Old 01-12-2005, 09:43 AM   #1
my99maddog
Member#: 55515
1998 MY99
Default Rough Idle on 2.5 Short Motor
Has any one experienced rough idle with a 2.5 short motor?
This one is bolted up to Version 6 STi Heads and is only running low boost during its run in. Original Version 6 STi 440cc injectors and a VF28 all in need of upgrade one day but this should not impact on the idle? Any thoughts appreciated.
my99maddog is offline   Reply With Quote
Old 01-12-2005, 10:26 AM   #2
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Didn't notice an idle difference when I switched to one. Vacuum leak somewhere maybe?
Old 01-12-2005, 04:50 PM   #3
jdchmiel
Member#: 926
my idle is the same.
ditto ont eh vacuum leak check suggestion. You can use a propane torch and dont light it, jsut move it around the engine bay near everything like where the manifold mounts to teh heads and see if your idle changes. I have heard people use water too, and you can hear it, but Id rather keep the motor dry since the next step is wrenching on it.
jdchmiel is offline   Reply With Quote
Rough idle on 04 Turbo motors (2.5L) TSB Peaty Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 145 03-29-2009 07:50 PM
2.2 heads on 2.5 short block jasaab Normally Aspirated Powertrain 1 05-31-2008 10:18 AM
2.5 short motor (shipped abroad tho) exvaux Private 'Wanted' Classifieds 2 11-07-2007 11:53 AM
Questions on Rough idle on 06 STI with the following mods... origonalp Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 04-07-2006 11:34 AM
2.2 ECU on 2.5 motor.. IAC valve problem Murray Engine Management & Tuning 6 12-30-2002 11:01 PM
