Old 01-11-2005, 07:04 PM   #1
dentprone
Member#: 18588
1999 busted car
silverthorn
Default spark
hey everyone. i just swapped wrx engine into my 99 rs and im workin the bugs out...ive got fuel in the cylinders, but no spark.. the harness ohms out good ...there is power to all the sensors... ive got 12 volt at the spark plug coils... but no signal voltage to the coils from the ecm...ive tried two different ecm's with the same outcome...i hooked a scan tool up to the obd2 connector....and it says i have no trouble codes... please help
dentprone is offline   Reply With Quote
Old 01-12-2005, 05:11 PM   #2
dentprone
Member#: 18588
1999 busted car
silverthorn
BUMP...
Old 01-13-2005, 05:46 PM   #3
dentprone
Member#: 18588
1999 busted car
silverthorn
anyone know where i can get my ecm checked out? i dont have another wrx to try my ecm in sooo im left with guesswork...is there a shop that will check my ecm to see if its operating correctly?
Old 01-13-2005, 07:05 PM   #4
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
Edit: reading comprehension is gewd.
BAN SUVS is offline   Reply With Quote
Old 01-13-2005, 07:11 PM   #5
RickInLittleElm
Member#: 58353
99 Mercedes-Benz
E430
Well if you already swapped ecus w/ no change, it seems likely that the problem exists in the wiring and not the ecu. Have you checked all your grounds? If one is not connected, certian parts of the ecu will not function properly.
All I can say is go back to basics. Trace every power source in the schematic and make sure it is correct. Do the same w/ the grounds. I had a similar problem on the last swap i did and it ended up being a grounding issue. PM me if you want some technical help. I do all the swaps @ FIS and can probably help.
_Rick
fis
RickInLittleElm is offline   Reply With Quote
Old 01-13-2005, 10:00 PM   #6
dentprone
Member#: 18588
1999 busted car
silverthorn
Ok im new at this swap stuff...so dont get too mad.. i made my own harness for the fuel controller..with female spade connectors, covered in heat shrink tubing. the problem is i had the wires in the wrong place on the controller when i tried both ecm's. When it didnt work, i eventually found out which place each wire goes from a super helpful nasioc member...as it stands..the controller is wired correctly now..but the ecm doesnt work, which leads me to think that i fried both ecm's from my ignorance...the controller was toasted and the 30amp fuse blew from me messin with those damn controller wires..the first time around,so im pretty sure the ecm's are bad now but i sure would like to know for sure..so i can stop this witch hunt...thanks!
Old 01-13-2005, 10:57 PM   #7
Ds baruuuuu
Member#: 4724
01 01RS
brp
i had the same problem mine ended up to be the wire that powers the coils(grn/red) coming from the smj i tapped into the blower fan relay another grn/red not to far off in pins on the ecu double check that wire
Ds baruuuuu is offline   Reply With Quote
Old 01-15-2005, 01:17 AM   #8
dentprone
Member#: 18588
1999 busted car
silverthorn
yep i made that mistake when i first had the harness apart..but i caught it before i soldered the wires...i have 12 volts to the coils but the third wire on each coil sends a signal from the ecm...and i have nothing in that wire... the service manual says replace the ecm if this happens when the harness is ok....so im gonna need another ecm
Spark Plug FAQ: Read if you want spark plug information! Unabomber Service & Maintenance 710 09-01-2016 11:53 AM
Replacing Spark Plugs - What else Compliments Spark Plug replacements? FIlters? jungleman Service & Maintenance 2 02-09-2009 03:45 PM
96 brighton 1.8l impreza 1-2 spark 3-4 no spark WRXR1A10 Normally Aspirated Powertrain 6 12-28-2007 02:52 PM
Help! Sparks between distributor cap and spark plug wires! Stickee Normally Aspirated Powertrain 13 04-23-2003 11:23 AM
('93-'01) Will you get better performance if you get different spark plug?? IBO Impreza Forum 4 04-08-2001 12:10 AM
