Old 01-12-2005, 05:42 PM   #1
kaneda3
Member#: 8057
99 rs-t & 02 sti
95 s14.5
Default wrx swap into 97L ? on axels
want to put the r160 in with the swap and was wondering if all the axels are the cerroct length to fit in to an L
thanx mike
kaneda3 is offline   Reply With Quote
Old 01-13-2005, 12:04 AM   #2
OvenMitts
Member#: 46278
96 Impreza
"brighton"
For the rear, WRX sedan axles will work (they worked for me at least) I would assume the same for wagon axles
As for the front, you'll either need some WRX wagon axles or RS axles.
OvenMitts is offline   Reply With Quote
Old 01-13-2005, 01:32 AM   #3
kaneda3
Member#: 8057
99 rs-t & 02 sti
95 s14.5
ok well on the front what about reusing the L axels?
Old 01-13-2005, 02:16 AM   #4
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
L axles won't work. this is coming from a guy who's tried.... well I tried using non LSD rear axles from a 94 L but from what I'm able to collect 99-01 RS rear axles will work even though 99RS had no LSD? currently I'm using some newier legacy axles on my R160. theres something to look for on the axle to know if they will work or not I completey forgot what it was at the moment
scobaru is offline   Reply With Quote
Old 01-13-2005, 11:44 AM   #5
linsavy
Member#: 11620
1997 GF4-STiV3 clone
I am running all 97 L axles with STi tranny and STi 4.44 rear LSD -R160. It was published on here that it wouldn't work, but yet it does. YMMV.
linsavy is offline   Reply With Quote
Old 01-13-2005, 11:52 AM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
whoa horsie!!!!
#1 not all lsds are outties (or innies)
#2 you already have a r160
#3 front axes are the same length/spline count (the new stis are stronger) only exception is 93-94 FWD cars
#4 99 rs axes are innies 00-01 are outties (or vise versa)
#5 one of the rear axels is longer than the other
if you match up th whole innie/outtie deal the only place things get grazy is when you switch to the r180 diff
Old 01-14-2005, 04:53 AM   #7
kaneda3
Member#: 8057
99 rs-t & 02 sti
95 s14.5
i know i already have a r160 but i wanted to the r160 from the wrx so i get the lsd and the same final drive
my only question is whether the front and rear wrx axels are the correct length for the L
so all post 94 axels are the same length?? any confirmation on this??
mike
Old 01-14-2005, 09:45 AM   #8
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
front axles no problem with any AWD subaru rear is what you should be worried about. I think pre 97 axles won't work in rear but thats all speculation I have nothing to back that up besides taht my 94 rears didn't work
Old 01-14-2005, 11:17 AM   #9
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
post 90 AWD front axels
any year real axels as long as the inne-outtie matches up
the year has nothing to do the rear being innei or outtie some models have inne some outtie
Old 01-14-2005, 11:53 AM   #10
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
we need to make a sticky about what axles will work with what...
Old 01-14-2005, 04:38 PM   #11
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
are you talking about the whole shalf? such as the accual trans is outie and the axles are innie ??
if thats the case its not true because both 94 L diff and 94 WRX diff's were innie and both axles I had were outies and my 94L just would'nt fit in the R160 LSD diff thus not working.
Old 01-14-2005, 06:13 PM   #12
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
did you take the c-clamps off?
Old 01-15-2005, 12:44 AM   #13
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
C clamps were off we talked to a few other subaru guys and we all came to the conclustion that it wouldn't work. I gotta talk to my bro about what was different between the 2 axles compared side by side
Old 01-18-2005, 11:25 AM   #14
Streetman
Member#: 8243
97 Brighton 2.5!
the REAL red
For what it's worth, I used front RS axels on a 97 Brighton. Actually, I used axles.
Streetman is offline   Reply With Quote
Old 01-18-2005, 09:07 PM   #15
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
Fronts will work. Like everyone else said, Innies or Outties.
Z
Zephyr is offline   Reply With Quote
what Gauge cluster to use... wrx swap in 97L crtan77 Pre-2002 Factory Turbo Powertrain 1 01-26-2009 05:33 PM
2002 WRX swap into 2001 RS swap question dtl1218 Subaru Conversions 14 08-13-2008 01:58 PM
99-01 RS dash swap into 97L Billy Subaru Conversions 8 11-20-2003 07:09 PM
WRX swap into BE B4wannabe Legacy Forum 6 01-02-2003 08:12 PM
WRX swap into a Forester. omahasubaru Forester Forum 5 03-23-2001 05:11 AM
