Old 01-10-2005, 01:21 PM   #1
STi-BOD-
Member#: 78539
2005 Subaru STi
K&N Typhoon HKS CarbonTi
Default Going from mobil 1 to regular Mobil ok?
the guys at the dealership put in reg mobil insted of mobil 1 is this real bad? its my fault i forgot to tell em syn.
STi-BOD- is offline   Reply With Quote
Old 01-10-2005, 01:29 PM   #2
bgbyztoy
Member#: 49437
04 wrb STI
PE1820 turbo 12.2@112mph
you'll be fine
bgbyztoy is offline   Reply With Quote
Old 01-10-2005, 01:59 PM   #3
antimullet
Member#: 44193
2008 WRX STi
Its ok as long as you're not running an oil only cooled turbo, don't wanna coke the bearings with dyno oil. But a stocker should be fine I've always ran dyno oil in my WRX and now my STi until i got the Green turbo in it now I gotta switch.
antimullet is offline   Reply With Quote
Old 01-10-2005, 02:01 PM   #4
Scooby-Doode
Member#: 28976
2007 Twin Turbo
Spoolin'
Dino oil should be fine. Just get it changed back to whatever your prefer at your next oil change.
Old 01-10-2005, 02:20 PM   #5
STi-BOD-
Member#: 78539
2005 Subaru STi
ok, thanks guys thats what my dad said too and hey i saved 20 bucks
Old 01-14-2005, 03:32 PM   #6
Al_Smokemcrack
Member#: 66640
1997 Legacy Outback
Glacier White
You'll be fine. Just make sure you change it on time. You can't get away with not changing dino like you can with synth. Though, if you're like most people on this forum, you've got a minor oil-change complex and change it all the time. Thus, I doubt it'll be a problem.
Al_Smokemcrack is offline   Reply With Quote
Is Mobile 1 M1-108 filter OK to use on a 2002 WRX? Maniac Service & Maintenance 4 04-08-2009 10:15 AM
Can you switch from part synthetic to regular oil sweetdang Legacy Forum 6 10-25-2008 08:39 PM
Going from Stage 1 to Stage 2 khizzle Newbies & FAQs 6 09-18-2007 01:49 PM
Going from VS 1 to VS 2, how to tune MikeWRX-NJ Engine Management & Tuning 2 09-17-2003 10:33 AM
What is the conversion factor to go from Wheel HP to Crank HP? makofoto Proven Power Bragging 11 06-11-2003 03:19 AM
Message Board Statistics All times are GMT -4. The time now is 03:17 PM.
