ramps from wal-mart worked perfectly (although it was very close). also i went through several jacks till i found one craftsman jack that was able to go under the car completely and was able to jack the car up from behind the oil pan. Now when I need to work on the car I jack either rear diff, with a small piece of wood inbetween, or right behind the oil pan on the jacking plate, sometimes i'll use a ramp but jacking the car up seems easier for me.
DJ_STI is offline   Reply With Quote
Old 01-24-2005, 05:22 PM   #11
WRX450
Member#: 20867
Default or...
pieces of wood work, but I personally like hockey pucks... they don't break as easily. *shrug*
C.
WRX450 is offline   Reply With Quote
Old 01-24-2005, 08:08 PM   #12
psoper
Member#: 7703
2002 WRX wagon
It isn't black, its blue!
Ramps don't do any good for changing tires or working on suspension
psoper is offline   Reply With Quote
Jack/lift points on 07 Impreza Wagon kaotik78 Service & Maintenance 9 07-22-2011 10:52 AM
What are the shift points on WRX ... MPH makofoto Transmission (AT/MT) & Driveline 16 02-11-2009 08:29 PM
shift points on wrx mattesonb Newbies & FAQs 45 10-05-2007 03:54 AM
wheres a good jacking point on wrx sedonawrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-13-2004 12:38 AM
Camber correction kit - H&R springs on WRX megatron Brakes, Steering & Suspension 5 11-29-2001 07:54 PM
