#1 |
Member#: 30488
TXIC
Vehicle:2006 Acura TL Gray |
Hey all,
I was checking the oil the other day (when the engine was cold...) and saw that it was a little low. so i added an enough amount for it to go back to the full mark. Anyway, i checked it today when the engine was warm. I got home, let it sit for ~15 minutes, and then checked it. It seems to be overfilled, the dipstick reads about 1 centimeter passed the Full mark. I need to drive from Houston to Dallas tomorrow (250 miles). Do i absolutely need to fix this before i go, or is it not that big of a deal? Please let me know. Thanks
#2 |
Member#: 63076
Vehicle:2004 Outback Sport Red! |
Not a big deal. Do you remember the notch above the full mark? It may read that high when the oil is hot. The temperature of the oil will make a big difference in the readings. Make sure the car is level - or at least parked in the same place - when you check the oil level, too. Even a little change will effect the reading on the dipstick.
#3 |
Member#: 1847
Vehicle:Team Broken: V6 GF rallyarmor.com |
Ill post it again.
Dipstick reading 101 hole closest to the bottom = low (about 1/2 qt) next hole up = Full when the engine is cold Notch on dipstick = Full engine at normal operating temps. To check oil properly when engine is cold, start the engine and let it run for a second or so, turn off the car then check the oil level. Jay |
#4 |
Member#: 30488
TXIC
I know how to check oil, I just wanna know if i have the risk of bustin any seals if i'm about 1/4 - 1/2 quart high on oil...
#5 |
Member#: 32371
Vehicle:'02 t-rex wagon platinum |
^^^^ no. u're car will be fine
#6 |
Member#: 30488
TXIC
Ok, awesome. Thanks guys.
#7 |
Member#: 72829
W. Canada
Vehicle:2006 HTA68'd wagon Powered by RomRaider |
In the manual for my VW Passat, it warns that overfilling engine oil can lead to fouling of the catalytic converter and kill it over time. Wil the Boxer engine be any different? If I only had the manual for my 2.5RS with me...
#8 |
Member#: 66640
Vehicle:1997 Legacy Outback Glacier White |
Overfilling the oil can cause frothing, and frothing is bad. What that has to do with the cat is beyond me, but whatever. I for one would be more concerned with my main bearings than with the cat...much, much more difficult, time consuming and expensive to replace (if you count labor, anyhow).
#9 | |
Member#: 72829
W. Canada
#10 |
Member#: 30488
TXIC
Yeah, I know that overfilling can cause very bad things, but we're talking about 1/4-1/2 qt MAX...Probably only about 1/4 qt...can this really cause such bad things?
#11 | |
Member#: 72829
W. Canada
#12 |
Member#: 48360
Vehicle:2011 WRX 5-door Silver |
Can I sugest getting one of these? http://www.fumotovalve.com/ Not only does it speed up oil changes and make them less messy but it also allows you to drain a little oil if you overfill by accident...
| Thread Tools | |
| Display Modes | |
| help me fix my stupid headlight problem... | scoobyi | Electrical & Lighting | 4 | 12-13-2009 09:22 PM |
| my friend and I, me and my friend, my friend and me | Matt A | Off-Topic | 44 | 09-20-2009 12:04 PM |
| somebody help me with my stupid Vortec engine GM truck | markman | Off-Topic | 8 | 08-01-2006 10:25 AM |
| Please, assist me in my stupidity. | moltenicce | Off-Topic | 6 | 11-24-2005 12:52 AM |
| Me and My Friends WRX went for some pictures/ and offroading and a movie HAHA | LookingForPower | Member's Car Gallery | 24 | 08-15-2005 04:16 PM |
