Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2015
Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 01-11-2005, 12:36 PM   #1
marcus12
Member#: 45613
2005 Legacy GT Ltd.
Satin White Pearl
Default 2.2L Crankshaft Positioning Sensor needed - also, oil in spark plugs question
Hey all,
I need a crankshaft positioning sensor for my EJ22. If anyone has one laying around from a broken down engine, or knows where I can get one, please respond or PM...
Also, anyone know why I would have oil in my spark plugs? I did a search and the most common response is a leaky valve cover gasket...but I heard head gasket as well. Only driver's side plugs have oil in them.
Thanks!
//marcus
marcus12 is offline   Reply With Quote
Old 01-11-2005, 12:45 PM   #2
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
I'd like to know if there's a way to tell if there's a way to check if its the valve cover or HG.
I've got the same oiling issue
iamrazor is offline   Reply With Quote
Old 01-11-2005, 12:47 PM   #3
Mumbles
Member#: 248
Valve cover gasket. No Doubt.
Mumbles is offline   Reply With Quote
Old 01-11-2005, 12:50 PM   #4
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
B:
Is it true the "closest" fluid to the spark plug hole at HG is clooant, while at the VCG is oil?
Old 01-11-2005, 01:13 PM   #5
jamesfacts
Member#: 51282
98 RS
black & blue from parking
2nd valve cover idea. Marc, I'm rebuilding an EJ22, I should have a cps for you to borrow if you need.
jamesfacts is offline   Reply With Quote
Old 01-11-2005, 01:25 PM   #6
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
is there enough room to replace them with the motor still in the car?
Old 01-11-2005, 01:51 PM   #7
jamesfacts
Member#: 51282
98 RS
Unless your car is DOHC, yes.
Old 01-11-2005, 01:54 PM   #8
marcus12
Member#: 45613
2005 Legacy GT Ltd.
Satin White Pearl
nice
american - I'd like to just try putting a new one in to see if it helps with my low-idle woes. I'm pretty sure the one in the car is working correctly. If it wasn't, the car wouldn't even turn over, right?
//marcus
Old 01-11-2005, 02:12 PM   #9
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
iamrazor=SOHC
has anyone performed this fix? any pitfalls to watch out for?
Old 01-11-2005, 02:29 PM   #10
jamesfacts
Member#: 51282
98 RS
nice
//marcus
For you, good question. Maybe. What year is your 2.2?
Razor, there's a good write-up on the procedure in the NA forums.
Old 01-11-2005, 02:49 PM   #11
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
thanks americanyouth!
ill go
for it in a minute.
2.2L Camshaft Position Sensor 302Stang 1993 - 2001 Impreza Specific Parts 0 08-12-2009 01:26 AM
Oil in spark plug hole 7andSubie Owner Normally Aspirated Powertrain 3 09-18-2005 12:52 AM
Oil in spark plug tube Flexy Service & Maintenance 16 09-16-2005 12:17 PM
Oil in spark plug hole, 91 2.2??? rallynutdon Legacy Forum 8 10-22-2004 12:08 PM
Oil in spark plug NickSTi South East Region Forum 8 08-27-2002 08:55 PM
