Old 01-13-2005, 01:04 AM   #1
Meat-Head-h
Member#: 36957
Default Should I change my air filter now?
My car ('02 WRX wagon) just hit 35k miles, and I haven't changed the air filter on it to date. Should I change my air filter now? And if I should, should I purchase a K&N filter instead of another stock one?
Meat-Head-h is offline   Reply With Quote
Old 01-13-2005, 01:07 AM   #2
gjhsu
Member#: 12329
2o15 WRX
Ice Silver
stock ones are fine, and yeah, go ahead and chage it. I thought air filters were slated for every 15k.
gjhsu is offline   Reply With Quote
Old 01-13-2005, 01:09 AM   #3
Meat-Head-h
Member#: 36957
Would I notice any sound or performance difference if I go with the K&N filter?
Old 01-13-2005, 01:13 AM   #4
powerslide23
Member#: 61956
2008 Tribeca
Pearl White Metallic
You will hear more sound (snort) and your butt dyno might feel a little power.
powerslide23 is offline   Reply With Quote
Old 01-13-2005, 01:20 AM   #5
Meat-Head-h
Member#: 36957
Another question, what is the model number for the filter for a '02 WRX.
I searched and I came up with many results, somepeople say 33-2031-2, others say 33-2075, and on the official K&N website it says 33-2232.
I am confused.
Old 01-13-2005, 08:10 AM   #6
doobie
Member#: 6570
04 WRXSW
9.3 TRB0 CNV
That filter is gonna be real dirty. I change mine every 7,500 miles and am continually suprised about how dirty it is. Stay with the stock one, the oil in the K&N can foul the MAF sensor.
Steve
doobie is offline   Reply With Quote
Old 01-13-2005, 10:34 AM   #7
Hayes
Member#: 11808
I change mine per schedual at ~30,000 miles and still looks good. I stick with the OEM or Purolator. K&M lets more dirt in for a miniscule power gain at the top end only and is a mess to recharge. ed
Hayes is offline   Reply With Quote
Old 01-13-2005, 10:37 AM   #8
subieworx
Member#: 47769
You won't feel a think with just an aftermarket panel filter. Not worth the money.
subieworx is offline   Reply With Quote
Old 01-13-2005, 10:42 AM   #9
z&cobb
Member#: 12344
2002 2JC
blue
If you have $ to burn you can put in the "for offroad use" only STI air filter. I have no idea if it improves filtration or airflow, and no knowledge of demonstrated increased torque/HP under controlled conditions. The good thing is it is not oiled. The bad thing is it is not meant to be cleaned and reused. Subaruparts.com carries it.
z&cobb is offline   Reply With Quote
Old 01-13-2005, 01:54 PM   #10
Malik
Member#: 29272
2002 WRX Wagon
The K&N is worth it for the long run if you are careful about the oil. I have had issues with the oil from a K&N filter fouling the MAF (factory oiled and blotted several times before install) and reverted to the stock filter for greater peace of mind (given that I am lazy!).
Malik is offline   Reply With Quote
Old 01-13-2005, 03:35 PM   #11
Meat-Head-h
Member#: 36957
I just bought and installed the K&N filter. It was easy. The filter I bought was pre-oiled.
Old 01-13-2005, 03:51 PM   #12
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
Go buy another stock filter. If you look at the cost difference the paper filters are the way to go ($12 for paper or $45 for K&N + $10 for ea recharge kits).
mbiker97 is offline   Reply With Quote
Old 01-13-2005, 03:53 PM   #13
zinc99
Banned
Member#: 56030
02 stage 2 wagon
But an K&N recharge kit will last about 3 cleanings.
zinc99 is offline   Reply With Quote
Old 01-13-2005, 03:56 PM   #14
Leadfoot77
Member#: 74268
2013 STi
with the K&N it's true you can get oil on the MAF sensor but you can clean this off - VERRRRY gently.
Leadfoot77 is offline   Reply With Quote
Old 01-13-2005, 03:59 PM   #15
Leadfoot77
Member#: 74268
2013 STi
but I think you only need to re-oil the K&N every 100k miles (iirc)
$12 per paper * 13 times in 100k = 160 > 45+10
Old 01-13-2005, 04:01 PM   #16
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
The stock filter will cause no problems and filter as well or better than any aftermarket filter.
The only real reason to use anything else is if you aren't using the stock airbox.
And beware the oiled filters....they have caused many here to chase their tails looking for the cause of engine issues....
Old 01-13-2005, 04:02 PM   #17
subenerd
Member#: 72630
2004 STi
My first change was at 30K and it was FILTHY! I will change mine sooner next time
subenerd is offline   Reply With Quote
Old 01-13-2005, 04:33 PM   #18
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
You need to clean the K&N just as much as you replace a standard filter.
I usually got 2 cleanings/re-oiling out of a recharge kit.
Old 01-13-2005, 05:21 PM   #19
Uncle Scotty
Member#: 16200
OK buy Nates beans
Old 01-13-2005, 05:26 PM   #20
zinc99
Banned
Member#: 56030
02 stage 2 wagon
If you dont get at least 2 cleanings you are using way too much oil. You are just to get the cotton red not saturated in oil. Also always apply the oil in the direction of the air and not on the back so it will stay in the cotton and not go into the MAF.
Old 01-13-2005, 05:54 PM   #21
Meat-Head-h
Member#: 36957
The instructions say to oil both sides though.
Old 01-13-2005, 06:06 PM   #22
Leadfoot77
Member#: 74268
2013 STi
IIRC it's just one side like zinc said I'm and POSITIVE you don't have to re-oil it as often as you change the paper filter. IIRC the manufacturer advertises reoiling at 100k but I think typically you'd want to clean it slightly more often than that. 2 cleanings per recharge kit is ridonkulous.
Old 01-13-2005, 06:26 PM   #23
Filanwizard
Member#: 78643
1995 Chevy S10 4x4
Teal Green
wow 15k for an air filter, and here for years i was allways told you change them every oil change.
Filanwizard is offline   Reply With Quote
Old 01-13-2005, 06:38 PM   #24
brunetmj
Member#: 8023
2004 2.5 RS
Much depends on environmental conditions. If it's dirty change it. Perhaps what you were told was to check it every oil change? Now when I used synthetic oils and had low travel mileage I changed the filter when I changed the oil.
brunetmj is offline   Reply With Quote
Old 01-13-2005, 07:48 PM   #25
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
Originally Posted by Uncle Scotty
I always had a ton of oil left over. It was the cleaner that ran out.
Changed my driving routine, how often should I change my oil? eurospek Service & Maintenance 8 11-04-2009 10:57 PM
How much power can I expect to gain by changing my air filters? Malasubidude Newbies & FAQs 17 07-16-2008 01:54 PM
How often should I clean my air filter? Jay04WRX Service & Maintenance 9 08-17-2005 05:13 PM
when should i change the air filter?? lik Vancouver Impreza Club Forum -- VIC 12 05-14-2003 06:12 PM
Should I change my oil now or later? Penphoe Normally Aspirated Powertrain 6 09-03-2001 02:07 PM
