01-12-2005, 01:16 AM | #1 |
Member#: 8023
Vehicle:2019 Crosstrek white |
Another Hella wiring question
Could someone verify for me that this would work.
Overall what I am trying to do is use my FF1000’s off the hella switch independently to act as fog lights in the winter and, after re aiming , use them as driving lights in the warmer months to be triggered by my high beams. If I chose to I could flip switch 1 and use a relay that would be triggered by the high beams. The top right was cut off in the photo but it is the wire that goes to pin 86 of the hella relay. It is the wire that was designed by hella to be hooked up to a headlight positive signal See the diagram proived by satrya in thread. http://forums.nasioc.com/forums/showthread.php?t=676460 I am particularly interested in knowing if the green/red wire (pin13) on the stalk switch connector B71 can be used as a negative trigger.
01-12-2005, 11:56 AM | #2 | |
Member#: 5887
BAIC
Vehicle:2002 GDAA (bugeye) 797 (blaze yellow) |
Personally, I'd rather worry about mounting one switch instead of two. This means abandoning the standard switch provided in the Hella kit, and get a Single Pole Dual Throw switch (which allows for 2 input sources), preferrably with "center-off" (which allows for 3 positions: independent fog, off, and high-beam dependent fog). So the switched ground pin on the diagram below would be connected to pin 8 @ B71 (or 13 @ B71). |
01-12-2005, 01:04 PM | #3 |
Member#: 8023
Wow , thank you satrya. That was exactley what I was trying to achieve.
I must say that when I see your diagrams , and then look at mine, I feel like a fourth grader with a crayon. lol |
01-12-2005, 01:36 PM | #4 |
Member#: 5887
BAIC
You're welcome.
It's quite amazing what the drawing features in MS Word & Excel can do. Regarding the SPDT switch, I've seen nice ones out there that has backlighting for when one of the non-off positions are selected. I can't remember which site sells really nice looking ones, but these sites may have been where I saw them: http://www.painlesswiring.com http://digikey.com http://www.parts_express.com <--- remove the underscore for the real url http://www.mcmaster.com Here's one from Painless Wiring (#80408 - On/Off/On Single Pole - Amber Lights). There may be nicer ones in other sites. I thought I can find one with different light colors for the 2 different "on" positions. |
01-12-2005, 06:59 PM | #5 | |
Member#: 8023
I will check out those web sites for a nice switch, one with two different lights if possible.. thanks again.. |
01-12-2005, 08:17 PM | #6 | |
Member#: 5887
BAIC
For the 3D drawings though, they are done using this shareware program called DoGA: http://www.doga.co.jp/english/index.html Not as powerful as Pro/E, SolidWorks, etc., but it allows making simple objects like one below relatively quickly. http://home.comcast.net/~satrya/art/zeta_pod.jpg |
Another Hella 500 question thread OH YEAH!!! | TheJames | Electrical & Lighting | 19 | 03-05-2010 04:05 PM |
another gauge wiring question. | everythingfallsx | Interior & Exterior Modification | 0 | 08-28-2006 10:28 PM |
Another Hella 500 question for the experts | Type1 | Electrical & Lighting | 3 | 01-11-2006 04:57 PM |
Another Hella horn question | 03MBP | Car Audio, Video & Security | 27 | 01-30-2005 05:29 PM |
Another Gauge Wiring Question? | rjhhockey1 | Electrical & Lighting | 1 | 02-03-2004 09:44 PM |
