Welcome to the North American Subaru Impreza Owners Club Friday July 11, 2014
Old 01-10-2005, 12:05 AM   #1
s4floorin
Member#: 79179
Default help adapting awd drivetrain into porsche 911...help!
I need some help putting together this project of mine. right now it is an idea, but i need more info to continue.
I would like to install a wrx drivetrain into a porsche. How would the drivetrain need to be situated? meaning would the gearbox need to be flipped over to work right? since the porsche is rear engine the car would need to drive in "reverse"...
what will i need to do here?
Also since the porsche doesnt have a front differential, i will need to adapt some of the wrx suspension parts to drive the front wheels. both are strut suspensions so it should work.
Please let me know any tips or ideas you guys may have. first timer on the boards, and need all the subie help i can get. maybe certain parts/years i should/shouldnt use?
thanks.
s4floorin is offline   Reply With Quote
Old 01-10-2005, 12:07 AM   #2
billzebub
Member#: 40248
2003 WRX
Midnight Pearl (black)
Sombody in the SE forun has done this...search on "Porscharu"
billzebub is offline   Reply With Quote
Old 01-10-2005, 12:20 AM   #3
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
You're gonna get slapped for cross posting....
Old 01-10-2005, 01:50 AM   #4
olsaltybastard
Member#: 54244
'04 STi
Wow, just thinking about the fabrication required is mindboggling. I guess the only advice I could give would be to have a machine shop in your garage, or close by. Lot's of things will have to be made. Good luck.
olsaltybastard is offline   Reply With Quote
Old 01-10-2005, 02:54 AM   #5
Boxologist
Member#: 21118
why not buy a 4S?
Boxologist is online now   Reply With Quote
Old 01-10-2005, 03:01 AM   #6
Porter
Member#: 486
2004 Forester XT
bug spattered
Yes. User steve_d. PM him for details. The original is a '68 912 with an EJ18 motor in it, and he's working on an EJ20 (turbo) powered '72 widebody 911 right now.
Porter is offline   Reply With Quote
Old 01-11-2005, 07:41 AM   #7
9-2xs
Member#: 77122
problem #1 Porsche equals dry-sump air/oil cooled... I'm not sure where you fit the radiator, turbo, exhaust manifold, Up-pipe, and then there's the tranny, etc.... It looks like a lot of fabrication. And you can get a 911 Nat Aspr 3.0 or 3.2 stage 2 that's rock solid with the early 70's style exhaust that will produce 245hp... And it will be cheaper than all the fabrication... We usually get 120k miles + between rebuilds. Also look closely at the torque/hp curve... My Porsche pulls harder than my stage 3 WRX in 3rd 4th and 5th
9-2xs is offline   Reply With Quote
Old 01-11-2005, 08:09 AM   #8
BryanH
Member#: 993
This begs the question of why?
BryanH is offline   Reply With Quote
Old 01-11-2005, 08:57 AM   #9
joey1313
Member#: 53839
2005 STi, 06 S2K
I would like to see this when its done.
joey1313 is online now   Reply With Quote
Old 01-11-2005, 06:51 PM   #10
911renegade
Member#: 58442
undecided
what year is this 911?
what are you planning on doing with this car?
to get a driveline from the transmission to the front of the car you will have to cut a tunnel in floor, porsche did not provide a "hump" for a driveline.
hopefully you know how serious it is to cut up the floor of a unibody car.
911renegade is offline   Reply With Quote
Old 01-12-2005, 10:19 AM   #11
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
95 993 C4, 71 911, 04 STI
Simpler? Certainly. Cheaper? No way. The whole point of a WRX engine is that it costs 20% of a decent 3.0 or 3.2, nevermind another $800 for SSIs or whatever "Stage 2" means. And if you want 245hp out of a 3.0, you're talking cams, pistons and EFI (> $10k altogether) vs a $500 ECU reflash on the WRX motor.
Jon Bogert is offline   Reply With Quote
Old 01-12-2005, 11:49 AM   #12
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
the WRX drivetrain would be a no go with the traditional porsche engine location...all of the drivetrain would be backwards...
Old 01-12-2005, 01:56 PM   #13
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
I don't think anyone was suggesting that he could use the Subaru AWD drivetrain. No chance of that. Perhaps read too many of those "flipping the ring gear" stories in kit car magazines?
Old 01-13-2005, 02:59 AM   #14
Boxologist
Member#: 21118
Originally Posted by Boxologist
why not buy a 4S?
1234
lets be a post whore
yeah Box!
Old 01-17-2005, 09:21 PM   #15
brandon
Member#: 1183
2002 Legacy L SE Wag
1964 Lotus Elan
Now I'll admit I haven't had a Subaru tranny apart before, but could you please explain why you couldn't just flip the ring gear assembly? Is there something in the way? I'm sure there was someone on one of the Australian sites who did this for a rail a few years ago. I'm not saying you're wrong, I'd just really like to know why.
brandon is offline   Reply With Quote
Old 01-26-2005, 11:14 AM   #16
bryan_johnson
Member#: 78987
Default motor spins the wrong way
The 911, 914, VW busses, and bugs have transaxles that spin backwards from normal front engine setups. Normally when people put non-standard motors in a VW or porsche they use the VW/porsche transaxle. KEP makes adapters for alot of these setups. www.kennedyeng.com
Another common conversion is the Corvair motor into old air-cooled VW busses. The corvair motor turned backwards from normal motors, so in that case, as I understand it, they turn the motor around and have some kind of adapter that lets you put the bell housing on the end of the motor that normally has the belts.
/Bryan
bryan_johnson is offline   Reply With Quote
Old 01-26-2005, 06:37 PM   #17
Porter
Member#: 486
2004 Forester XT
bug spattered
A Subaru motor spins the correct way to mate to a Porsche transaxle. There are several companies who make Subaru -> Porsche transmission adapter kits that involve mating a Porsche style flywheel and bellhousing to the Subaru crank. This is what was done in the Porscharu v.1.
See below:
If you search in this forum there are several shots of the engine crossmember that Steve fabricated.
Drove a '00 Porsche 911 (996) Carrera 4, my thoughts inside... Sam_P Off-Topic 64 11-10-2009 09:37 PM
06 WRX AWD sedan drivetrain into 94 1.8 L 2WD wagon Questions Bertamus Subaru Conversions 7 10-09-2009 12:13 AM
porsche 911 VS WRX HOKOS Texas Impreza Club Forum -- TXIC 25 06-05-2002 10:26 AM
Porsche 911 C4 vs WRX Hartman WRX Forum Archive 0 02-13-2001 02:10 PM
playing with a porsche 911... soob2k Southern California Impreza Club Forum -- SCIC 4 08-29-2000 12:48 AM
