Old 01-11-2005, 05:31 PM   #1
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
Default EJ20G short block in a my02 WRX?
so im trying to figgure out a couple of things. whould i be able to use a ej20g bottom end in a WRX?
my buddy blew his bottom end in his WRX and i am going to put in a new one for him. im just trying to figgure out if an EJ20G BottomEnd will work with all the modern sensors(if there are any) and ECU? the thing im afraid of is that the EJ20G will lack sertain sensors, or if the WRX harness will match up w/ the EJ20G bottom end, or if the WRX ecu will be able to recognize the new bottom ends sensors.
i know there are other issues w/ this swap but this is the major issue i have for now.
thanks
kirill
snowman4us is offline   Reply With Quote
Old 01-11-2005, 08:21 PM   #2
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
Unless you have an EJ20g shortblock just laying around it's not really worth it. Unless there absolutely some reason you have to stay 2.0L getting an EJ257 shorty will be easier to make much more power with and cost about the same.
no-coast-punk is offline   Reply With Quote
Old 01-11-2005, 08:23 PM   #3
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
well i can get one for about 1/5 of the price it would cost to get a 257. but could i do it w/o having the problems i stated eariler?
Old 01-11-2005, 08:27 PM   #4
no-coast-punk
Member#: 49087
If you swap over all the WRX sensors it will work just fine. I don't know for sure but the older blocks might have different style knock sensors and stuff. All the EJ blocks have the same bungs for stuff though... shouldn't be a problem at all.
Old 01-12-2005, 08:11 AM   #5
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
anyone else know anything else?
and im actualy woried about the knock senseor and more then anything crank angle sensor...
Old 01-12-2005, 10:54 AM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
there was a guy in portland that tried just that spoonagule/pdx tuning helped him
give noah at cobb a call he has a fresh rebuilt ej20g block for sale .. or did
there are 2 versions of the g 8 to 1 and 8.5 to 1
knock sensor is not an issue at all ..
it will definatly need a reflash .. it will run like crap on a stock ecu
Old 01-12-2005, 02:11 PM   #7
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
yeah i already talked to noah about the block he had for sale. i was the one that actualy picked it up from him for another buddy of myne.
but as for the ECU, a Utec will be used to sort out the tunning issues.
jaxx so it is possable to do this swap? i know there will be issues w/ higher CR due to the WRX heads having a smeller chamber. but im going to use a thicker headgasket to get it back down a little bit.
but as far as all the electronics go it will all match up to the ej20g?
Old 01-12-2005, 05:42 PM   #8
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
dunno contact pdx tuning...
the only electronics on the short block are the knock sensor and the two temp sensors in the coolant crosspipe
Old 01-12-2005, 06:13 PM   #9
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
whould u know there phone# or website?
Old 01-13-2005, 02:51 AM   #10
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
http://pdxtuning.com/
RS_to_WRX_swap is offline   Reply With Quote
2.5 short block in a 02 wrx blkhatch Newbies & FAQs 6 09-30-2008 03:49 PM
FS: EJ22t block, EJ20G short block, sti RA heads my name Engine/Power/Exhaust 20 05-12-2008 08:04 PM
EJ20G short block in a WRX snowman4us Subaru Conversions 12 03-04-2005 08:49 PM
Interest?: WRX EJ20G Short Block subyfanatic Private 'For Sale' Classifieds 12 08-28-2003 01:59 PM
Our New Short block in a stock WRX Crawford/I-Speed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 67 06-06-2003 02:51 PM
