Old 01-11-2005, 10:00 AM   #1
root
Member#: 55854
2004 STi
Blue/silver
Default Calculate VE from MAF readings?
Seems like it should be possible to calculate the VE from log files if we have the RPM, MAF, and AFR readings. Has anyone worked out the calculations or am I missing some bit of info?
root is offline   Reply With Quote
Old 01-11-2005, 10:18 AM   #2
hippy
Member#: 36528
2002 Impreza Wrx
Someone has. I was reading the other day where someone said their wrx had a 162% efficiency at peak torque(with 14.9psi of boost). Here's a link.....
peace
Old 01-11-2005, 10:25 AM   #3
root
Member#: 55854
2004 STi
Blue/silver
Very interesting. Thanks for the link.
Old 01-11-2005, 10:29 AM   #4
root
Member#: 55854
2004 STi
Blue/silver
I was thinking you would have to take the volume of the fuel entering the engine into account as well as the air. But maybe with such a small amount of fuel compared to air it would be negligible in the calculations.
Old 01-11-2005, 11:12 AM   #5
happasaiyan
Member#: 37731
i think thats jblaines site if im not mistaken.
happasaiyan is offline   Reply With Quote
Old 01-11-2005, 03:48 PM   #6
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Roger that.
jblaine is offline   Reply With Quote
Old 01-11-2005, 08:09 PM   #7
Jon [in CT]
Member#: 2992
02 WRX Sedan
You don't need AFR. You do need ambient pressure and temperature. You also need to know the volume of the combustion chamber when the cylinder's at TDC. And, of course, you need the cylinder's swept volume (displacement). With these values, plust RPM and MAF, you can calculate VE from log files. For best accuracy, collect ONLY RPM and MAF.
Jon [in CT] is offline   Reply With Quote
Article: Calculating VE jblaine Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 07-09-2004 10:10 PM
Article: Calculating VE jblaine Engine Management & Tuning 4 07-09-2004 04:49 AM
calculating MPH from RPM gypsymoth Transmission (AT/MT) & Driveline 3 07-28-2002 11:41 PM
how to calculate psi from boost gauge? rayder Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-08-2002 01:42 AM
What's the formula for calculating MPH from RPM? Mykl Transmission (AT/MT) & Driveline 2 01-31-2002 01:36 AM
