01-10-2005, 10:39 AM | #1 |
Member#: 56571
Vehicle:'05 LGT - Stage 2 |
OBD Port not reading?
Took my car in to have gauges installed and everything went fine but the guys said they tried to plug in a code reader to the OBD port and got nothing, no signal. Is this something I should take to the dealer for or do they have other ways of pulling codes if a CEL goes off? I have never had a CEL go off or had to pull codes for anything before so this is the first time I was made aware of a bad OBD port in 20,000 miles of driving.
01-10-2005, 10:56 AM | #2 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
Do you know what kind of code reader it was? Some of the cheaper generic ones won't connect to Subarus. You can take it to Autozone and have them do a free scan, they won't find any codes but at least you'll know if the port is working. Alternately you can try finding someone in your local area with a scanner and have them hook up to it.
The OBD port is the only means of communication with the ECU so it needs to be working, if you suspect a problem with it by all means let the dealer check it. |
OBD port not working? | 04stidg | Electrical & Lighting | 3 | 03-15-2012 12:17 PM |
Help OBD Port Not Functioning | search | Service & Maintenance | 5 | 05-30-2009 12:36 AM |
How is the OBD port disconnected? | David03WRX | Electrical & Lighting | 2 | 04-20-2003 02:43 PM |
Need to relocate OBD port | TurboRex | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 06-29-2002 01:44 PM |
Does obd-2 software read injector duty cycle | snookem | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 8 | 04-12-2002 12:11 PM |
