Old 01-11-2005, 07:04 PM   #1
bigjeffscv
Member#: 62887
Default Dash elimination
I am working on a 99 Impreza and I want to eliminate the factory dash cluster and install a custom one. I have been told that the center diff lights and thumb wheel control wiring run through the cluster. Is this correct and can the change out be done with a minimum of re wiring?
Any help would be appreciated!
Thanks in advance.
bigjeffscv is offline   Reply With Quote
Old 01-11-2005, 09:40 PM   #2
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
By installing a custom one, do you mean simply replacing the cluster with aftermarket choices like Syms or Zero/Sports, or building your own cluster out of various gauges & displays?
If it is the former, afaik, they should have a proper harness to make the swap work with minimum modifications.
If it is the latter, I'm afraid you may have little luck here, as most members here are in north america, and we don't get Imprezas with DCCD until the WRX STi came almost 2 years ago. My guess is that the DCCD thumb wheel control connects to the dash cluster only to supply display signal, and thus the thumb wheel should still be able to operate. If not, you'd have to look at the wiring diagram from the factory service manual to see which pin on the thumb wheel connector needs to be connected to power and ground.
satrya is offline   Reply With Quote
does the mil eliminator eliminate..... xtuffycorex Engine Management & Tuning 16 09-28-2005 06:03 PM
CEL Eliminator Not Eliminating Discjoshie Normally Aspirated Powertrain 0 01-31-2005 10:20 PM
Dash Elimination bigjeffscv Electrical & Lighting 0 01-13-2005 01:48 PM
1993 Dash to 2001 Dash AJS Subaru Conversions 3 11-05-2003 08:08 PM
Will trade - my stock carbon dash kit for your silver dash kit and $$$ alfriedesq Tri-State Area Forum 2 02-10-2003 01:15 AM
