Old 01-10-2005, 11:44 PM   #1
Hye-Teck
Member#: 46087
Default Accessport base map question
so i got an accessport today. When initializing and choosing the base map i chose the stock map.
after that i uploaded a stage 2 91 oct but not as a base map...just a regular map. When i check to see what map is currently runnig, it says Stock Map. Is the car actually running the stock map or is it running the stage 2 91oct map?
It said it was successful when sending the stage 2 91oct map. Was i suppose to set that map as my base map?
Hye-Teck is offline   Reply With Quote
Old 01-10-2005, 11:57 PM   #2
darkstarmoto
Member#: 44681
2011 WRX SWP Hatch
www.48hrs.info group lead
You onlt see the base map with the AP, it will not show you your realtime map (you have to remember what you flash). I will say that you should have the stage 2 map as your base to see the complete power gains available.
darkstarmoto is offline   Reply With Quote
Old 01-10-2005, 11:58 PM   #3
BigJ04STi
Member#: 77239
2004 Impreza WRX
None
Make the base map the map of the stage you are at...So if you have the TBE, and are runnin a stage 2 tune, make the base map STage 2, and use the Real time maps to retune from there...
If you don't use the Stage 2 as the base map you won't get the max output from the tune...
Also, no matter which real time map you use, it'll only tell you what base map you are running.
BigJ04STi is offline   Reply With Quote
Old 01-10-2005, 11:59 PM   #4
darkstarmoto
Member#: 44681
2011 WRX SWP Hatch
Jinx...owe me a beer....
Old 01-11-2005, 12:02 AM   #5
Hye-Teck
Member#: 46087
thanks...gonna go to the garage and load the stage 2 base map since i have an APS turboback
Old 01-11-2005, 02:09 AM   #6
Hye-Teck
Member#: 46087
how many pounds of boost am i suppose to be boosting in 4th gear wot? i was doing 18.3-18.5 peak psi of boost haven't done a 6th gear wot yet cause its raining.
Old 01-11-2005, 10:40 PM   #7
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
I belive it's 17.5 +-.5 Psi. Yours is a tad high, but will probably settle down with some learning. And having stage 2 as base map is the way to go!!
wrxdrvr is offline   Reply With Quote
Old 01-12-2005, 12:38 AM   #8
Hye-Teck
Member#: 46087
last night it kept constantly hitting 18.3-18.5 tonight it was only doing 17.4-17.6 with once it spiking to 18.1 at wide open throttle in 6th 5.5k rpm.
Old 01-12-2005, 12:59 AM   #9
flycaster
Member#: 60142
2011 WRX
Grey
Perfect, right on the money.
flycaster is offline   Reply With Quote
04 WRX - Going to be installing STAGE 1... Real Time vs Base map Question. Jeenyus AccessPort 10 12-27-2007 02:44 PM
Accessport Base Map/Real Time Map overlay question ruski Engine Management & Tuning 0 01-09-2006 06:37 PM
accessport base map question? lettucemanatee Engine Management & Tuning 1 07-27-2004 05:56 AM
FXT base map question speedypete Engine Management & Tuning 1 06-22-2004 06:46 PM
Tweaks to UTEC STi Stage II base map questions. StiDreams Engine Management & Tuning 24 06-19-2004 06:32 PM
