Old 01-12-2005, 12:08 AM   #1
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Default EJ22T Structure - should I be worried?
This has been sitting in my garage for awhile since I bought it (underfunded project) and I finally got around to posting this. Should I be concerned about the block's integrity? It looks like someone tried to open up (scarred) the passages quite a bit.......not very professional:
Belly up, driver side
passenger side
exterior view
TyranosaurusWRX is offline   Reply With Quote
Old 01-12-2005, 04:16 PM   #2
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
bizzump
Old 01-12-2005, 04:31 PM   #3
scoobydorift
Member#: 43128
92 RWD, 96 FWD
05 AWD
are you talking about the scratches in the passages?
i just went and looked at a ej20g closed deck..and it looks very similar.
if your just talking about the scratches you should not have a problem.
Rick
scoobydorift is offline   Reply With Quote
Old 01-12-2005, 04:42 PM   #4
Kreeger
Member#: 37558
2003 TS wagon
JDM bukkake white
That hole looks to me like a typical crankcase pressure channel to allow the crankcase to equalize pressures between the crankcase and the valve covers. Looks the same on most (if not all) suby F/I blocks.
Kreeger is offline   Reply With Quote
Old 01-12-2005, 06:41 PM   #5
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Cool, I hope so. When you have a better look at it, it appears that it was done with a beer (maybe more than one) in one hand and a drill bit in the other...unless they just do it that way from the factory.
Old 01-14-2005, 06:12 PM   #6
dentprone
Member#: 18588
1999 busted car
silverthorn
Im pretty sure its done that way at the factory...fast conveyor and air die grinder assembly work getting casting burrs off the case...my EJ22t had the same markings...and i was the 1st person to take mine apart.
dentprone is offline   Reply With Quote
Old 01-15-2005, 11:57 PM   #7
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Thanks all, I feel a little less stressed!
Old 01-19-2005, 08:53 PM   #8
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
you are just seeing factory flashing. Build it...
Old 01-20-2005, 12:35 AM   #9
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Amen
Old 01-21-2005, 10:54 PM   #10
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
Get a real torque wrench....
RS_to_WRX_swap is offline   Reply With Quote
Old 01-22-2005, 12:09 AM   #11
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Hahah, don't worry, that's not my only one. It's just my prybar
just put in ngks...should I be worried?... Blindeye_03 Normally Aspirated Powertrain 8 06-22-2012 03:05 PM
OT: should I be worried subarurabbit New England Impreza Club Forum -- NESIC 24 10-29-2005 07:45 PM
Should i be worried about this? 00SilverWRXSedan Service & Maintenance 5 09-25-2002 07:18 PM
Metal pieces found in tranny...should i be worried? GDA Transmission (AT/MT) & Driveline 79 09-19-2002 07:03 PM
I have a Phase 1 block should I be worried? georgiamiata Legacy Forum 21 09-13-2002 02:51 PM
