#1 |
Member#: 33370
Vehicle:2002 Impreza WRX Blue now w/ 6 fun flavors |
Well I started w/ a search and found a lot of recommendation w/ out reason and a lot of speculation w/ out support... Yes I've also read the big FAQ and while helpful doesn't really answer my ?
So I'm just going to ask.. I'm finally going out and grabbing some plugs 1 step colder for my stg4 wrx. I have found in the past that both Phil (elemental) and Nathan (txs) in the past have recommended the NGK PFR7G-11 for a quality plat plug. I have seen others say that this is over gapped for our use and I need the non -11 if so why is it such a trusted tuner would recommend this. Further when I go to actually gap these plugs before install what should I shoot for .032 (high end of recoomendation) or .028 (low end of spec)... and what is the advanatage/disadvantage of a larger/smaller gap In my knowledge the difference is the larger gap should allow for more power and complete burn w/ the risk of blow out .. and thus the recommendation is the highest gap your ignition system can drive w/ out this blow out.. does this mean I should attempt a gabp near .032 or even greater if I have never experienced blow out in the past? Thanks for reading... Chuck
#2 |
Member#: 33370
lots of views no thoughts?
#3 |
Member#: 36823
Vehicle:03 MBP WRX Sold :( 93.5 Single Supra :) |
I just bought the BKR7E copper plugs and am looking for some of the same answers.
#4 |
Big Ron
Moderator Member#: 18062
While I respect the opinions of those tuners, I asked the identical question to the folks at Cobb Tuning. When I get my tune there I will be using OEM plugs with ~50k miles on them. When asked about type/style/gap/heat range of plugs, I was told to not bother. :shrug:
#5 |
Member#: 16200
Vehicle:OK Houston we have an Uncle |
someone, hotrod I believe, posted a VERY concise answer to this question in one of the 'sparkplug' threads....I looked and can't seem to find the one....
BUT.... http://www.ngksparkplugs.com/techinf...200&country=US "Q: What is the maximum I can open or close the gap? A: NGK doesn't recommend adjusting the spark plug gap < or > .008". The reason for this is the ground electrode and center electrode won't line up properly, hindering spark plug performance." ....and THAT is why the '-11' is the WRONG plug for a turbo'd EJ engine. |
#6 |
Big Ron
#7 |
Member#: 36823
Unabomber, uncle scotty, i am that much wiser after reading that post, i solute you
![]() P.S. Unabomber i didn't read your entire Spark plug FAQ but if its not in there that post should have a reference or two from hotrod's post. |
#8 |
Big Ron
After re-reading his post yesterday, it's now linked in my FAQ.
#9 |
Member#: 33370
Yep found hotrod's thing to be exactly as I thought the wider the non problematic gap the better.....
Thank you all. |
| Thread Tools | |
| Display Modes | |
| spark plug gap NGK Iridium plugs? | SeaRex | Factory 2.0L Turbo Powertrain | 14 | 09-12-2004 09:49 PM |
| What spark plugs, and what gap? | kaos200 | Factory 2.5L Turbo Powertrain | 8 | 07-07-2004 09:55 PM |
| spark plug gap & fluid capacities | jamest46 | Service & Maintenance | 5 | 12-18-2003 06:20 PM |
| Spark Plug Gap | Scooby South | Factory 2.0L Turbo Powertrain | 1 | 04-27-2001 12:10 AM |
| Spark Plug Gap??? | Ben | Legacy Forum | 0 | 01-28-2001 10:49 AM |
