#1 |
Member#: 8488
Vehicle:1993 Impreza GCStyle Teal |
As some of you know I'm working on a "budget" 250hp engine.
Block stock EJ20G 30,000 miles, fresh seals Heads 95 EJ22 N/A heads 95 EJ18 intake manifold, wireing and ECU. Stock exhaust manifold, my up pipe, down pipe, and 2.5" press bent exhaust with 2.5" CATCO cat, straight through muffler. TD04L Turbo E-manage 370cc injectors Question is the heads: Has anyone used WRX springs and retainers on the ej22 heads? The WRX is designed for a 7000 RPM redline vs the 6200 RPM redline of the ej22. I don't plan on bumping the redline, but with track days pushing the car at 5000 RPM for 30 minutes at a time, I don't want valve float. Anyone have any info? Are they the same? Different? if they are different, how? Chad
| Thread Tools | |
| Display Modes | |
| WRX ej205 heads mild port at seats, +1mm valves, crower valve springs and retainers. | NITROS | Engine/Power/Exhaust | 16 | 12-02-2009 03:45 PM |
| 2002 WRX springs and strut on 07 2.5i | Yakshii | Newbies & FAQs | 4 | 06-29-2009 03:29 PM |
| Installing WRX springs and struts on 99 OBS | kurier44 | Brakes, Steering & Suspension | 9 | 11-26-2005 01:12 PM |
| WRX springs and struts on Legacy good idea? | StuBeck | Legacy Forum | 8 | 09-22-2003 12:55 AM |
| WRX springs and swaybar on an L? | pankopp | Brakes, Steering & Suspension | 4 | 08-12-2003 11:40 AM |
