Old 01-12-2005, 06:03 PM   #1
wan2gofast
Member#: 68125
Default AccessPort Install
I many just be dumb but did anyone else have a problem finding these 2 green test connectors that u have to connect...anyone give me a clue on where they are?
wan2gofast is offline   Reply With Quote
Old 01-12-2005, 06:23 PM   #2
darkstarmoto
Member#: 44681
2011 WRX SWP Hatch
www.48hrs.info group lead
Have you tried searching the Cobb forum? They have a couple threads on where to find the connectors....http://www.wrxforum.com/cgi-bin/ultimatebb.cgi
darkstarmoto is offline   Reply With Quote
Old 01-12-2005, 08:23 PM   #3
BigJ04STi
Member#: 77239
2004 Impreza WRX
None
Climb under the dash, and there they are...
I found them in the parking lot of a local pharmacy where I bought a flashlight from. Basically to make a long story short. I got my AP, couldn't wait to get home to install it, ran into the first place I saw to buy a flashlight to look under my dash...yaddi yaddi yadda...I have a 93 octane stage 1 tune...
BigJ04STi is offline   Reply With Quote
Old 01-12-2005, 08:23 PM   #4
wan2gofast
Member#: 68125
so i need some massive help...i found the green connectors which had already been plugged in...is this weird? So any way we went about the normal procedure in the directions and the AP would let select my map and then it would say "Intalizing..." with 3 dots and then would just say turn car off and on and try again... we tried this but it would never go past these three dots is there anything u guys can tell me to help me out
Old 01-12-2005, 08:32 PM   #5
bemani
Member#: 5673
16 Hellcat
05 LGT, 02 bug eye
You are looking at the wrong green connectors. There might be multiples, depending on your car I guess.
bemani is offline   Reply With Quote
Old 01-12-2005, 08:38 PM   #6
Chigliakus
Member#: 77525
'02 GDA, '09 GR
'93 FD
Don't forget you have to connect the Cobb init connector as well. It should have come with your AP.
Chigliakus is offline   Reply With Quote
Old 01-12-2005, 08:41 PM   #7
stevessti
Member#: 71097
2005 Subaru
STi
I believe some people on Cobbs forums have said some cars have green connectors in both the drivers and passengers side foot wells.
stevessti is offline   Reply With Quote
Old 01-12-2005, 09:29 PM   #8
Brahmzy
Member#: 3293
'14 FXT-T
'15 XTERRA PRO-4X
These connectors only contain 1 conductor. They are loose just waiting for you to plug 'em together.
Old 01-12-2005, 09:37 PM   #9
wan2gofast
Member#: 68125
im going to try tomorrow and look in the passenger foot well or side panel and hope that those connectors are not together and then plug them together and then go out the directions as they are depicted
Old 01-12-2005, 11:16 PM   #10
WrxTream
Member#: 39207
2008 WRX STi
Dark Gray Metallic
What year and model is your car.
2002, 2003, 2004 WRX... will all have the init. connectors.(don't know about 05 wrx)
I know the 2005 STi doesn't have the init. Connectors and I'm pretty sure that the 2004 STi doesn't have them either.
The two green connectors are not hard to find.... when you get them connected you will start hearing the fans and stuff making noise... At least I did. Not sure but I think if they are connected your car wouldn’t start.
For some reason I doubt you would have to connect anything on the passenger side.... I'm sure Cobb would have let that be known (I may be wrong though)
The absolute best thing to do would be to call Cobb.... If you are having trouble..... I would just think it is better to ask them just incase.
-Bundy
WrxTream is offline   Reply With Quote
Old 01-12-2005, 11:36 PM   #11
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Yes ther are connectors on the passenger side too, normaly they should be connected and driver side disconnected. ? Connect pasenger side too and after finnishing instal disconnect driver side.
wrxdrvr is offline   Reply With Quote
Old 01-13-2005, 10:01 AM   #12
Chigliakus
Member#: 77525
'02 GDA, '09 GR
'93 FD
WrxTream:
You can drive with the green connectors together, the car will run fine but you'll get a flashing CEL. Don't ask me how I know this...
Old 01-13-2005, 01:26 PM   #13
zanderspeed
Member#: 72818
2002 Bugeye
EJ25 | FPGreen
took me about... 5 sec to find them! just look up and there they are
zanderspeed is offline   Reply With Quote
Failed AccessPort Install on 05 STi wan2gofast Engine Management & Tuning 9 01-14-2005 06:10 PM
AccessPORT install pics Peaty Forester Forum 8 10-12-2004 07:17 AM
VF34/STi injectors/Walbro Pump/AccessPort Installed Aerosim Research Ltd SCIC Vendor Classifieds 34 09-21-2004 05:00 AM
factory boost gauge not working! accessport installed cdavis03 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 09-20-2004 01:52 AM
Accessport install? Needles Engine Management & Tuning 2 07-28-2004 07:31 PM
