Old 01-12-2005, 12:44 AM   #1
Physics Junkie
Member#: 65609
Default Could use some help removing the power steering pump bracket..
Ok, so there are 4 bolts that need to be removed. I got the two that are underneath the pulley(one to the right and one to the left)--where are the other two? I've taken a good look at the thing and even attempted removing some bolts that I shouldn't have(the two bolts behind the pulley...pain to get out). Could someone point me in the right direction? The car is an '04 sti.
To get an idea of what I'm talking about look at step 4 here --> http://www.autocds.ru/2004%20STI/02.%20ENGINE%20SECTION%20(STi)/01.%20FUEL%20INJECTION%20(FUEL%20SYSTEMS)/03.%20Intake%20Manifold.pdf
Physics Junkie is offline   Reply With Quote
Old 01-12-2005, 06:40 PM   #2
2phless
Member#: 69343
1998 TransAm cnvrtbl
Feel behind the pump. They are straight down into the motor if I remember right, and they are WORSE to get to than the ones behind the pully. Before pulling, remove any vaccum connections in the area and the plastic valves they are attached to. There are a couple bolted to the intake or near it and I've heard the nipples can get broken off when wrenches slip.
2phless is offline   Reply With Quote
Remove and Repair the Power Steering Pump? STIG 007 Brakes, Steering & Suspension 7 02-24-2010 04:39 PM
WTB: 99+ RS motor and wrx power steering pump bracket! scobaru Private 'Wanted' Classifieds 1 05-14-2007 01:23 PM
WTB: power steering pump bracket scobaru MWSOC Private Classifieds 6 05-14-2007 03:18 AM
WTB: power steering pump bracket scobaru Private 'Wanted' Classifieds 0 05-12-2007 03:19 AM
WRX power steering pump/bracket...... AK'S REX Private 'Wanted' Classifieds 0 12-14-2006 01:57 PM
