Old 01-12-2005, 02:47 PM   #1
nitrohuffer
Member#: 6982
2001 Legover
04 forester xt
Default Uneven idle problem on my snowblower
11:00 at night I get home to 8" of snow. Thats the good part. I fire up the snowblower, it's a 8 or 9 year old craftsman with 8hp briggs and stratton. Ran fine for about 3 minutes then started surging and bogging out to the point where it slowly died. The gas is fresh and the plug looks fine. I'm thinking maybe the carb is gunked up?
ibshovelityourselflazy!
nitrohuffer is offline   Reply With Quote
Old 01-12-2005, 02:51 PM   #2
DISCOPOPE
Member#: 43339
2oo4 STi
URgt35r w/t3hM3finj3cki0n
you drain the bowls last spring?
if not that 2" of varnish just fuxored up your carbs.
next time use alcahol free gasoline, and put a cap of seafoam in every 2 gallons you pump.
DISCOPOPE is offline   Reply With Quote
Old 01-12-2005, 02:52 PM   #3
Philsdabom
Member#: 55288
just adjust the carb, make sure you didn't leave choke on
Philsdabom is offline   Reply With Quote
Old 01-12-2005, 02:53 PM   #4
Grap
Member#: 6590
Why did you feel the need to post a technical snowblower question to OT? n00b!
Grap is offline   Reply With Quote
Old 01-12-2005, 02:53 PM   #5
SkirtBoy
Member#: 11056
2012 MB C250 CPO
Black on Tan
Top up the boost fluid.
SkirtBoy is offline   Reply With Quote
Old 01-12-2005, 02:55 PM   #6
nitrohuffer
Member#: 6982
2001 Legover
04 forester xt
Old 01-12-2005, 02:56 PM   #7
bobturismo
Member#: 42145
6-4 jockin da bish-
es and slappin the hoes.
"MY MOTHER WAS A SNOWBLOWER!!"
bobturismo is offline   Reply With Quote
Old 01-12-2005, 03:00 PM   #8
03WRXMA
Member#: 35081
2012 WRX
I have the same motor on my same age Snapper.
I find that if the choke is NOT left on at least it little it runs like crap...
03WRXMA is offline   Reply With Quote
Old 01-12-2005, 03:02 PM   #9
Trip McNealy
Member#: 37338
2007 Legacy 2.5 GT
2009 Daytona 675
Trip McNealy is offline   Reply With Quote
Old 01-12-2005, 03:02 PM   #10
nitrohuffer
Member#: 6982
2001 Legover
04 forester xt
hmm I'll try that tonight before I take it apart.
Old 01-12-2005, 03:13 PM   #11
scoobydorift
Member#: 43128
92 RWD, 96 FWD
05 AWD
if you need to take it apart clean out the jet. i rebuild a carb on a snowblower 2 times before i realized that the jet was all gunked up.
Rick
scoobydorift is offline   Reply With Quote
Old 01-12-2005, 03:15 PM   #12
nitrohuffer
Member#: 6982
2001 Legover
04 forester xt
Can I just dump a bunch of injector cleaner in it? I so don't like working on these things.
CEL / low idle problem on STOCK 05 2.5RS 2.5impreza Normally Aspirated Powertrain 22 08-25-2014 06:57 PM
high idle problem on 93 1.8 in a 95L scobaru Normally Aspirated Powertrain 2 12-16-2004 11:28 PM
Idle question on my MY90 legacy sedan L BajaNut Legacy Forum 2 06-18-2003 06:17 PM
A/C problem on my L SAND_MAN1 Normally Aspirated Powertrain 9 04-30-2003 02:35 PM
serious idle problems on 99RS pearlblack2.5rs Service & Maintenance 8 03-29-2002 09:11 PM
