Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum
Old 01-13-2005, 11:45 AM   #1
Jitenshakun
Member#: 61586
2005 STi
WI and all the goodies
Question Steering column knock at low speeds
Hey Guys,
I get some pretty loud and noticeable knocking in my steering wheel/column at low speeds, especially when its colder outside. Usually happens when I'm parking, turning around, etc.
Anyone else getting this?
-J
Jitenshakun is offline   Reply With Quote
Old 01-13-2005, 12:49 PM   #2
bigbear522
Member#: 21304
2002 Impreza WRX
Funky Silver Party Wagon
yeah this morning when everything is super stiff, I heard a loud crack while I was trying to turn.. hope everything is ok..
bigbear522 is offline   Reply With Quote
Old 01-13-2005, 01:13 PM   #3
Jitenshakun
Member#: 61586
2005 STi
Mine isn't a crack. It is definitely a knocking sounds and persists throughout the turn. Its similar to a 4x4 with big knobby tyres losing traction on a tight corner but more pronounced in my car. Besides, my Michellins don't exactly have the same size tread as a 4x4 truck.
-J
Old 01-13-2005, 01:36 PM   #4
Member#: 47261
might wanna take a look at your cv joints on your front halfshafts... if I'm not mistaken once one of them is toast you get a knocking sound when you turn at lower speeds. Easiest way to tell is there will be a break in your cv boot and/or there's greasy stuff all over.
for me when I park my car and then move it a couple hours later my brakes like to stick a little bit... (prolly from the melted snow from donuts ) then I get a "clunk" and that's it.
soccer_freak_m@hotma is offline   Reply With Quote
Old 01-13-2005, 04:35 PM   #5
RickDaTuner
Member#: 28806
05 STi
well i knwo im getting a clunk from one of my driver side struts, mabey this is the problem you are experincing aswell, allthough mine clunks all the time at any speed in any direction wehn going over any imperfections in the road, since you car is new you should take it to the dealer and have them look at it...
RickDaTuner is offline   Reply With Quote
Old 01-13-2005, 04:57 PM   #6
GD8
Member#: 65085
2004 Impreza WRX
World Rally Blue
Mine was super stiff too and I previousily warmed the car. I thought its suppose to be power assist steering. It felt more like manual steering. but no crack noise.
GD8 is offline   Reply With Quote
Old 01-13-2005, 09:39 PM   #7
phantomsr
Member#: 69071
2002 Stg2-WRX Wagon
WRB & Dust
I'd second the CV joints if it's it's a click/clunk/knock that occurs when turning. The fequency of the knock will vary with speed. If you can get the car up on a chassis hoist and turn the wheel all the way to either side and rotate the wheels, you'll usually see a bit of a hop in the CV if it's pretty bad. Then it's time for a new one.
phantomsr is offline   Reply With Quote
Old 01-13-2005, 11:29 PM   #8
Wheelhop
Member#: 44263
04 WRX sedan
The first winter I had my car the front suspension bushings froze up alot when it was cold. It caused knocking sounds in the steering and horrible vibrations at speed.
This winter I was dreading a reoccorance but it hasn't happened. Wonder why it happened so much when the car was new????
I also had problems with the RE-92's feeling very square when it was very cold but now I'm riding on RSI's.
Wheelhop is offline   Reply With Quote
Old 01-14-2005, 01:02 AM   #9
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
Jitenshakun
What is your DCCD set at.
Wombat North is offline   Reply With Quote
Old 01-14-2005, 01:18 AM   #10
syncros
Member#: 30032
2005 Impreza wagon
black
Maybe due to the extreme cold temps the front diff is acting like the front diff of a 4wd truck locked in low range (seeing as you liken the sound to same)? Perhaps this is related to Wombat North's question. Ah, I'm probably way off base.
OT: Wombat North, I sent you a PM.
Thanks,
Syncros
syncros is offline   Reply With Quote
Old 01-14-2005, 10:03 AM   #11
Jitenshakun
Member#: 61586
2005 STi
It'll definitely do it when I have it in Lock, but sometimes it'll do it when I have it in Auto.
-J
Steering shudder at low speed - please help doctoct Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-18-2008 01:21 PM
FS: 02 WRX Steering Column w/Key Low Miles B-power-B Interior/Dressup/Audio & Security 3 09-25-2008 11:28 PM
Knock in rear of car when Gas is let off at low speeds. silimpreza Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 24 05-30-2008 12:18 PM
Occasional steering shudder turning at low (parking lot) speeds? wayoutwest Tire & Wheel 3 09-24-2005 01:37 AM
Binding in the steering at low speeds? 03MBP Brakes, Steering & Suspension 2 09-04-2005 02:23 AM
