Old 01-10-2005, 01:19 PM   #1
gotawd
Member#: 31504
FP Red
2.5L/6 speed 02 WRX
Default engine problems..need help
last week i installed my egt and oil pressure gauges and a lightweight crank pulley and now the car is running horrible. its real sluggish and jerky on full throttle. we pulled the CEL and it said i was running to lean.. what could of caused it?? i was thinking that my filter was dirty and wasnt getting enough air but i cleaned it really well last night and its still doing the same. any ideas????
kuhn
gotawd is offline   Reply With Quote
Old 01-10-2005, 01:22 PM   #2
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
check all vacuum hoses under the hood..You might have unplugged one by accident.
There is a thread that covers what to look for when you get a CEL P0171 I think, which is for system being too lean. Perform a search for it, and I think you should find the info you need there.
jigga is offline   Reply With Quote
Old 01-10-2005, 04:00 PM   #3
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Search for the code number and see what others have done to fix it. Sounds like you have a dirty MAF sensor and it needs to be cleaned. Try that and see if it fixes it.
Old 01-10-2005, 05:05 PM   #4
mmorningstar
Member#: 73432
2008 Ford Mustang GT
Performance White
you bumped something, check for vacuum leaks, sounds like it's leaking somewhere. P0170 and P0171 are very hard to solve sometimes, I had that code on my Eclipse GST for 3 months about a year ago, turned out to be a crack in the turbine housing introducing air to the sensor...good luck
mmorningstar is offline   Reply With Quote
Old 01-10-2005, 10:00 PM   #5
gotawd
Member#: 31504
FP Red
2.5L/6 speed 02 WRX
if it was in a vacuum hose would i still run the same psi...would it drop if there was a leak and my vacuum on my boost guage is the same also... yea im gonna clean my maf sensor tonight and see if thats it
Need help ASAP with smoking engine problem! PLEASE HELP! DJS_02_WRX Newbies & FAQs 14 10-10-2009 10:59 AM
engine problems..need help.. fosingwo Subaru Conversions 5 10-27-2006 04:09 PM
Engine problems - Need help ASAP! Soon2BturbodRS Normally Aspirated Powertrain 13 06-25-2005 07:08 PM
Engine Problems Need Help!!! RSimport Normally Aspirated Powertrain 7 06-10-2005 06:00 PM
toyota engine problem, need help. spike Off-Topic 25 01-11-2004 06:25 AM
