Old 01-10-2005, 07:37 PM   #1
tekfoc
Member#: 21392
2014 45 AMG MB
WHITE /MB C300 4MATIC
Angry started as a axle leak now what
ok i noticed i had a leak from the passanger side axle going into the gearbox,ok i said i new this is a common problem with 2002 and up wrx's. I said to my self, you know the dealer is going give you a real hard time wth your mods. I have uppipe and bosal down with cobb stge II on the acessport. the car runs very very good by the way. so i did the smartest thing you can do for your wrx I made a apointment with precision tunning I love that place, rich does fantastic work their. well i get their rich brings me right in the garage up goes the rex on the lift rich ask me what side was it again cause, he forgot i said passanger side he said i have both left and right axle gaskets just in case. its good thing he did cause we noticed both sides were leaking. I told rich might as well do both sides. rich does the work and tells me you have some play in your roller bearings in the gearbox. now im very very pissed off inside cause i take very very good care of my car never never droped the clutch never speed shift i always let off the gas when i shift. I got the car brand new ,it still to this day shifts great in all gears. rich then tells me your gear box can probably last 50.000 or even a 100.000 before you really have to do something. rich drains the oil from the gear box inspects the drain plug for any metal pieces on it cause the drain plug is magnetic any metal would stick to it. rich finds one tiny tiny i mean tiny like the size of human short hair, the oil looked good coming out wasnt burnt no other metal pieces were found. my car has 23.000 miles only !!! .I wander how many wrx's out there have the same problem of premature wair of the roller bearings . now im dabating i should just trade it in for a 2005 wrx sti . any guru experts on these gearbox with any insight please respond with any information. like a said before the gearbox runs fantasic no problems no syncro problems just this dam leak that got repaired that lead me in to the problem with play of the roller bearings .
tekfoc is offline   Reply With Quote
Old 01-10-2005, 07:52 PM   #2
pr0driveX
Member#: 23207
2013 BRZ
I know that WRXs have lasted many miles (100k+) with the car maintained like it should be. I also know the transmissions have had short lives when driven poorly. "Wear", not "wair" could have occured if the transmission was abused or if it was lacking proper lubrication.
pr0driveX is offline   Reply With Quote
Old 01-10-2005, 07:56 PM   #3
tekfoc
Member#: 21392
2014 45 AMG MB
fluid level was allways kept at the full level since new.
Axle replace now leaking lowsol94 Transmission (AT/MT) & Driveline 10 05-22-2012 11:41 PM
what stage to start as a base on utec with a ej5-40t? zachary.berrier UTEC 1 04-02-2006 01:13 AM
Uh-Oh, One tire leaking now what? Tuned Tire & Wheel 2 08-03-2004 08:38 AM
What childhood foods still taste just as good to you now? Heavy Fuji Off-Topic 27 01-08-2004 09:41 PM
I overreved by car to 8K! Now it's leaking oil what should I do? Bill_WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 57 03-18-2002 09:00 PM
