Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 01-12-2005, 07:26 PM   #1
DONAUDI
Member#: 71639
2004 STI
Default sti rad cap
viewed previous post, just want to clarify where it goes. resvior or radiator or both. thanx
DONAUDI is offline   Reply With Quote
Old 01-12-2005, 07:34 PM   #2
2phless
Member#: 69343
1998 TransAm cnvrtbl
Reservoir. Don't remove the one one the radiator. It supposedly has issues with sealing back up properly. I top-up through the reservoir.
2phless is offline   Reply With Quote
Old 01-13-2005, 11:15 AM   #3
Pirana
Member#: 55197
Thats BS, I had them all remove and reinstalled. I use 2 STi caps and just recently reinstalled the factory ones since I went to the dealer and didnt want them messed up by the mechanic. No leaks or smell.
Pirana is offline   Reply With Quote
Old 01-13-2005, 08:16 PM   #4
DONAUDI
Member#: 71639
2004 STI
SO WHICH IS IT? Havent been able to get a straight answer.
Old 01-13-2005, 08:42 PM   #5
ADR 04STi
Member#: 51918
2015 Audi S3
Daytona Gray
Lightbulb Tip
Donaudi : If you notice. . the cap on the engine has ears on it. The cap on the radiator is round. . The STi 1.3 bar cap has ears right? Should be on the package as well.
ADR 04STi is offline   Reply With Quote
Old 01-13-2005, 08:47 PM   #6
kool168
Member#: 61006
i replaced them both with STI 1.3 bar caps
kool168 is offline   Reply With Quote
Old 01-13-2005, 09:24 PM   #7
ADR 04STi
Member#: 51918
2015 Audi S3
Daytona Gray
Good idea. . .probably looks alot better too.How much did you pay anyway. . they pretty $$$ X2.
Old 01-13-2005, 10:36 PM   #8
DONAUDI
Member#: 71639
2004 STI
So im assuming you install it on the resvior if youve got one.
Old 01-13-2005, 11:52 PM   #9
kool168
Member#: 61006
Old 01-13-2005, 11:54 PM   #10
kool168
Member#: 61006
and i don't find it leaks any coolant
Old 01-14-2005, 01:32 AM   #11
Pirana
Member#: 55197
See 2 caps. Its not a big deal, both cap seal properly.
Old 01-14-2005, 01:45 AM   #12
DONAUDI
Member#: 71639
2004 STI
Looks awwwsome! I think im going to have to purchase another one. Besides only thougf guys sport pink. Radiator caps that is. <--gotta love this guy
Old 01-14-2005, 01:57 AM   #13
STi-BOD-
Member#: 78539
2005 Subaru STi
K&N Typhoon HKS CarbonTi
wherd u get that strut tower bar from?
STi-BOD- is offline   Reply With Quote
Old 01-14-2005, 04:06 AM   #14
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
isint the cap that goes on the radiator not supposed to have the spring in it and just be basicly a circular filler cap ?
im trying to compare it to the setup after my swap
ImprezaRSfan! is offline   Reply With Quote
Old 01-14-2005, 08:17 AM   #15
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
Have any more info on that CF shroud you have there?
offset
offset is offline   Reply With Quote
Old 01-14-2005, 09:20 AM   #16
2phless
Member#: 69343
http://store1.vividracing.com/catalo...roducts_id=189
But then you have to deal with vivid... is it really worth it?
Old 01-14-2005, 09:39 AM   #17
AndyH
Member#: 2133
2005 STi WRB/Gold
2005 S4 Avant
Originally Posted by kool168
No offense man, but I think it's time for a new camera
AndyH is offline   Reply With Quote
Old 01-14-2005, 01:57 PM   #18
kool168
Member#: 61006
it's my cell fone
Old 01-16-2005, 07:21 PM   #19
DONAUDI
Member#: 71639
2004 STI
Ok so after about 2 min of deep thought i knoticed the pressures on the two caps were diffrent. The one on the resvior round one had a higher pressure than the one on the radiatior w/ears. So i put the round one from the resvior on to the radiator and put the STI cap on the resvior. Sounds good? Let me know if this is unadvisable.
Old 01-17-2005, 08:32 AM   #20
cann
Member#: 8618
isn't that higher pressure caps be tougher on the hoses?
it would suck if u pay 48 bucks for an eye candy and risk cracknig a hose
cann is offline   Reply With Quote
Old 01-17-2005, 12:47 PM   #21
Pirana
Member#: 55197
yes, the STi and for that matter all of the upgraded radiator caps should be 1.3bar. You upgrade because the car is supposed to run hotter at higher boost. This caps are for people with upgraded hoses and radiators...but if you dont push your car on a track (not 1/4) you should be safe. I have this set up since I bougth the car, and have over 100 passes on a 1/4 track with no problems. I probably wont advise to use them if you run in autocross or something similar since the engine can be pushed hard for long periods of times. Myself I would >STi ll< use them but I run it at my own risk
~~~~> the strut bar came from a used STi in Japan (titanium)
~~~~> the c/f cover is a piece from www.lnronline.com, its non-functional since it keeps the heat of the alternator trapped, so its one of those bling-bling pieces.
Old 01-17-2005, 01:09 PM   #22
STi-BOD-
Member#: 78539
2005 Subaru STi
i was talking to someone and he said that its japan spec. So you have to move some a/c parts to install it and subaru will void ur ass if they see it onn their. and im pissed because i can get one but i dont wana loose the warrenty.
rallispec.com i belive
Old 01-18-2005, 01:28 AM   #23
Pirana
Member#: 55197
I have taken my STi 3 times to the dealer, and no problem. All you have to do is unbolt one 10mm bolt that holds the AC line by the firewall, flip the bracket and bolt it again. That it.
Old 02-21-2005, 05:34 AM   #24
kool168
Member#: 61006
back to the topic...
is there any different between WRX and STi radiator?
since many WRX owners saying that the STi high pressure rad cap caused blew their rad...
just wondering does the STi rad has the ability to hold that high pressure?
Old 02-21-2005, 05:46 AM   #25
2phless
Member#: 69343
I'm wondering what the point is. More pink under the hood? The word STi? Are there real concerns with the "performance" of radiator caps out there? Just leave them alone unti lthey dry rot in 10 years.
Garrett GT28RS turbo, STi rad cap, STi Pink injectors, Blue Ultrasuede fabric NickWRX Tri-State Area Private Classifieds 6 04-29-2008 08:13 AM
Garrett GT28RS "disco potato" turbo, STi rad cap, Sti Pink injectors NickWRX Engine/Power/Exhaust 9 04-29-2008 08:12 AM
FS:CT: STi rad cap SPT batt tie down/oil cap fasterthanrayswrx Interior/Dressup/Audio & Security 5 09-23-2006 01:06 PM
FS: turbo xs rfl bov / sti rad cap BlackWagon Private 'For Sale' Classifieds 6 02-29-2004 04:09 AM
tampa area sti rad cap for sale cheap BlackWagon South East Region Forum 8 04-18-2003 10:46 AM
