Old 01-09-2005, 10:35 PM   #1
wrx05
Member#: 69032
2005 Legacy GT
Obsidian Black
Default 02 wide-band sensor same as EGT?
Is there a faq yet for a wideband sensor? I was thinking of getting a EGT gauge but then I came across a wideband sensor and wondered if it would give me the same info if not more. Id rather spend the extra bucks and have an easy install.
wrx05 is offline   Reply With Quote
Old 01-09-2005, 10:37 PM   #2
wrx05
Member#: 69032
2005 Legacy GT
Obsidian Black
Old 01-09-2005, 10:39 PM   #3
cnk
Member#: 10757
2013 BRZ Limited 6MT
No. .they're not the same. WBO2 is used to detect the air/fuel ratio while EGT is used to detect exhaust gas temperature. An EGT gauge will tell you if your engine is running too hot or too cold, while the WBO2 will tell you if you're running too rich or too lean. They are related to one another since the leaner you run, the higher your EGT's will be and vice versa. Most people get an EGT gauge. A WBO2 is nice, but it's more expensive and unless you have a need for one in order to do tuning on your car, I would say an EGT would be sufficient.
Calvin
cnk is offline   Reply With Quote
Old 01-09-2005, 10:41 PM   #4
wrx05
Member#: 69032
2005 Legacy GT
Obsidian Black
Thanks Calvin..thats exactly what I needed.
wide band o2 kit and egt gauge midnight2.5rs-t Private 'Wanted' Classifieds 4 05-15-2009 09:47 PM
Greddy EGT Sensor Same as Defi? Sap12687 Electrical & Lighting 2 11-05-2008 03:27 PM
F/S Hydra EMS with wide band sensor 2006STI365 Engine/Power/Exhaust 31 03-26-2008 09:43 PM
Stock EGT sensor...same as aftermarket??? subieworx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-27-2006 02:42 PM
Wide band sensor? Lachlan Newbies & FAQs 0 09-21-2005 05:06 PM
