Old 01-11-2005, 01:48 PM   #1
C2H5OH
Member#: 39924
2003 WRX
Default Honda question - 420 CEL (Cat Inefficiency)
Hey guys,
My gf's accord is throwing a CEL - Autozone's reader's scanned it at 0420... some blah..blah... cat being inefficient. Do you think I could use some kind of MIL eliminator to get rid of the code or if there anything else that I could do?
Appreciate any input on the issue
C2H5OH is offline   Reply With Quote
Old 01-11-2005, 01:53 PM   #2
WRX300
Member#: 17974
Well depending on the actual code (high/low, no response) it could be the sensor as well as or in addition to the cat....
if its the sensor I dont think the MIL eliminator would work but if its the cat than yeah it would get rid of the light but you still wouldnt pass emissions with a sniffer
WRX300 is offline   Reply With Quote
Old 01-11-2005, 02:08 PM   #3
blue-sun
Member#: 15934
my Honda throws MILF codes all the time boi! especially at the female Z06 drivers
blue-sun is offline   Reply With Quote
Old 01-11-2005, 02:58 PM   #4
C2H5OH
Member#: 39924
2003 WRX
Thanx - the actual code was something like cat running below or with low efficiency, so I doesnt sound like a bad sensor. On the other hand, she just smogged that accord! Just caught one of the days when CEL was off and it passed the test. I'm puzzled...
Old 01-11-2005, 02:59 PM   #5
e_a_olson
Member#: 7034
2005 Nissan Altima
2.5SL - Black
Code 0420 means you need to stop fishbowling in yuor Honduh.
e_a_olson is offline   Reply With Quote
Old 01-11-2005, 03:00 PM   #6
soso3
Member#: 36794
89 T I T A N
CHeck your gas cap.
soso3 is offline   Reply With Quote
Old 01-11-2005, 03:03 PM   #7
WRX300
Member#: 17974
would probably be the o2 sensor itself then... especially if it passed a sniffer
Old 01-11-2005, 03:06 PM   #8
C2H5OH
Member#: 39924
2003 WRX
Originally Posted by soso3
CHeck your gas cap.
Check it for what? If it's closed? For leaks? The car's been recently smogged and I'm sure they checked it...
Old 01-11-2005, 03:08 PM   #9
WRX300
Member#: 17974
gascap will throw a CEL for "small evap systems leak detected" not a cat ineffiency code
Old 01-11-2005, 03:14 PM   #10
mattjk
Member#: 16615
I ♥ my TE51
2009 Nissan 370z
mattjk is offline   Reply With Quote
Old 01-11-2005, 03:14 PM   #11
WRXVT
Member#: 17979
335i Blue
p0420 happened on my GF's old 2002 accord, and JUST happened on my coworkers 98 accord. Dealership said that they need to replace the catalytic converter for that code. Keep in mind it (the cat) is covered until 80,000 miles on a honda.
WRXVT is offline   Reply With Quote
Old 01-11-2005, 03:19 PM   #12
WRX300
Member#: 17974
the 8/80 is federal warranty from all OEM cars
EDIT: most OEMS will do the CAT itself under this warranty but if your o2 sensor(s) crap out you gotta pay for it yourself
Old 01-11-2005, 03:31 PM   #13
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Yup federal law
8 years 80k on the Catalytic Converters and PCM.
A bad 02 sensor will not cause a p0420, if its under 8 years 80k take it to the dealer and have them look at it.
Jay
Old 01-11-2005, 03:40 PM   #14
andywrx
Member#: 10355
2008 Honda Element
What year of accord?
My friends Si was throwing a similar code (cat inefficiency) and he just put an 02 sim on it (then again, he's now running a race header which eliminates the cat) and that worked.
Another friend had a bad 02 sensor, Honda replaced it.
My car got a CEL the other day - I never checked it, actually - but I reset the ECU and it didn't come back on. Might want to try that first, if it comes back up get Honda to peek at it.
andywrx is offline   Reply With Quote
Old 01-11-2005, 07:39 PM   #15
C2H5OH
Member#: 39924
2003 WRX
Thanks for the information I think it's a 97 accord, and it's over the 100,000 by now, so it's out of warranty... But, it has passed a smog check within a couple of months for sure. As wrx300 pointed out, it's more likely to be an O2 sensor than a cat since it passed a sniffer test without issues.
So far, I'm going to (1) reset an ECU, (2) if the CEL comes back, search for an electrical CEL fix (if it worked on a WRX, it should be fine for an Accord - and there is NO way i'm gonna spend time trying to custom fit a mechanical one), (3) take a look at a gas cap, just in case, and check whatever else is related to emissions and is easily reachable.
Why wouldnt a bad sensor cause a p0420? I was under impression that if reads incorrectly, it will be sending wrong voltage back to the ECU... Is 420 associated with cat converter itself or can it be caused also by something else, for example, a bad air/fuel mixture?
Again, thanks for all the input!
-Alex
Old 01-11-2005, 07:43 PM   #16
BJamerican
Member#: 5595
2005 Legacy 2.5GT
Satin White Pearl
My Legacy will throw a P0420 code once or twice a year. I'm guessing that the oxygen sensors need replaced rather than the actual cats. I just can't justify spending the $180 on an old car when it is running strong as ever at 135k miles.
BJamerican is offline   Reply With Quote
Old 01-11-2005, 07:47 PM   #17
C2H5OH
Member#: 39924
2003 WRX
I think it's more like $50-70, but still... I know what you mean
Old 01-11-2005, 07:48 PM   #18
BJamerican
Member#: 5595
2005 Legacy 2.5GT
Satin White Pearl
Originally Posted by McDade
Yup federal law
Jay
But doesn't the ECU use the O2 sensors to determine cat efficiency by comparing their readings? Couldn't it throw a P0420 if one of the sensors is fouled as long as the reading isn't deemed invalid by the ECU?
Old 01-11-2005, 07:49 PM   #19
BJamerican
Member#: 5595
2005 Legacy 2.5GT
Satin White Pearl
But there are 2 oxygen sensors to replace.
quick question about NA cat and FI cat bnr34rb26dett Newbies & FAQs 1 01-23-2009 11:12 AM
Question about CEL and cats fujiwara_yingyu Vancouver Impreza Club Forum -- VIC 6 12-22-2007 11:49 AM
CEL Cat Efficiency Blind Moose Legacy Forum 8 06-01-2006 11:14 AM
Honda question... need clutch/pressure plate/flywheel recommendations RallyWagon Bay Area Impreza Club Forum -- BAIC 2 11-20-2002 02:15 AM
HndaTch?Others?- Honda question Subi Ru Mid West Subaru Owners Club Forum -- MWSOC 7 05-03-2002 02:33 PM
