Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 01-10-2005, 02:22 PM   #1
4830DeuceWRX
Member#: 54762
02 Aspen WRX- VF22
and S202 Springs & Struts
Default ECUtek + Boost Controller
I did a search and didnt find what i was looking for, but I just got my ECUtek tuned and am very happy with the numbers. Tom @ Payn Tech (tuner) set the boost on my VF22 at a low 17 PSI to be safe with a good amount of power. If it was ever needed to beat a good match in a drag race I was thinking of getting a simple manual boost controller to pump the boost up a little maybe to like 19 or wathever. I was wondering if this would be ok and not lean out my engine. Will the ECUtek still run the same fuel? Any help would be great, thanks.
4830DeuceWRX is offline   Reply With Quote
Old 01-10-2005, 03:03 PM   #2
Physics Junkie
Member#: 65609
I really wouldn't recommend it.
Physics Junkie is offline   Reply With Quote
Old 01-10-2005, 04:42 PM   #3
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
Buy Delta Dash and make use of the User Tune feature if your ecutek tuner enabled this. Add fuel, reduce timing
Do not just turn up the boost.
mick_the_ginge is offline   Reply With Quote
Old 01-10-2005, 08:16 PM   #4
4830DeuceWRX
Member#: 54762
02 Aspen WRX- VF22
thanks guys, anyone else?
Old 01-10-2005, 10:15 PM   #5
joeyd02
Member#: 16742
07 STI UGM
AP Stage2 Clark Tuned
I had my car reflashed with ECUtek also. I am using the VF30. Rich at Dyno Comp set my boost to max at 17 psi and said that I shouldn't use any boost controller at all. Mohommad at MZM uses one because he is running an APS SR55 turbo and there is no need with our smaller turbos. He agrred wth Rich from Dyno Comp
joeyd02 is offline   Reply With Quote
Old 01-10-2005, 10:27 PM   #6
ghedo icy
Member#: 55409
2014 Infiniti Q50
I'm running an EcuTek flashed by kingpin. I had an MBC previous to the flash and have left it on with no issues.
Getting ready for a VF22 upgrade.
-Matt
ghedo icy is offline   Reply With Quote
Old 01-10-2005, 10:29 PM   #7
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
ecutek with 2 maps, 16.5 psi and 18.5 psi.
using stock boost control. vf30 and supporting mods.
Old 01-10-2005, 10:34 PM   #8
ghedo icy
Member#: 55409
2014 Infiniti Q50
BTW, what are the numbers?
-Matt
Old 01-10-2005, 10:42 PM   #9
screamin04wrx
Member#: 46098
2004 WRX Stage II
220whp/210wtq
Kind of off topic. 4830 Deuce.... why such low boost with the VF22? Is that all you can run with the ECUtek? My friend has the 22 but with UTEC running 18.5lbs of boost with 93oct for low boost setting and 21lbs with 100oct high boost. I wanted to go with ECUtek but I don't want to if you can only run 17lbs safely.
screamin04wrx is offline   Reply With Quote
Old 01-11-2005, 10:00 AM   #10
Kingpin
Vendor
Member#: 41252
Twin 2005 600WHP
FormulaD/TimeAttack Sti's
Boost in not designated by the Engine Management. You could run any amount of boost with the EcuTek. There are a lot of different philosophies to tuning Subarus but keep in mind boost is not independent. There is a fine balance going on between the boost, fuel, and timing. Not to mention a couple dozen other parameters. The goal is to make the most power and torque. I cannot speak for the tuner of this car but I would go with whatever combination works best. More information is really necessary before a resonable answer can be given. What does the timing curve look like? What does the AFR curve look like? Did the tuner leave you some head room for more boost or are you maxed out?
M
Kingpin is offline   Reply With Quote
Old 01-11-2005, 10:21 AM   #11
4830DeuceWRX
Member#: 54762
02 Aspen WRX- VF22
Thats one of the things he forgot to give me. I never received a print out of my power, or such things as timing, fuel etc. It was an honest mistake by tom payn (tuner) and me for not asking. It was last Saturday morning and he did me a favor by coming in to tune my car. As he was tuning I did pay close attention to my power curve which was very nice and straight tapering off very slightly as the rpms raised. I will try to stop buy and get a print out later this week and post it. Oh by the way the numbers came out to be 240whp and 239ft lbs of torque on a mustang dyno with the shop loading door open in 25 degree weather. Thanks for the replies and keep them coming!
Max boost with OEM boost controller and Ecutek? Silver '02 REX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 08-26-2005 01:14 AM
Help! EcuTek and Boost Controller? Silverandscared Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 09-08-2004 03:48 PM
blitz boost controller, MRT dogbox, stage 4 ecutek ecu, stock IC for 02 wrx. dothespeedlimit Private 'For Sale' Classifieds 16 08-18-2004 12:54 AM
blitz boost controller, MRT dogbox, stage 4 ecutek ecu, stock IC for 02 wrx. dothespeedlimit Private 'For Sale' Classifieds 17 04-15-2004 12:35 AM
Boost controller or ECUtek SjpWrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-01-2003 10:16 PM
