Old 01-10-2005, 01:46 AM   #1
Killian Maynard
Member#: 73734
2005 WRX I caught
you a delicious bass
Default Can Dealership Detect AP Stage 1 Flash?
Assuming mechanically everything is stock, only running a stage 1 reflash, would the dealership be able to detect the flash?
Or would it be neccesary to run the stock map if a trip to the dealership was in order?
Killian Maynard is offline   Reply With Quote
Old 01-10-2005, 03:16 AM   #2
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
dealer can detect any flash, just not what kind. Dealer told me that a couple flashes are ok cause sometimes the dealer flashed the ECU when you go in for major service but if there is too many flashes recorded, then they get suspicious. Thats what I heard.
You need to run the stock flash...
darksands is offline   Reply With Quote
Old 01-10-2005, 03:13 PM   #3
Killian Maynard
Member#: 73734
2005 WRX I caught
Thats what I was thinking, my only concern is that if and when I had to take my car into the dealer for warranty work I would 1. reinstall stock DP 2. remove 2.2 ohm resistor and reinstall egt sensor (for gutted stocker) and 3. flash stock program. My concern is that a CEL (P0545 EGT temp too low) might appear at some point at the dealer which could lead them to discovering my uppipe cat had mysteriously dissapeared. If I were to do all that but flash the stage 1 instead, it would be less likely that a P0545 CEL appeared.
Old 01-10-2005, 04:27 PM   #4
crazymikie
Member#: 56321
2008 Lexus IS-F
Once you flash your ECU, they can detect it. Going back to stock doesn't make the car exactly the same-
See this thread for more info:
http://forums.nasioc.com/forums/showthread.php?t=672784
Since the 04/05 Accessport is the same, I assume your car will now read as an '04 with an automatic transmission- even after unmarrying.
Mike
crazymikie is offline   Reply With Quote
Old 01-10-2005, 09:35 PM   #5
Killian Maynard
Member#: 73734
2005 WRX I caught
Could they prove that you had something to do with it?
Old 01-11-2005, 08:43 AM   #6
Corkfish
Member#: 39503
That was my thinking. If they detected some alteration, what's to stop you from just saying "hey, this is how the car came and I haven't touched it"? If you're just running a stage 1 with no other visible modifications, couldn't you just play dumb?
Corkfish is offline   Reply With Quote
Old 01-11-2005, 09:52 AM   #7
crazymikie
Member#: 56321
2008 Lexus IS-F
Well, the ECU tag that is written is for an '04 WRX with an automatic transmission. The case, however, says that you have an '04 WRX with a manual transmission- on top of that, there are several flavors of the MT ECU- ah791, ah792, ah793. The sticker on the case won't match what the ECU returns from it's ROM.
Mike
AP Stage 1 Flash questions wawawrx Newbies & FAQs 18 03-20-2009 02:05 PM
Just another Cobb AP Stage 2 flash appreciation thread ultraspdWRX Factory 2.0L Turbo Powertrain 7 09-16-2006 09:08 PM
Can only get AP stage 1 if it is quicker. HAL1 Engine Management & Tuning 22 12-17-2005 11:35 PM
Can Dealership detect AP flash? STirocket Engine Management & Tuning 9 06-30-2005 04:06 PM
Can you run AP stage 2 with just a Helix catted downpipe? Irishman Engine Management & Tuning 3 04-19-2005 11:56 AM
Message Board Statistics All times are GMT -4. The time now is 01:07 AM.
