Old 01-12-2005, 12:28 PM   #1
gsteclipse33
Member#: 72859
Default can a utec get rid of cat efficency codes like a AP can
just what the title says i traded my AP for a utec but i cant drive around with cel for cats cause i wont pass inspection ik normally u cant but i know someone but they still ahve to plug it into obd2 and any cel u fail
gsteclipse33 is offline   Reply With Quote
Old 01-12-2005, 12:37 PM   #2
hippy
Member#: 36528
2002 Impreza Wrx
You know from your last thread that it can't(no offense). Use this. If you have a problem with an uppipe cel, do the resistor mod.
peace
Old 01-12-2005, 12:40 PM   #3
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
No, it can't.
jblaine is offline   Reply With Quote
Old 01-12-2005, 01:28 PM   #4
gsteclipse33
Member#: 72859
actully my last post was if it blocks them entirly this is if it gets rid of cetian codes
Old 01-12-2005, 01:56 PM   #5
gsteclipse33
Member#: 72859
also can a tuning shop rid my car of sertian cel for ever like cat effieceny
Old 01-12-2005, 02:09 PM   #6
cronic
Member#: 9749
Get a splice in cel fix.. Or mechanical cel fix with a spark plug anti fouler/
cronic is online now   Reply With Quote
Old 01-12-2005, 02:12 PM   #7
gsteclipse33
Member#: 72859
ah that works for the uppipe too
Old 01-12-2005, 02:22 PM   #8
cronic
Member#: 9749
THe uppipe u can just get a resistor for at radio shack.. then just insert one end into one side of the egt plug bend it, put the other side in and just tape it up.. You need a 2.2k ohm 1/2 watt resistor
Old 01-12-2005, 03:06 PM   #9
gsteclipse33
Member#: 72859
alright cool thanks
Old 01-13-2005, 03:48 PM   #10
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
The 'splice' fix just renders the OBDII cycle to 'pending' the o2 check and if any OBDII device is plugged in, it will show this.
If you are in an area where there is any OBDII emissions testing, the 'splice in fix' will cause you to fail the test...
The 'mechanical fix' does NOT-say again- NOT produce a 'pending' state for the OBDII cycle, and you will pass the OBDII test.
THIS is why the 'mechanical fix' is a better 'fix', IMO
Old 01-13-2005, 10:54 PM   #11
Locowrx
Member#: 28054
2005 GGM WRX STI
Cobb STG 2 and Loving it!
Wrong, I had the MIL eliminators on both of my old cars (03wrx and 00mustang GT) and I passed Emissions without anyproblems..
Locowrx is offline   Reply With Quote
Old 01-14-2005, 12:20 PM   #12
gsteclipse33
Member#: 72859
but was it obd2 emissions or sniffer
Anything i can do to get rid of this POS? tom@kartboy Off-Topic 83 01-28-2010 07:54 PM
getting rid of cat olsen726 Normally Aspirated Powertrain 27 04-04-2008 02:21 PM
Can the EcuTek get rid of the TGV cell? Optimus Prime Engine Management & Tuning 12 09-05-2005 01:19 PM
getting rid of cats bliz Off-Topic 25 02-11-2004 12:26 AM
anyone know of exauhst shops in houston that dont mind getting rid of cats? jmott Texas Impreza Club Forum -- TXIC 21 12-04-2001 10:05 AM
Message Board Statistics All times are GMT -4. The time now is 07:08 PM.
