Old 01-12-2005, 01:41 PM   #1
MomoWRX
Member#: 36823
03 MBP WRX Sold :(
93.5 Single Supra :)
Default Which tool to gap spark plugs
I am picking up some NGK BKR7E spark plugs and want to know the best gapping tool.
gapping wire or feeler gauge? Which one do you find more accurate for measuring gap?
MomoWRX is offline   Reply With Quote
Old 01-12-2005, 02:58 PM   #2
MustGoFast
Member#: 33370
2002 Impreza WRX
Blue now w/ 6 fun flavors
which plugs are those.. I had the NGK PFR7G's highly recommended to me for 1 stage colder .. these are of course the plats.. are those the coppers?
MustGoFast is offline   Reply With Quote
Old 01-12-2005, 03:29 PM   #3
MomoWRX
Member#: 36823
03 MBP WRX Sold :(
yea, how did you gap yours?
Old 01-12-2005, 04:33 PM   #4
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Old 01-12-2005, 05:37 PM   #5
MomoWRX
Member#: 36823
03 MBP WRX Sold :(
Unabomber, do you have a under $40 solution
Old 01-12-2005, 06:53 PM   #6
WillysPU
Member#: 25994
2003 WRX wrb stage 4
What would Scooby do?
I am a bit older than many of you and back in the day we didn't have a fancy pants electrode gapping tools. Here is what we did:
I like to use the feeler gauge (not the wire gauge) as it provides more surface to test the gap.
I place the spark plug on it's head and use a small rubber mallet to GENTLY tap the "arm" down to the electrode just a little and test the fit with the gauge. If I go too far I GENTLY bend the arm back with a needle nose pliers.
If you are lucky enough to have an assistant near by they can hold the plug for you while you hold the feeler gauge between the arm and the electrode and gently tap it until it is flush on the gauge. It takes very little force to move the arm.
Be exta careful if you have iridium plugs as that tip can break very easily and then they are toast.
Spend the extra $40 on a pop and ice cream for the kids.
Jim
WillysPU is offline   Reply With Quote
Old 01-12-2005, 08:04 PM   #7
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Jim's post above is 100% correct, buy you DID state you wanted the best.
Old 01-12-2005, 10:45 PM   #8
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
http://buy1.snapon.com/catalog/item....re&dir=catalog
any auto parts store should have a gapper just like this.
usually 99 cents
I tried to find the snap on one I have, it has a part to adjust the arm.
Jay
Old 01-12-2005, 10:46 PM   #9
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
ah I found the mac version of mine.
http://www.mactools.com/ProductDetai...ItemNum=FG4450
Old 01-13-2005, 01:37 AM   #10
MomoWRX
Member#: 36823
03 MBP WRX Sold :(
nice thanks
gap spark plugs? xblaze1one Newbies & FAQs 8 11-29-2007 12:39 PM
gapping spark plugs FadiSTI Service & Maintenance 4 07-31-2006 05:36 PM
how much to gap spark plugs kettsupp Service & Maintenance 20 02-22-2005 06:20 PM
gapping spark plug HS WRB-rex Newbies & FAQs 2 11-28-2002 03:24 PM
Can you side gap spark plugs on the 2.5's? spshultz Normally Aspirated Powertrain 4 07-07-2001 01:40 AM
