Old 01-10-2005, 03:08 PM   #1
werkInProgress
Member#: 76083
03 wrx
Default torque specs for swap???
looking for torque specs on shortblock swap..I bought a v7 shortblock,and need the torque specs, so i can go ahead and do the swap..Any help would be appreciated..Thanks..justin..
werkInProgress is offline   Reply With Quote
Old 01-10-2005, 06:50 PM   #2
Kreeger
Member#: 37558
2003 TS wagon
JDM bukkake white
I would think that the torque specs would be the same as a USDM wrx... but I am not certain. The only thing that may be slightly different is the head bolt torque.
Kreeger is offline   Reply With Quote
Old 01-10-2005, 08:40 PM   #3
werkInProgress
Member#: 76083
03 wrx
Yeah, thats what i figured..Its just i have no idea what they are for the wrx either..
Old 01-10-2005, 09:16 PM   #4
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
You need a FSM...
Old 01-10-2005, 09:57 PM   #5
Mumbles
Member#: 248
What specs do you need?
Mumbles is offline   Reply With Quote
Old 01-11-2005, 02:21 AM   #6
werkInProgress
Member#: 76083
03 wrx
heads,crank,exhaust manifold, etc...
Old 01-11-2005, 11:46 AM   #7
Mumbles
Member#: 248
There you go, JDM Ver7.
Old 01-11-2005, 03:33 PM   #8
Kreeger
Member#: 37558
2003 TS wagon
JDM bukkake white
You, sir, are my hero.
Torque specs for bolts after hub swap? OUScooby Brakes, Steering & Suspension 0 05-08-2010 08:22 PM
08 WRX Torque specs when swapping out springs SubyConvert Brakes, Steering & Suspension 2 05-02-2008 02:09 AM
Torque specs for Cosworth rod bolts for EJ25? Navid Built Motor Discussion 0 10-20-2007 10:57 PM
looking for torque specs for valve cover, spark plugs and coil packs Tobey Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 04-13-2005 03:35 PM
Torque specs for pulley? JGard Normally Aspirated Powertrain 9 04-12-2001 10:01 AM
